Been thanked: 1044 times
v18.1
Version 18.1
allsopsmr
Post by allsopsmr »
Howdy. I've tried creating a custom watch face for my GTR 3, using Version 16.1 of Watch Face Editor. It's based on the Zepp Health watch face 'Keep it secret'.
Although the watch face looks fine in the tool and in the preview, on the actual watch it is missing the numbers from the dials. (Day and date show up fine, though.)
I've published the watch face here: https://amazfitwatchfaces.com/gtr/view/45004
Any help or advice would be appreciated.
Thanks! :)
Has thanked: 436 times
Been thanked: 2137 times
allsopsmr wrote: 11 Jun 2026, 11:34
Thanks! :)
If you're using a GTR3 and encountering issues where the numbers aren't displaying, and you're using a TTF file, First when you installed that watch face, I recommend resetting the watch.
After If the numbers still don't display after resetting, it could be due to the following:
1. The TTF file you're using might not be a true TTF file; it could be an OTF file.
2. Some GTR3 widgets cannot use TTF or system fonts for display, even if they display correctly in the preview. They won't display correctly on the GTR3.
If you're using a GTR3, I recommend converting those numbers to a PNG image and using
"Numerical values" to display the widget.
You can use the Amazfit watch face generator to convert the text to an image:
or
If you are not using TTF and are experiencing this issue, we recommend attaching your project file to your post.
The watch face works on other models. The GTR3 cannot display this data using a font, so a set of images must be used instead.
Please note that the watch face preview is incorrect. The watch face contains many images that are not used.
allsopsmr
Post by allsopsmr »
Okay, so I need to add the numbers as images and use 'Numerical values' to display them. I will work to do that and then re-upload once I'm done.
I did not grasp Sasha's second point at all. :D Oh, do you mean the images in the sub-folders? They are from the original 'Keep it secret' watch face, I guess I'll remove them.
Thanks! :)
allsopsmr
Post by allsopsmr »
Success!! Thanks!
allsopsmr wrote: 12 Jun 2026, 13:25
Thanks! :)
Yes, I was talking about the images in the subfolders. And about the preview that appears when you change the watch faces.
Superwitschi
Has thanked: 8 times
Post by Superwitschi »
Does the editor also work for Balance 2 XT?
Archive
Installer
sadc
Post by sadc »
Hi Sasha, great work with Version 18, thanks again!!!
May I suggest a little "option" for one of your next releases?
In
Weather forecast - general settings
can you add a "skip day 0" option, so to start from "tomorrow" forecast in first place and not showing "today" weather?
I usually edit my index.js files from this:
              for (let i = 0; i < 3; i++) {
                normal_forecast_date_week_img[i] = normal_group_ForecastWeather.createWidget(hmUI.widget.IMG, {
                  x: 0 + i*66,
                  y: 64,
                  src: normal_forecast_date_week_img_array[0],
                normal_forecast_date_week_img[i].setAlpha(180);
to this:
              for (let i = 1; i < 4; i++) {
                  x: 0-66 + i*66,
                  y: 64,
To get a 3 days forecast starting from "tomorrow"
Guydu91
Has thanked: 59 times
Post by Guydu91 »
sadc wrote: 18 Jun 2026, 18:21
In
                  x: 0 + i*66,
                  y: 64,
to this:
                  x: 0-66 + i*66,
                  y: 64,
I think there's a simpler way to display the weather forecast starting from "tomorrow" than entering code.
You can simply create a 4-day (or possibly 5-day) forecast and move the first day to the outside of the screen (to the left).
That's what I did on this watch face for the Bip6 and GTS4:
https://amazfitwatchfaces.com/bip/view/43900
https://amazfitwatchfaces.com/gts/view/12180
Good luck.
Guydu91 wrote: 22 Jun 2026, 21:13
That’s not quite right. Your design is such that the forecast starts at the edge of the screen. So you can move the first day off-screen. But the design doesn’t always allow you to do that. And in that case, you’ll need to edit the code.
EXneko
Post by EXneko »
Which version should I use to make watch faces for the Amazfit Band 5 NFC edition?
EXneko wrote: 25 Jun 2026, 16:44
Probably none at all
sadc
Post by sadc »
Guys l've just left a 5 star rating in the Microsoft Store page, let's give some credit to the great work of Sasha!
Here it is the link, then you have to open the store to give your rating ;-)
https://apps.microsoft.com/detail/xp89mr7pjvt9q9
Has thanked: 132 times
Been thanked: 21 times
Post by taw_bip »
sadc wrote: 18 Jul 2026, 08:35
Or how about this:
"You can thank me for my work by paying for a beer at https://www.buymeacoffee.com/sashacx75
or by transferring money to PayPal: [email protected]"
sadc
Post by sadc »
taw_bip wrote: 18 Jul 2026, 14:03
Or how about this:
Already done ;-)
hoangkuty12345
Post by hoangkuty12345 »
 //day
        function UpdateBackgroundOne(){
        normal_distance_text_text_img.setProperty(hmUI.prop.VISIBLE, false);
        normal_distance_text_separator_img.setProperty(hmUI.prop.VISIBLE, false);
        normal_calorie_current_text_img.setProperty(hmUI.prop.VISIBLE, false);
        normal_calorie_current_separator_img.setProperty(hmUI.prop.VISIBLE, false);
        normal_step_current_text_img.setProperty(hmUI.prop.VISIBLE, false);
        normal_step_current_separator_img.setProperty(hmUI.prop.VISIBLE, false);
	normal_day_text_text_img.setProperty(hmUI.prop.VISIBLE, true);
        normal_day_text_separator_img.setProperty(hmUI.prop.VISIBLE, true);
        normal_hearth_current_text_img.setProperty(hmUI.prop.VISIBLE, false);
        normal_heart_current_separator_img.setProperty(hmUI.prop.VISIBLE, false);
        normal_weather_text_text_img.setProperty(hmUI.prop.VISIBLE, false);
        normal_heart_rate_text_text_img.setProperty(hmUI.prop.VISIBLE, false);
	normal_heart_rate_separator_img.setProperty(hmUI.prop.VISIBLE, false);
	normal_weather_temperature_text_img.setProperty(hmUI.prop.VISIBLE, false)
        normal_battery_text_text_img.setProperty(hmUI.prop.VISIBLE, false);
        normal_battery_text_separator_img.setProperty(hmUI.prop.VISIBLE, false);
        normal_step_jumpable_img_click.setProperty(hmUI.prop.VISIBLE, true);
        normal_pai_jumpable_img_click.setProperty(hmUI.prop.VISIBLE, false);
Can someone help me? I wrote the code like this, but it doesn't hide the date when I switch to another mode.
user_functions.js
(13.12 KiB) Downloaded 51 times
hoangkuty12345 wrote: 19 Jul 2026, 04:51
code
 //day
Your script, in summary, controls the opening and closing of widgets using the following functions:
UpdateBackgroundOne, UpdateBackgroundTwo, up to UpdateBackgroundSeven
All functions execute through the `click_Background()` function.
Your attached code has a logical structure that works as intended, but there is one syntax error (JavaScript syntax) and some spelling mistakes in variable names, which may cause errors or incorrect display.
Below is a summary of the points that need to be corrected to ensure correct functionality:
🔍 Points to Fix (Bug & Syntax Check)
1. Syntax Error (Missing Semicolon):
In the functions UpdateBackgroundOne, UpdateBackgroundTwo, up to UpdateBackgroundSeven, there is a line that is missing a ";"
Example: `normal_weather_temperature_text_img.setProperty(hmUI.prop.VISIBLE, false)`
Solution: Add a semicolon at the end to prevent the system from misinterpreting the following line of code.
It's not critical, but in some cases it might cause processing to stop.
2. Variable names are misspelled (risk of app crashes/no display):
The UpdateBackgroundOne function uses the variables normal_hearth_current_text_img and normal_heart_current_separator_img (both with and without 'h'), and have other functions use normal_heart_rate_text_text_img.
I'm not sure what the exact name of the widget you're looking for is, as there seem to be different widget names within the Heart's widget. And if you use ".setProperty(hmUI.prop.VISIBLE, false);" with a non-existent widget, it might cause your script to break.
The UpdateBackgroundSix function uses the variable normal_weather_image_text_img, but other functions don't clear this variable to false (if you loop back, the screen might display overlapping images).
Based on the script you attached, this is roughly the summary.
If you want someone to check this issue, we recommend sending the entire project so they can pinpoint the problem more effectively.
And I suggest starting a new topic if your question doesn't align with the main topic.
I think your question should be addressed in a new topic to avoid confusion with the main topic.
Laurienzu
Post by Laurienzu »
Hello guys, I was wondering if there is any way to add kiezel pay to my watchface using this program. Thank you in advance!
awrun
Post by awrun »
Hi!
I have a problem with the editor.
All buttons working, just the "Music on phone" works not on Bip Max.
The watchface I uploaded (2026.07.23) is the "Oreg Szemnek 03 CC".
When I tap on the orange text near the weather picture, the music controller should be starting, but it not works.
Is it possible to fix this?
awrun wrote: 23 Jul 2026, 18:44
Hi!
If you are using BipMax and want to open "music on phone,"
change to use function "music (on phone)*" marked with an asterisk (*)
in the settings button.
Preview
awrun
Post by awrun »
Thank You Asoo!
It works :)
sadc
Post by sadc »
Missing elements in AOD
Hi there, I have a problem with my project: some elements that should be visible in AOD (at least, they are visible in wathc face editor), are missing when the project runs on my Balance 2
I'm struggling to find the solution, for sure I'm doing something stupid on my side :lol:
As from the below pictures, digital time, date and battery + bpm values are not shown on the watch :shock:
EDIT 1: rebooting the watch didn't solve the problem (third party fonts involved)
EDIT 2: something wrong with my JS, if disabled the AOD works correctly
images
sadc
Post by sadc »
I've found... This code in "user_script_end.js" makes the AOD screen "unhappy"
for (let i = 0; i < 4; i++) {
	normal_forecast_low_text_font[i].setProperty(hmUI.prop.VISIBLE, false);
	normal_forecast_high_text_font[i].setProperty(hmUI.prop.VISIBLE, true);
	normal_forecast_average_text_font[i].setProperty(hmUI.prop.VISIBLE, false);
Users browsing this forum: Google Adsense [Bot], Jcvictor and 7 guests
