Been thanked: 1029 times
allsopsmr
Post by allsopsmr »
Howdy. I've tried creating a custom watch face for my GTR 3, using Version 16.1 of Watch Face Editor. It's based on the Zepp Health watch face 'Keep it secret'.
Although the watch face looks fine in the tool and in the preview, on the actual watch it is missing the numbers from the dials. (Day and date show up fine, though.)
I've published the watch face here: https://amazfitwatchfaces.com/gtr/view/45004
Any help or advice would be appreciated.
Thanks! :)
Has thanked: 414 times
Been thanked: 2070 times
allsopsmr wrote: 11 Jun 2026, 11:34
Thanks! :)
If you're using a GTR3 and encountering issues where the numbers aren't displaying, and you're using a TTF file, First when you installed that watch face, I recommend resetting the watch.
After If the numbers still don't display after resetting, it could be due to the following:
1. The TTF file you're using might not be a true TTF file; it could be an OTF file.
2. Some GTR3 widgets cannot use TTF or system fonts for display, even if they display correctly in the preview. They won't display correctly on the GTR3.
If you're using a GTR3, I recommend converting those numbers to a PNG image and using
"Numerical values" to display the widget.
You can use the Amazfit watch face generator to convert the text to an image:
or
If you are not using TTF and are experiencing this issue, we recommend attaching your project file to your post.
The watch face works on other models. The GTR3 cannot display this data using a font, so a set of images must be used instead.
Please note that the watch face preview is incorrect. The watch face contains many images that are not used.
allsopsmr
Post by allsopsmr »
Okay, so I need to add the numbers as images and use 'Numerical values' to display them. I will work to do that and then re-upload once I'm done.
I did not grasp Sasha's second point at all. :D Oh, do you mean the images in the sub-folders? They are from the original 'Keep it secret' watch face, I guess I'll remove them.
Thanks! :)
allsopsmr
Post by allsopsmr »
Success!! Thanks!
allsopsmr wrote: 12 Jun 2026, 13:25
Thanks! :)
Yes, I was talking about the images in the subfolders. And about the preview that appears when you change the watch faces.
Superwitschi
Has thanked: 8 times
Post by Superwitschi »
Does the editor also work for Balance 2 XT?
Archive
Installer
sadc
Post by sadc »
Hi Sasha, great work with Version 18, thanks again!!!
May I suggest a little "option" for one of your next releases?
In
Weather forecast - general settings
can you add a "skip day 0" option, so to start from "tomorrow" forecast in first place and not showing "today" weather?
I usually edit my index.js files from this:
              for (let i = 0; i < 3; i++) {
                normal_forecast_date_week_img[i] = normal_group_ForecastWeather.createWidget(hmUI.widget.IMG, {
                  x: 0 + i*66,
                  y: 64,
                  src: normal_forecast_date_week_img_array[0],
                normal_forecast_date_week_img[i].setAlpha(180);
to this:
              for (let i = 1; i < 4; i++) {
                  x: 0-66 + i*66,
                  y: 64,
To get a 3 days forecast starting from "tomorrow"
Guydu91
Has thanked: 55 times
Post by Guydu91 »
sadc wrote: 18 Jun 2026, 18:21
In
                  x: 0 + i*66,
                  y: 64,
to this:
                  x: 0-66 + i*66,
                  y: 64,
I think there's a simpler way to display the weather forecast starting from "tomorrow" than entering code.
You can simply create a 4-day (or possibly 5-day) forecast and move the first day to the outside of the screen (to the left).
That's what I did on this watch face for the Bip6 and GTS4:
https://amazfitwatchfaces.com/bip/view/43900
https://amazfitwatchfaces.com/gts/view/12180
Good luck.
Guydu91 wrote: 22 Jun 2026, 21:13
That’s not quite right. Your design is such that the forecast starts at the edge of the screen. So you can move the first day off-screen. But the design doesn’t always allow you to do that. And in that case, you’ll need to edit the code.
EXneko
Post by EXneko »
Which version should I use to make watch faces for the Amazfit Band 5 NFC edition?
EXneko wrote: 25 Jun 2026, 16:44
Probably none at all
sadc
Post by sadc »
Guys l've just left a 5 star rating in the Microsoft Store page, let's give some credit to the great work of Sasha!
Here it is the link, then you have to open the store to give your rating ;-)
https://apps.microsoft.com/detail/xp89mr7pjvt9q9
Has thanked: 128 times
Been thanked: 19 times
Post by taw_bip »
sadc wrote: Today, 08:35
Or how about this:
"You can thank me for my work by paying for a beer at https://www.buymeacoffee.com/sashacx75
or by transferring money to PayPal: [email protected]"
