Hi everyone,
All currently available watches are selectable, and it also includes special features such as animations, smooth second, circle second, etc. I haven’t come across a watch face yet that doesn’t work with it. Both short and long tabs are supported. It’s an alternative to the original ZEPP Simulator, which some users have had trouble with. It includes standard .GIF creation, where you can select the number of frames and the speed. The highlight is the screen recording feature, where you can test your watch face and, for example, execute color changes or other scripts supported by the player. I’ve posted an ONLINE VERSION at https://shorturl.at/ZDPRF for testing or in case the site operators here are interested. If there is no interest from this site, the ONLINE version will only be available for a short time so as not to unnecessarily increase my traffic.
There’s also a standalone version. There, you can create a working folder and then switch back and forth between projects in the player. You also no longer need to unzip the watch face—just use the generated .ZIP file and you’re all set.
I would have liked to attach the STANDALONE version here as well, but the limit is only 5 MB, and the tool is 10 MB. Maybe an admin could increase my upload limit; then I could even keep the package up to date here and post new updates right away.
ZeppOS Player ONLINE
Lattenknaller
- Has thanked: 60 times
- Been thanked: 135 times
- Has thanked: 422 times
- Been thanked: 2131 times
Is it possible to create a version where the ZIP file is extracted into a folder—similar to ZeppPlayer—so that the `index.js` file can be edited directly when testing watch face scripts?
