ZeppOS Player 2
Newest Release
CHANGELOG
2.3.3 · September 17, 2026
2.3.2 · September 16, 2026
2.3.1 · September 16, 2026
2.3 · September 16, 2026
Older Versions
VERSION 2.2.1
CHANGELOG
VERSION 2.1.3
CHANGELOG
VERSION 2.1
Release Start
Future Versions
VERSION 2.4
These will then be recognized in the player with the label “- Editor,” and you can test your unfinished WF files.
VERSION 2.X
But that's still a long way off.
TRANSLATE
