Preview
Youtube how to use zepp app
ZPK
Download Program
Before use Please install winrar or 7zip firstWinRAR :
7zip:
ืNote :
Or you can use
permanent :
catbox.moe
storage time limit :
litterbox.catbox.moe
to upload the file
Codice: Seleziona tutto
https://xxxx.com/watchface/xxxx.zpkCodice: Seleziona tutto
zpkd1://xxxx.com/watchface/xxxx.zpkTo create a QR code, you can use the program zint to do it.
Note:
( By taw_bip )
viewtopic.php?p=22191#p22191
viewtopic.php?p=22231#p22231
Developer Mode ( 24-08-2025 )
or see this clip
- select General
- select Developer Mode
- select SCAN
My Note :
