ZeppOS Player 2
Lattenknaller
Has thanked: 61 times
Been thanked: 161 times
ZeppOS Player 2
Post by Lattenknaller »
Hi everyone,
ZeppOS Player 2
Newest Release
Download v2.3.4
CHANGELOG
2.3.4 · September 17, 2026
2.3.3 · September 17, 2026
2.3.2 · September 16, 2026
2.3.1 · September 16, 2026
2.3 · September 16, 2026
Older Versions
VERSION 2.2.1
Download Release 2.2.1
CHANGELOG
VERSION 2.1.3
Download Release 2.1.3
CHANGELOG
VERSION 2.1
Release Start
Future Versions
VERSION 2.4
Select a folder that contains incomplete works started with Editor 3 but not yet finished.
These will then be recognized in the player with the label “- Editor,” and you can test your unfinished WF files.
VERSION 2.X
If everything works and we're at nearly 99.9% Zepp compatibility, the next step is to develop our own editor.
But that's still a long way off.
Translate missing language
TRANSLATE
Translations.xlsx
Has thanked: 436 times
Been thanked: 2137 times
Is it possible to create a version where the ZIP file is extracted into a folder—similar to ZeppPlayer—so that the `index.js` file can be edited directly when testing watch face scripts?
Lattenknaller
That's easily possible in the STANDALONE version. I've also extracted all my WF files there and am editing the index.js file in real time. That doesn't work in the online version. The online version is actually meant for users who want to quickly test their first (or even third :-) ) WF. The STANDALONE version is clearly intended for power users.
Unfortunately, I can’t send you a private message; otherwise, I would have sent you a download link. I’d rather not post the link publicly here.
But let's wait for an admin—maybe I'll get the chance to post the tool here, and then there will be updates for new watches or, for example, for ZeppOS 6. Users could also post their errors, and I'll take a look at them.
Lattenknaller wrote: 10 Sep 2026, 11:33
Thanks for the information, and that’s great news about the standalone version allowing direct edits to `index.js`.
As for the PMs, I apologize; I had them turned off for so long that I completely forgot.
Has thanked: 1179 times
Been thanked: 281 times
Lattenknaller wrote: 10 Sep 2026, 09:29
I would have liked to attach the STANDALONE version here as well, but the limit is only 5 MB, and the tool is 10 MB. Maybe an admin could increase my upload limit; then I could even keep the package up to date here and post new updates right away.
Unfortunately, we can't increase the attachment limit just for one user. The attachment rules are global for the entire forum, so changing them would affect everyone.
As an alternative, you can upload the standalone package to any file hosting service and send us the download link via private message. We'll host the file separately on our server and update it for you when new versions are released.
We could even try hosting it as a dedicated tool on our website, similar to the Watch Face Generator. If everything works well, we'd be happy to provide it with a permanent home on our server so users can always download/use the latest version.
If you're interested, just send us the file and we'll discuss the best way to organize it.
Lattenknaller
Okay, I'll make a few more tweaks tonight and then send you the files for the web version tomorrow. Thanks for agreeing to host the tool.
For now, 2–3 users will get the standalone version to test—uncompiled. As soon as everything is running smoothly, I'll host the tool on a file-hosting service and then offer support and updates. But as I said, that will come later. Thank you very much for your time.
Lattenknaller
New Version ONLINE 2.7.17
- Fixed an issue with the analog hour display
- Custom .ttf fonts are now used from the WF (this may cause some misalignment in the display, which is due to the font being used)
- Added various scripts, including sleep tracking and pulse charts.
- All types of animations should now work
I will first fix all reported bugs and then upload the ONLINE version to host it here. The STANDALONE version is being thoroughly tested and will soon be available for everyone to download here.
Lattenknaller
New Version ONLINE 2.8.17
- Fixed a bug where the digital time display was offset by a few pixels.
- BIP5 and similar older watch faces are now recognized and displayed correctly.
- Option to test the watch face with the original watch border (Skins imported from Sasha's Editor)
- Option to create .GIFs with or without the watch skin
frankh93
Has thanked: 26 times
Post by frankh93 »
Lattenknaller wrote: 11 Sep 2026, 11:33
Sorry for disturbing, could I get access to the standalone build too? Thank you in advance
Has thanked: 132 times
Been thanked: 21 times
Post by taw_bip »
Wow @Lattenknaller This is quite the undertaking and much appreciated!
I really liked Melian's tool because I had a number of issues trying to get the Zepp simulator running on my laptop.
Your tool removes all these technical hurdles. I look forward to the release of the standalone version.
Nice!
Been thanked: 1044 times
You can upload the archive containing the portable version to any file-sharing site or to GitHub. Then post a link to that archive here. That’s what I do with my editor. If the portable version handles watch faces in the same way as Zepplayer, it will be much easier to make changes to the watch face and test new features.
In edit mode (blue pencil when you press and hold the dial), the element labels are not displayed. Also, in this mode, you cannot switch between the different windows (element selection and background selection). Just in case, I’ve attached the dial I used to test this.
It would be nice if, when you opened the dial, it switched straight away to the correct watch model.
In the list of models, some of the names begin with ‘Amazfit’ whilst others do not. This makes it a little difficult to choose the right model. It would be better to write all the names in the same style.
Razaa Digital.zip
(351.56 KiB) Downloaded 10 times
I don’t seem to have skins for all the models. If necessary, I can have a search for skins for the missing models.
Lattenknaller
VERSION 2.1
RELEASE
MarioLie
Has thanked: 56 times
Been thanked: 37 times
Post by MarioLie »
I will create watch models for you.
Preview
Lattenknaller
MarioLie wrote: 14 Sep 2026, 08:04
Preview
Sure, I'd be happy to. You can see what's missing. But in addition to the images, I'll also need the internal dimensions—that is, how big the preview needs to be. And the images shouldn't be taller than 800px; shorter is fine.
@Lattenknaller
I am unsure whether this is an error or if the new version imposes limitations on animation rendering. In the previous test version, animations—whether generated via the editor or custom scripts—rendered perfectly. However, in Version 2.1.1, the animation display differs from the test version, It doesn't seem to be displaying the animation.
as shown in the attached image.
Preview Report
Best regards,
Thank you.
Lattenknaller
asoo wrote: 14 Sep 2026, 11:54
@Lattenknaller
Preview Report
Best regards,
Thank you.
@asoo That's probably a direct result of my last change: Smooth Second has always been choppy in the preview. I'll see if I can get Smooth Second to run smoothly without stopping the animations.
Will try to fix it
Lattenknaller wrote: 14 Sep 2026, 12:55
starts the animation at auto-increment? can you pn me the WF?
@Lattenknaller
I’ve sent the WF link I used for testing via PM.
MarioLie
Post by MarioLie »
Here's one complete Amazfit offer. The size of the picture is 800x800 px, and the height of the appearance is 644px. Shading is created for the web's colour #262428. If you'd like something created, let me know. I'd be happy to help.
Preview
watches3.zip
(3.06 MiB) Downloaded 3 times
watches2.zip
(3.91 MiB) Downloaded 4 times
watches1.zip
PSD watches
(4.21 MiB) Downloaded 5 times
Lattenknaller
VERSION 2.1.3
RELEASE
CHANGELOG
- Smooth-second image pointers remain fixed when Auto-Increment is disabled, while unrelated watchface and script animations continue normally.
- Legacy generated callbacks such as checkConnection, minute_circle_call and hour_circle_call no longer abort watchface initialisation.
- Zero-sized Zepp groups now render their children correctly, restoring generated multi-day weather forecasts.
- Added Russian and Ukrainian interface languages, translated by SashaCX75.
- Completed Compass translations, including Thai, Russian and Ukrainian.
Lattenknaller
VERSION 2.2.1
ZeppOS Player 2.2
CHANGELOG
- Added 33 watch skins with corrected display alignment ( skin credits for MarioLie)
- Added support for Amazfit Active 3 Premium, Active Edge, Cheetah Square and GTS 3, plus additional hardware IDs for existing models.
- Added Czech, translated by MarioLie, and included the revised Thai translation by Asoo.
ZeppOS Player 2.2.1
CHANGELOG
- Several set phrases was being translated; I probably cleaned them up too much. (fixed in 2.2.1)
- The buttons for the widgets was always active at startup. (fixed in 2.2.1)
screenshots
In the GIF file settings menu, the letters in the drop-down list are cut off at the bottom.
In the data configuration section, the display elements are positioned very close together. It would be better if there were some space between them.
Lattenknaller
A complete redesign of the three windows next to the preview is planned for version 2.3. So it'll look different anyway.
I'll take a look at the cropping at the bottom.
MarioLie
Post by MarioLie »
Preview
Added HUAWEI WATCH GT
Huawei
Files
redmi.zip
(627.27 KiB) Downloaded 1 time
HAYLOU.zip
(2.9 MiB) Downloaded 1 time
HUAWEI WATCH part 1.zip
(2.98 MiB) Downloaded 1 time
HUAWEI WATCH part 2.zip
(3.11 MiB) Downloaded 1 time
HUAWEI WATCH part 3.zip
(2.52 MiB) Downloaded 1 time
HUAWEI WATCH part 4.zip
(3.41 MiB) Downloaded 1 time
Users browsing this forum: SashaCX75 and 3 guests
