https://discord.com/channels/1202787457 ... 7592805396Discord wrote:Some changes are coming to the way your custom QR Codes with perma links like the one put on `github` pages, are processed.
Starting from zepp app `10.8.5` when generating QR Codes from custom tools like `QRCoder` or manually assembling a QR, you will have to make sure that your QR Code is built in `preview` mode, not production. If you don't know how to do it, or can't recompile the old watch face, you should be able to modify this value inside the `app.json` of the said watch face archive.
```json```Code: Select all
"packageInfo":{"mode":"production",
has to be
"packageInfo":{"mode":"preview",
Also, you will have to use the
protocol for your watch faces. Not theCode: Select all
watchface://.../..
which is used for the mini apps.Code: Select all
zpkd1://.../...zpk
If you do not follow the protocol correctly, you will see the `"Only preview packages are supported"` message, which some of you have encountered in zepp app `10.8.0`.
I'm not sure if this issue will affect older QR codes.
Just sharing this information.
21-09-2026Discord (𝗦𝗶𝗹𝘃𝗲𝗿) wrote:I have confirmed that starting from `10.8.5` the direct links should be handled the same way as before, and you don't have to follow our official protocol to a T. Also, the `preview` / `production` flag will be ignored when using the direct link, so you don't have to bother with it.
Now, Update to 10.8.6 it still can use QR-Code Normally
Preview
Youtube how to use zepp app
ZPK
Download Program
Before use Please install winrar or 7zip firstWinRAR :
7zip:
ืNote :
Or you can use
permanent :
catbox.moe
storage time limit :
litterbox.catbox.moe
to upload the file
https://xxxx.com/watchface/xxxx.zpkCode: Select all
zpkd1://xxxx.com/watchface/xxxx.zpkTo create a QR code, you can use the program zint to do it.
Note:
( By taw_bip )
viewtopic.php?p=22191#p22191
viewtopic.php?p=22231#p22231
Developer Mode ( 24-08-2025 )
or see this clip
- select General
- select Developer Mode
- select SCAN
My Note :
