Has thanked: 1165 times
Been thanked: 279 times
App version (Stable or Beta)
Watch model
Phone model
OS version
Description of your problem
Filling example:
App version: 2.0.111 Stable
Watch model: GTR
Phone model: Samsung S10
OS version: Android 10
Stas
Been thanked: 34 times
Post by Stas »
We’ve made the necessary changes to ensure the app becomes compatible with your device. The update will be available soon, and you’ll also be able to download the APK directly from our website.
ZduneX25 wrote: 12 Jan 2025, 18:14
Google Play says AmazFaces app is not compatible with my Redmi 8, Android 10, works fine on Redmi K70 Pro, Android 15.
piotarock
Post by piotarock »
App version: 4.7.385 stable
Watch model: balance
Phone model:Redmi Note 10
OS version: Android 13
Unable to sync watchfaces. Getting an unusual error (see green area at the bottom of the attached image). In addition, the app keeps logging me out.
Stas
Post by Stas »
Download the beta version where this issue has been fixed.
piotarock wrote: 29 Jan 2025, 01:21
Alan_SP
Post by Alan_SP »
How to download beta, or even better, when it will be available as regular download?
I also have this issue, can't upload watchfaces. :(
piotarock
Post by piotarock »
The beta version is downloaded automatically after joining the beta test community. To do this, download the stable app from Play store. After installing, go back to play store and view the app, scroll down and you will see App Support. Click it, you will get an option of joining the beta. Join it. It will take a few minutes. And that's it.
g-rex69
Post by g-rex69 »
Google Play says AmazFaces app is not compatible with my:
Watch model: T-REX 3
Phone model: MiNote 13 rooted
OS version: HYPERoS ver: 1.0.9.0
How to override it?
Stas
Post by Stas »
Are you unable to download the AmazFaces app itself, or is the issue that you can't download watch faces within the app?
Downloading dials on the T-REX 3 is only possible via QR code.
direct link https://amazfitwatchfaces.com/awapp
grex69 wrote: 15 Feb 2025, 19:02
How to override it?
piotarock
Post by piotarock »
App version: 4.7.388 stable
I was having a problem where the watchfaces couldn't install or the wrong watchface was being installed. I fixed it by clearing the cache of the amazfitwatchface app. This might help someone.
Smarteam
Post by Smarteam »
App version: 4.7.391 Stable
Watch model: Amazfit Active 2
Phone model: Samsung A52s
OS version: Android 14
Not able to sync watch faces from app to watch. Can not connect to watch. Is Amazfit Active 2 not supported yet?
piotarock
Post by piotarock »
Smarteam wrote: 05 Mar 2025, 15:26
Try to log out and sync. I encountered a similar bug. I logged out and was able to sync watchface. In addition, if this fails, try the beta version of the app.
Zritwo
Post by Zritwo »
App version: 4.7.391 beta
model: origin OS version: Android 15
Stas
Post by Stas »
For Balance watch faces, they're loaded via a QR code. Once you scan, you'll see instructions on how to enable developer mode.
Zritwo wrote: 08 Mar 2025, 10:11
abuaqif
Post by abuaqif »
Thank you
Stas wrote: 28 Dec 2024, 10:01
We will soon upload the APK version on our website for your convenience.
abuaqif wrote: 25 Dec 2024, 15:27
App version: Unable to install any of apps version
Watch model: T-Rex
Phone model: Nubia Redmagic 7
Not able to install AmazFaces apps at all, error not compatible.
Return to “AmazFaces app”
