Search found 6 matches
Return
by SashaCX75
17 Mar 2026, 15:51
Jump to forum
Jump to topic
sadc wrote: 17 Mar 2026, 10:42
Thanks Sasha fro your great work!
Do you plan to add the "inversion" option to the Circle progress bar in BioCharge?
No. That’s not possible at the moment.
by SashaCX75
18 Mar 2026, 16:08
Jump to forum
Jump to topic
sadc wrote: 18 Mar 2026, 12:41
Hi Sasha,
I've found a little error in the Italian translation.
When selecting the days of week via font, the program puts the following string in the name of week field:
Lu,Ma,Me,Gi;Ve,Sa,Do
There is a ";" instead of "," between "Gi" and "Ve"
I'll fix it.
by Guydu91
22 Jun 2026, 21:13
Jump to forum
Jump to topic
Hi Sasha, great work with Version 18, thanks again!!!
May I suggest a little "option" for one of your next releases?
In Weather forecast - general settings can you add a "skip day 0" option, so to start from "tomorrow" forecast in first place and not showing "today" weather?
I usually edit my ...
by SashaCX75
23 Jun 2026, 09:45
Jump to forum
Jump to topic
You can simply create a 4-day (or possibly 5-day) forecast and move the first day to the outside of the screen (to the left).
That’s not quite right. Your design is such that the forecast starts at the edge of the screen. So you can move the first day off-screen. But the design doesn’t always ...
by SashaCX75
31 Jul 2026, 12:23
Jump to forum
Jump to topic
@sadc
In AOD mode, there are no elements on the main screen. Consequently, the code attempts to modify a non-existent element, which causes an error. You need to add a check for the screen type.
This code doesn’t make sense. It will change the same elements three times.
by SashaCX75
10 Sep 2026, 17:11
Jump to forum
Jump to topic
Version 18.1
Archive
Installer
