Been thanked: 1029 times
Messaggio da SashaCX75 »
allsopsmr
Messaggio da allsopsmr »
Howdy. I've tried creating a custom watch face for my GTR 3, using Version 16.1 of Watch Face Editor. It's based on the Zepp Health watch face 'Keep it secret'.
Although the watch face looks fine in the tool and in the preview, on the actual watch it is missing the numbers from the dials. (Day and date show up fine, though.)
I've published the watch face here: https://amazfitwatchfaces.com/gtr/view/45004
Any help or advice would be appreciated.
Thanks! :)
Has thanked: 411 times
Been thanked: 2046 times
Messaggio da asoo »
allsopsmr ha scritto: 11 giu 2026, 11:34
Thanks! :)
If you're using a GTR3 and encountering issues where the numbers aren't displaying, and you're using a TTF file, First when you installed that watch face, I recommend resetting the watch.
After If the numbers still don't display after resetting, it could be due to the following:
1. The TTF file you're using might not be a true TTF file; it could be an OTF file.
2. Some GTR3 widgets cannot use TTF or system fonts for display, even if they display correctly in the preview. They won't display correctly on the GTR3.
If you're using a GTR3, I recommend converting those numbers to a PNG image and using
"Numerical values" to display the widget.
You can use the Amazfit watch face generator to convert the text to an image:
or
If you are not using TTF and are experiencing this issue, we recommend attaching your project file to your post.
The watch face works on other models. The GTR3 cannot display this data using a font, so a set of images must be used instead.
Please note that the watch face preview is incorrect. The watch face contains many images that are not used.
allsopsmr
Okay, so I need to add the numbers as images and use 'Numerical values' to display them. I will work to do that and then re-upload once I'm done.
I did not grasp Sasha's second point at all. :D Oh, do you mean the images in the sub-folders? They are from the original 'Keep it secret' watch face, I guess I'll remove them.
Thanks! :)
allsopsmr
Success!! Thanks!
allsopsmr ha scritto: 12 giu 2026, 13:25
Thanks! :)
Yes, I was talking about the images in the subfolders. And about the preview that appears when you change the watch faces.
Superwitschi
Has thanked: 8 times
Messaggio da Superwitschi »
Does the editor also work for Balance 2 XT?
Archive
Installer
sadc
Messaggio da sadc »
Hi Sasha, great work with Version 18, thanks again!!!
May I suggest a little "option" for one of your next releases?
In
Weather forecast - general settings
can you add a "skip day 0" option, so to start from "tomorrow" forecast in first place and not showing "today" weather?
I usually edit my index.js files from this:
Codice: Seleziona tutto
              for (let i = 0; i < 3; i++) {
                normal_forecast_date_week_img[i] = normal_group_ForecastWeather.createWidget(hmUI.widget.IMG, {
                  x: 0 + i*66,
                  y: 64,
                  src: normal_forecast_date_week_img_array[0],
                normal_forecast_date_week_img[i].setAlpha(180);
to this:
              for (let i = 1; i < 4; i++) {
                  x: 0-66 + i*66,
                  y: 64,
To get a 3 days forecast starting from "tomorrow"
Guydu91
Has thanked: 55 times
Messaggio da Guydu91 »
sadc ha scritto: 18 giu 2026, 18:21
In
                  x: 0 + i*66,
                  y: 64,
to this:
                  x: 0-66 + i*66,
                  y: 64,
I think there's a simpler way to display the weather forecast starting from "tomorrow" than entering code.
You can simply create a 4-day (or possibly 5-day) forecast and move the first day to the outside of the screen (to the left).
That's what I did on this watch face for the Bip6 and GTS4:
https://amazfitwatchfaces.com/bip/view/43900
https://amazfitwatchfaces.com/gts/view/12180
Good luck.
Guydu91 ha scritto: 22 giu 2026, 21:13
That’s not quite right. Your design is such that the forecast starts at the edge of the screen. So you can move the first day off-screen. But the design doesn’t always allow you to do that. And in that case, you’ll need to edit the code.
EXneko
Messaggio da EXneko »
Which version should I use to make watch faces for the Amazfit Band 5 NFC edition?
EXneko ha scritto: 25 giu 2026, 16:44
Probably none at all
Torna a “Watchfaces tools”
