Hi everyone,
We would like to let you know that very soon we will begin migrating AmazfitWatchFaces to a new server.
This is a major infrastructure upgrade that will involve moving the website, forum, databases, and related services to a new environment. The new server will use a modern software ...
搜索找到 26 个匹配
- 13 7月 2026, 19:39
- Jump to forum
- Jump to topic
Re: Upcoming server migration and temporary service interruption
Update: The main maintenance work has been completed and the website is back online. However, we will continue working on the server and infrastructure over the next few days, so some temporary issues may still occur.
If you notice any errors, unusual behavior, or other problems with the website ...
- 18 3月 2026, 09:21
- Jump to forum
- Jump to topic
- 07 1月 2022, 14:16
- Jump to forum
- Jump to topic
- Amazfit Bip 5 ...
- Amazfit Bip 5 ...
- 29 6月 2025, 17:37
- Jump to forum
- Jump to topic
Because there isn't enough time for everything
- 14 7月 2025, 19:00
- Jump to forum
- Jump to topic
Version 14.1
Mirror
Fixed issues with the circular scale on some widgets.
Added support for Active 2 (Square).
Mirror
- 15 7月 2025, 16:35
- Jump to forum
- Jump to topic
@frankh93
Try prop.Y or prop.POS_X.
Also, if you use prop.MORE, for some widgets you need to change all parameters at once, not just the coordinates.
- 22 7月 2025, 17:18
- Jump to forum
- Jump to topic
@frankh93
That means you're doing something wrong. Based on your description of the problem, this is the only answer I can give you.
- 23 7月 2025, 04:35
- Jump to forum
- Jump to topic
frankh93
I don't know how to do it. Only to create a new project and copy all the code into it.
There is an unofficial editor. But the project is abandoned and not all widgets work in it.
You can take screenshots of the clock screen and then compile them into a gif ...
- 23 7月 2025, 04:35
- Jump to forum
- Jump to topic
frankh93
- 07 8月 2025, 08:39
- Jump to forum
- Jump to topic
@frankh93
An example of vibration can be seen if you set a switchable background.
- 11 8月 2025, 17:10
- Jump to forum
- Jump to topic
@frankh93
You need pause_call from WIDGET_DELEGATE.
https://docs.zepp.com/docs/watchface/ap ... de-example
- 22 12月 2025, 00:21
- Jump to forum
- Jump to topic
Yes, with the progress bar, I do have to look at the numbers to reach 100% before setting the progress bar in the battery 🔋 icon, with your editor.
I think you mean to get the progressbar in the right position and size you want right? if so you can open the "data for preview" tab and under ...
- 27 12月 2025, 18:30
- Jump to forum
- Jump to topic
Version 16.0
Sleep widget added.
Text widgets added (display of custom text).
Sleep widget added.
- 26 2月 2026, 17:46
- Jump to forum
- Jump to topic
Version 16.1
I will post the archive ...
- 22 4月 2026, 14:51
- Jump to forum
- Jump to topic
Version 17.0
- 29 5月 2026, 06:00
- Jump to forum
- Jump to topic
No. This is a closed-beta version.
- 15 6月 2026, 19:11
- Jump to forum
- Jump to topic
Added the ability to record the ...
- 17 6月 2026, 20:12
- Jump to forum
- Jump to topic
GoogleDrive
Dropbox
GoogleDrive
Dropbox
GoogleDrive
Dropbox
GoogleDrive
Dropbox
- 10 9月 2026, 12:02
- Jump to forum
- Jump to topic
Re: ZeppOS Player ONLINE
I would have liked to attach the STANDALONE version here as well, but the limit is only 5 MB, and the tool is 10 MB. Maybe an admin could increase my upload limit; then I could even keep the package up to date here and post new updates right away.
Unfortunately, we can't increase the attachment ...
- 11 9月 2026, 11:33
- Jump to forum
- Jump to topic
New Version ONLINE 2.8.17
- Fixed a bug where the digital time display was offset by a few pixels.
- BIP5 and similar older watch faces are now recognized and displayed correctly.
- Option to test the watch face with the original watch border (Skins imported from Sasha's Editor)
- Option to create ...
- 26 7月 2025, 01:03
- Jump to forum
- Jump to topic
Re: Unpack Bip 6 Watchfaces
I got to know about mmk site where I can download the zip file of a certain watchface I wanna mod (https://mmk.pw/en/zepp_explorer/explorer/watch) but when I tried to unpack it using Sasha's tool it says I wasn't able to cause it is encrypted, so I wanna ask... There is another way to do this ...
- 06 9月 2025, 12:31
- Jump to forum
- Jump to topic
Re: Get text/size/anything from the weather element
If I understand your explanation correctly, you want to create a color-changing dial. You'll use the transparent image property to create a dial that changes all the text colors. However, you're having trouble with the uneven image sizes, which can lead to uncovered spaces.
In this section, I used ...
- 07 9月 2025, 09:01
- Jump to forum
- Jump to topic
Use the sensor to obtain the value of the displayed parameter (e.g., heart rate). Knowing the value, you can find out how many digits it has and calculate its size.
- 21 11月 2025, 00:44
- Jump to forum
- Jump to topic
Re: Trying to get color in AOD
So I've been trying to make a modification to my "Dotted Clock" watchface (https://amazfitwatchfaces.com/bip/view/43990) where the choosen color gets applied to the AOD too. I have tried to add an IMG widget only showed in AOD and changing its source together with the BG for the normal watchface ...
