Search found 15 matches
Return
by asoo
11 Jan 2024, 22:49
Jump to forum
Jump to topic
Further update: I found some mentions on Discord about changes to QR code generation, and it seems to affect the upcoming version 10.8.5.
Some changes are coming to the way your custom QR Codes with perma links like the one put on `github` pages, are processed.
Starting from zepp app `10.8.5 ...
by asoo
09 May 2026, 03:05
Jump to forum
Jump to topic
Re: Create a QR Code and Sync to device that use zeppOS by using the Zepp app
On my Windows 11 laptop, I used Claude to code up an automation.
Setup (one time)
Install Python from python.org if you don't have it
Save zpk_to_qr.py and zpk_to_qr.bat to the same folder
Open a terminal in that folder and run:
pip install requests qrcode[pil]
Usage
Drag and drop any .zpk ...
by Maikeldevil
15 Nov 2019, 10:06
Jump to forum
Jump to topic
Making inclined dates on watchface
Due many request about how i make inclined dates, here the secret:
https://amazfitwatchfaces.com/forum/download/file.php?mode=view&id=694&sid=f4651949d356ccb3a1e9562c2245438c
Goodluck! A thank you in the post is welcome!
Greets,
Maikeldevil
Like my work or help? Buy me a coffee or help me ...
by hikashi
31 Jan 2020, 09:59
Jump to forum
Jump to topic
Complete Json Syntax Guide for GTR
This guide is meant for the py amazfit tool developed by dpeddi and co. Download the py_amazfit_tool fix array branch here: https://github.com/amazfitbip/py_amazfit_tools/tree/fix_array
Thanks dpeddi, loly and gthalpo for the continuous development on the py amazfit tool. You guys are amazing ...
by demiurg1
05 Aug 2022, 20:41
Jump to forum
Jump to topic
If I find some time, I will try to deliver BOTTA elements in black and 24 hours.
by TRK88PL
20 May 2025, 08:39
Jump to forum
Jump to topic
Re: Watchface image generator (web app tool)
Hi SashaCX75 , alright… you convinced me to make some changes, but this time it’s seriously my last update to the generator for a while.
I’ve significantly expanded the code – now there are two methods for generating angles. One is used for text shadow, gradient, and pattern, and a different one ...
by TRK88PL
04 Jun 2025, 13:44
Jump to forum
Jump to topic
Amazfit watch face generator v3
Hello guys,
this thread is a continuation of the previously created one – https://amazfitwatchfaces.com/forum/viewtopic.php?t=4649 – however, I wanted to highlight the information about the new version of the generator a bit more clearly.
Amazfit Watch Face Generator v3
This update is ...
by Lattenknaller
17 Sep 2026, 08:12
Jump to forum
Jump to topic
Re: ZeppOS Player 2
ZeppOS Player 2.3.4
Download v2.34
2.3.4 · September 17, 2026
2.3.3 · September 17, 2026
- Combined compatibility reports and live performance diagnostics in a single analysis ...
by asoo
02 Sep 2022, 06:53
Jump to forum
Jump to topic
About test create Watchface GTR4 with offical editor
Today I have used Official editor and found that now the Official editor has made it possible to create a watch face of the GTR4.
So I tried to build and test it on my GTR3. The result is that it can be enabled on the GTR3 as well, but the image size is larger than the GTR3 because the GTR4 has a ...
by kmi
12 Apr 2023, 09:47
Jump to forum
Jump to topic
Re: New GTR Mini
GTRmini users please help to test this watch face.
This watch face is made for Test converting the image to the format of GTRmini.
Anyone who has tested it, please inform the result.
thank you very much
https://i.postimg.cc/90FgCTXH/1678459821-72fa88a305.gif
G317_GTRmini.zip
This ...
by Xphyle1971
22 May 2026, 20:54
Jump to forum
Jump to topic
Re: Some one Request Watchface for Bip Max
My Bip Max device source is 11206915. Please let me know if I can give you any more information. I'm also happy to test any watch faces you create or convert to test for compatibility.
Here is a watch face to check that the images are being converted correctly
https://i.postimg.cc/SKsKNqrK ...
by Xphyle1971
24 May 2026, 15:23
Jump to forum
Jump to topic
@Xphyle1971
Thank you. That’s exactly what I needed. It’s odd, though, that the border isn’t visible around the edges of the screen on the test dial. I’ve tweaked the test dial a little. You need to use the ‘Padding’ setting to make the border visible around the screen, and then adjust the corner ...
by YsPan
21 Apr 2026, 10:56
Jump to forum
Jump to topic
Re: I make a tool to push the zpk format watchface into official simulator, but have little problems(Fixed)
I find out the package exported by the SashaCX75's WatchFace editor, can push into the simulator with little modification:
Edit: I added the flow into the C#'s version of the program, just open the exported watchface package like the zpk!
(Steps 1~2 can see the instruction in this README https ...
by asoo
01 Sep 2026, 02:42
Jump to forum
Jump to topic
Re: Number of week Amazfit active 3 premium
Hi
Do you know about some watchface with number of week ? For example wk36
You could check out Drakowed's watch faces:
https://amazfitwatchfaces.com/search/gtr/authorID/474447
His 480x480 (GTR3pro) watch faces include several with
"Number of week" and "Day of year" which should work ...
