La ricerca ha trovato 133 risultati
Return
da wanders
08 apr 2024, 15:56
Jump to forum
Jump to topic
Re: Definitive Documentation for Zepp OS hmUI.createWidget()
Thanks, taw_bip , for the suggestion. I've pinged the developers on Slack.
EDIT: I've been informed that the "watch face API" is not maintained , per a Slack user by the handle of Silver. I've suggested that said API be put onto github and managed by a volunteer. We'll see.
EDIT #2: I got another ...
da asoo
02 mag 2024, 19:26
Jump to forum
Jump to topic
Re: Download Watch Faces to PC that are uploaded from the Zepp Store
If you want to modify the watch face installed through the zepp app. you must be rooted your mobilePhone first to be able to access the system folder (in Android).
Or you can download directly to your PC from the web.
You can try this web.
https://mmk.pw/en/zepp_explorer/explorer/watch/
But only ...
da GIK-Team
12 ago 2024, 20:17
Jump to forum
Jump to topic
Re: ©️ Takedown Requests from Copyright Holders (Ongoing Updates)
What is the scope of this takedown? The watch face name? The logo? The watch shape?
The scope of most takedown requests usually focuses on the use of protected graphics, such as logos, icons, or specific design elements. If you blur or remove these elements in the preview images, there's a good ...
da SashaCX75
07 giu 2025, 05:20
Jump to forum
Jump to topic
Re: How do I upload my watch face made in Zepp Watchface?
When exporting from Zepp Watchface Maker, switch off all models except yours. Then there will be only one zpk file inside the resulting file. In this zpk file take device.zip, this will be your watch face. If you upload it to this site and install it on the watch using qr code, refresh the page ...
da Postmortem
21 mag 2026, 11:21
Jump to forum
Jump to topic
Re: Is there any way for me to upload the watch face directly
Is there any way for me to upload the watch face directly to my watch instead of using the website to scan a QR code? sorry is this is a dumb question.
I haven't tried it lately but I used to do this:
I install watchfaces from my Android phone this way:
1. download the .zip file to your phone ...
da asoo
11 gen 2024, 22:49
Jump to forum
Jump to topic
Further update: I found some mentions on Discord about changes to QR code generation, and it seems to affect the upcoming version 10.8.5.
Some changes are coming to the way your custom QR Codes with perma links like the one put on `github` pages, are processed.
Starting from zepp app `10.8.5 ...
da asoo
09 mag 2026, 03:05
Jump to forum
Jump to topic
Re: Create a QR Code and Sync to device that use zeppOS by using the Zepp app
On my Windows 11 laptop, I used Claude to code up an automation.
Setup (one time)
Install Python from python.org if you don't have it
Save zpk_to_qr.py and zpk_to_qr.bat to the same folder
Open a terminal in that folder and run:
pip install requests qrcode[pil]
Usage
Drag and drop any .zpk ...
da SashaCX75
09 mag 2026, 07:30
Jump to forum
Jump to topic
asoo ha scritto: 09 mag 2026, 03:05
This file contains minor code modifications for use with litterbox,
which is catbox's non-permanent file hosting service, with file retention set for 1 hour.
Thank you. For my purposes, using littlebox is a better option.
da asoo
12 mag 2026, 04:56
Jump to forum
Jump to topic
I've created a GUI to help upload to LitterBox and CatBox, and generated and displayed a QR code with a URL for user convenience.
I won't be making any further modifications. I've attached the code in Python; feel free to modify it if you wish.
This code uses the following libraries:
requests ...
da SashaCX75
13 mag 2026, 19:26
Jump to forum
Jump to topic
Actually, this feature is already available in the editor. I’m just finishing off the styling, testing it, and creating the necessary files.
da asoo
15 mag 2026, 03:28
Jump to forum
Jump to topic
From my previous post:
https://amazfitwatchfaces.com/forum/viewtopic.php?p=22210#p22210
I've improved the app. You can now select catbox and littlebox, and use Filepost.dev for file uploads and to generate a QR code for installation.
I'd like to thank SashaCX75 for the information on filepost.dev ...
da osmat
24 feb 2020, 15:31
Jump to forum
Jump to topic
Huawei Watch Face Maker
Huawei Watch Face Maker v0.7.5b
Tuto Vidéo
Lien Programme
https://drive.google.com/drive/folders/ ... F8i5skX6GR
da MedicineMan4040
27 apr 2020, 21:55
Jump to forum
Jump to topic
Re: Help me with poor vision please.
Wow!!!!! Even a blind man (me) can see this! That is freaking awesome.
I just got home (snuck away from my covid zone) and will upload it to my watch later tonight!
Man that is hero's work!
da Ollegon
16 ago 2020, 23:31
Jump to forum
Jump to topic
Making a watch face from scratch for Amazfit GTR in the GTR_WatchFace editor by SashaCX75
Good day everyone!
Wrote a detailed article on how to make a watch face. But the article turned out to be large and written in Russian. I hope that Google Translate will handle the translation ... :)
Read here
Google Translate
I would be glad to receive comments, suggestions, criticism ...
da SashaCX75
17 dic 2019, 17:06
Jump to forum
Jump to topic
https://i.postimg.cc/PrMjngqJ/2020-09-14-19-39-23.png
Not all ...
da hikashi
31 gen 2020, 09:59
Jump to forum
Jump to topic
Complete Json Syntax Guide for GTR
This guide is meant for the py amazfit tool developed by dpeddi and co. Download the py_amazfit_tool fix array branch here: https://github.com/amazfitbip/py_amazfit_tools/tree/fix_array
Thanks dpeddi, loly and gthalpo for the continuous development on the py amazfit tool. You guys are amazing ...
da SashaCX75
29 mar 2020, 08:15
Jump to forum
Jump to topic
Re: GTR_WatchFace editor for Windows by SashaCX75
Version 7.0
Added animation support
Verge Lite Support Added
da Maikeldevil
31 mar 2020, 09:27
Jump to forum
Jump to topic
Synek ha scritto: 30 mar 2020, 20:13
Hello. I would like to change only the background of the face. How to do it quickly and easily? I don't know how to use the program.
Dude, dont be so damn lazy, just read the whole topic and try it yourself.. It easy as hell with this tool..
da Maikeldevil
01 apr 2020, 11:53
Jump to forum
Jump to topic
TOOL
1. For the people who are finding it hard to create font png's here is a tool you can use this tool:
AMAZFITFONTGENERATOR
2. For people who wants to convert images from a 47mm GTR to a 42mm GTR use this tool:
GTR47 to 42 IMAGE GENERATOR
Download here:
GTR IMAGE TOOLS
da SashaCX75
06 apr 2020, 12:18
Jump to forum
Jump to topic
Version 7.1
Italian language added.
Minor fixes.
da SashaCX75
14 apr 2020, 14:15
Jump to forum
Jump to topic
Re: Complete Json Syntax Guide for GTR
[mention]taw_bip[/mention]
At the moment, the order of drawing elements cannot be changed.
da SashaCX75
21 apr 2020, 16:32
Jump to forum
Jump to topic
Version 8.0
da SashaCX75
30 apr 2020, 16:01
Jump to forum
Jump to topic
For GTR and GTS, users have roughly determined the maximum possible size of their dials. For T-Rex and Verge Lite is no accurate data on what size dials can be installed. Therefore, for them I have set a limit as well as for the GTS 1,5MB. If someone has verified data on what maximum size of the ...
da SashaCX75
12 mag 2020, 17:38
Jump to forum
Jump to topic
Version 8.1
