Been thanked: 2122 times
June 17, 2026
Preview
============ if update Zepp to version 10.8.1+.
Now cannot be installed via this method. A fix is ​​expected to be implemented soon. =============
Youtube how to use zepp app
Note :
ZPK
Download Program
CreateZPK+2.zip
(48.39 KiB) Downloaded 1467 times
WinRAR :
7zip:
ืNote :
CreateZPK.zip
(90.62 KiB) Downloaded 1422 times
Or you can use
permanent :
catbox.moe
storage time limit :
litterbox.catbox.moe
to upload the file
Let's edit it to
Note:
QRCoder+zpkd1-link1.1.zip
(217.3 KiB) Downloaded 659 times
( By taw_bip )
viewtopic.php?p=22191#p22191
viewtopic.php?p=22231#p22231
Developer Mode ( 24-08-2025 )
or see this clip
- select General
- select Developer Mode
- select SCAN
My Note :
Has thanked: 1162 times
Been thanked: 279 times
mbmuch wrote: 04 Mar 2026, 09:57
How can I attach my zip file here?
I'm lost.
What's wrong?
What can I do?
Cheers
Your problem is likely due to you naming your files using non-English characters.
This causes an error when syncing.
Change the characters to English, and you should be able to sync normally.
This is a modified sample file.
(305.42 KiB) Downloaded 296 times
This is a QR code for testing the installation.
QR Code for Synce
This QR use for proof , after rename with english charleter it can sync normally
Note:
This QR code links to Catbox. At certain times, if there are many users, the installation may be slow or may not work. Please try again later.
if you user "Watch face editor for Amazfit watch on ZeppOS" for create your watch face , I recommend you to update to Version 16.1 viewtopic.php?p=21837#p21837
Because this version when you pack watchface the program will be checks file names, and if it encounters any problems with the file name, the program will display a popup notification to you.
mbmuch
Post by mbmuch »
Man, you safed my day !!!
That's great, thank you very much!
Cheers mate :-)
Has thanked: 130 times
Been thanked: 19 times
Post by taw_bip »
On my Windows 11 laptop, I used Claude to code up an automation.
Setup (one time)
Install Python from python.org if you don't have it
Save zpk_to_qr.py and zpk_to_qr.bat to the same folder
Open a terminal in that folder and run:
pip install requests qrcode[pil]
Usage
Drag and drop any .zpk file onto zpk_to_qr.bat. It'll upload the file to catbox.moe and open a QR image you can scan directly in the Zepp app to install the watchface.
zpk_to_qr.zip
(1.38 KiB) Downloaded 236 times
taw_bip wrote: 08 May 2026, 18:00
Setup (one time)
Usage
This is a useful tool.
However, users need to understand that the files are hosted on catbox's server, and sometimes, if there are many users, uploading and downloading may encounter issues. Therefore, when using this tool, you may need to consider the readiness of catbox as well.
I have created standalone ".exe" file from pyinstaller (zpk_to_qr.py) for those who do not want to install Python, by use original code from owner , So the code and content remain the same as the original.
zpk_to_qr.rar
(15.1 MiB) Downloaded 224 times
The usage method remains the same as the original.
You can use the command line or drag and drop the .zpk file onto the .exe file.
This file contains minor code modifications for use with litterbox,
which is catbox's non-permanent file hosting service, with file retention set for 1 hour.
zpk_to_QR_litterBox1h.rar
(15.1 MiB) Downloaded 234 times
Ideal for those who want to test dials and don't need to store them permanently.
Note:
In the future, if Catbox changes its API UPLOD, attached files may no longer work. And I will not modifications will be made if this occurs.
asoo wrote: 09 May 2026, 03:05
Thank you. For my purposes, using littlebox is a better option.
Have you tried changing the file retention period? Setting a time other than 1 hour?
SashaCX75 wrote: 11 May 2026, 16:49
As far as I can check, `litter` has 4 values ​​for `time`:
"1h"
"12h"
"24h"
"72h"
I've made two for my own use, 1h and 24h.
I haven't tested the other time values ​​yet.
Litterbox 24h :
zpk_to_QR_litterBo24h.rar
(15.1 MiB) Downloaded 222 times
I've created a GUI to help upload to LitterBox and CatBox, and generated and displayed a QR code with a URL for user convenience.
I won't be making any further modifications. I've attached the code in Python; feel free to modify it if you wish.
This code uses the following libraries:
requests
qrcode
Pillow
Tkinter (included with most Python packages)
I've included a standalone executable (.exe) in the pack for those who don't want to install Python.
However, this program may not work immediately if CatBox changes its upload API.
If that happens, I will not take any further action.
gui_C_L.rar
(11.3 MiB) Downloaded 215 times
Update Version 1.2 ( Change layout and some function )
gui_C_L_G_V1.2.rar
(11.3 MiB) Downloaded 221 times
The original code about upload is from taw_bip:
asoo wrote: 12 May 2026, 04:56
I'm currently working on adding this function to the editor. I created a version of this function in C#, but it turned out to be a bit more complicated than I expected. The site's security system flagged me as a bot and returned an error regarding the link. However, I will only support LitterBox.
I can't fully test the version you posted. I have all the necessary dependencies installed, so your version should work without any issues. However, I'm not sure it will work for people who have never installed Python before. In any case, when I ran the first version of this utility on Python, it refused to work. It seems it was missing the “qrcode” library.
SashaCX75 wrote: 12 May 2026, 14:08
This is good news for those who are using your watchface editor.
For all the .exe files I've created to standalone, I've tested them on machines that have never had Python installed, and they work fine (I included the necessary libraries during the .exe creation process).
However, for .py files, if who want to use them via Python, you will need to install additional libraries:
</> CMD
pip install requests qrcode pillow
I still don't want to use Python code in my editor because the rest of the code is written in C#. Although I did manage to create a working function. But if anyone has any ideas on how to improve this, I'd appreciate the help.
Post by taw_bip »
requests
qrcode
Pillow
gui_C_L.rar
gui_C_L_G_V1.2.rar
That's great. In the meantime, I adjusted mine to do the conversion from .zip to .zpk then perform the upload and QR code generation. I think if it gets integrated into the editor that would be amazing.
Actually, this feature is already available in the editor. I’m just finishing off the styling, testing it, and creating the necessary files.
From my previous post:
viewtopic.php?p=22210#p22210
I've improved the app. You can now select catbox and littlebox, and use Filepost.dev for file uploads and to generate a QR code for installation.
I'd like to thank SashaCX75 for the information on filepost.dev.
If you want to use filepost.dev, you need to register as a member first to receive an API Key for uploading files.
The files you upload will never expire, and you can manage them through filepost.dev.
FilePost.DEV
Download and Preview
ZPK-Tool-Upload_V2.3.rar
(13.78 MiB) Downloaded 229 times
Update : if use filepost program will be check for the key field; a warning will appear if it's empty.
However, this program may not work immediately if CatBox and or Filepost changes its upload API.
Hopefully, this is another option before SashaCX75's new editor is released.
(This feature is already available in the beta version of the Watch face editor for Amazfit watches on ZeppOS.)
wjj1
Post by wjj1 »
I'm unable to load any watchface using the zepp app and scanning the QR code.
Downloading xxxx.zip from amazfitwatchfaces.com, this is what I do:
1. rename xxxx.zip to xxxx.zpk
2. upload xxxx.zpk to litterbox
3. copy the url from litterbox yyyy.zpk
4. rename the url to zpkd1 yyyy.zpk
5. create the QR code for the url
6. scan the QR code on the zepp app
I always get a "Parse mini program package failed" message.
Loading official watchfaces from the zepp app on the phone works fine.
I suspect that the format of the files in the zpk files is now slightly different for Zepp App,
either app.js or watchface/index.js.
Thanks for any help or ideas.
Jeff
wjj1 wrote: 30 Jul 2026, 14:12
Jeff
1. Why don't you install via the QR code on amazfitwatchface.com :?: :?:
If you only want to install the watch face, you can click the QR icon after the file name to install it directly. No need to waste time downloading the .zip file for built QR Code
2. Converting a zip file to a zpk isn't just about renaming; you also need to format it according to the requirements. Or you can use a utility to convert zip to zpk.
The program is called CreateZPK+2. You can find it in the first post; it was recommended there.
If you created the zpk file correctly, successfully uploaded it, and generated the QR code correctly,
I'm sure you can install it via the Zepp app.
wjj1
Post by wjj1 »
Oh, I see the little QR code button now. But no luck using the QR code on amazfitwatchface.com. Installs with no errors but no watchface shows up.
I can't use CreateZPK+2 because I'm on linux. CreateZPK appears to be a .NET/windows app. If there was source code and it's small enough I could possibly script an alternative for linux.
I'm also working on my own watchface, so I'd like to be able to create an appropriate zpk.
Thanks for answering so quickly.
wjj1
Post by wjj1 »
quick update -- the QR code method on amazfitwatchface.com doesn't show up in the zepp app on my android phone, but the watchface does display and work on my watch.
wjj1 wrote: 30 Jul 2026, 20:27
That's expected behavior.
The Zepp app only displays watch faces that were installed from the official Zepp Store.
Watch faces installed through Developer Mode (such as via the QR code on AmazfitWatchFaces.com) are installed directly on the watch, so they won't appear in the Zepp app's watch face list. However, they will continue to work normally on the watch itself.
So if the watch face is installed and working on your watch, everything is functioning as expected.
wjj1
Post by wjj1 »
I saw a screenshot from the zepp developer that showed the watchface displayed in the zepp app itself, so I was confused.
https://docs.zepp.com/docs/1.0/guides/t ... /scanCode/
Now on to getting my own developed watchface synced to the watch so I can test it. Linux only so I have to find out the exact format for a ZPK file. This is not the topic to ask about that.
Thank you very much.
@wjj1
You can open a ZPK file as a standard ZIP archive and view its structure.
The source code for the CreateZPK utility.
https://github.com/SashaCX75/CreateZPK_2
wjj1
Post by wjj1 »
@SashaCX75 THANK YOU!!!!!!!!!!
