Пошук дав 15 результатів
- 26 липня 2025, 14:30
- Jump to forum
- Jump to topic
Re: Help with extracting special symbols from symbols
Hello everyone,
I love creating/porting watchfaces for fun. Asoo assisted me a lot during my beginner days (thank you very much). However, I have been experiencing a challenge when creating special symbols from fonts, e.g, the degree celcius (zero and C), AM/PM, error symbol (--), etc. I have ...
- 17 січня 2025, 07:27
- Jump to forum
- Jump to topic
Re: Help with simulating watchface using Zepp OS [ balance]
Of course it's going to cause an error. Because if you look at the structure of the files before changing them, you will see that it is different. In the best case you can copy the init_view() function from one file to another. But you also need to m,eltn copy other elements besides the function.
- 17 січня 2025, 19:02
- Jump to forum
- Jump to topic
"But you will need to copy other elements besides the function."
A typo in the translation.
- 17 січня 2025, 19:18
- Jump to forum
- Jump to topic
piotarock
1. The editor makes watch faces on API 1. In Zeus CLI you have created code on API 2. They have fundamentally different code and cannot be copied. Create a watch face on API 1. If it is important for your design to use functions that are available only on API 2, you can take only ...
- 23 лютого 2026, 14:31
- Jump to forum
- Jump to topic
Re: Seonds progress (linear mode) and also step
Hello devs,
Is it possible to use the editor to make second and step progress as shown in the image? Seondly, how can I add the week number using the editor by sasha? For example, week 10, day 100, etc.
https://i.postimg.cc/P5053WFN/sample.gif
Regarding the week section, I'm not sure.
But ...
- 23 лютого 2026, 19:12
- Jump to forum
- Jump to topic
This is an example I've created; it's the simplest method I can think of.
But you need to create a 60-frame image to show this progress.
This is the simplest option and the easiest to adapt to different models.
But you can also make one image with the background as a mask. And under it, place ...
- 24 лютого 2026, 12:44
- Jump to forum
- Jump to topic
Thank you very much for the ideas @asoo
This is another example of using a single image, scrolling up and down by changing the x,y values (in this case, the Y value) to show seconds and steps. Hope this is useful to you.
https://i.postimg.cc/9F5xK1n6/watch-A.gif
https://amazfitwatchfaces ...
- 03 січня 2025, 01:23
- Jump to forum
- Jump to topic
Re: Request for weather images
I am learning how to create watchfaces. I am looking for the unedited/uncropped weather images such as the ones used by mirda69 in this watchface:
https://amazfitwatchfaces.com/gtr/view/34029
Thank you.
This is an image that I have collected for my own use. It is not sort as per ...
- 14 лютого 2025, 07:47
- Jump to forum
- Jump to topic
Re: Help with color change on tap script
Try this
pointer is not an img in the code, it must be treated differently
let colornumber_main = 1
let totalcolors_main = 5
let namecolor_main = ''
let pointerstring = 'pointer_1.png'
function click_ColorStyle() {
colornumber_main=1;
else ...
colornumber_main=1;
else ...
- 15 лютого 2025, 18:02
- Jump to forum
- Jump to topic
Try this
Changing properties with hmUI.prop.MORE is correct in this case. But I don't understand why to add an additional variable ‘pointerstring’? I would change the function like this
let totalcolors ...
- 13 березня 2025, 02:56
- Jump to forum
- Jump to topic
Re: Unknown weather issue
Hello developers, porters, and watchface creators,
I believe that you are all well. I have a question regarding the unknown weather image. Sometimes, when it rains the watchfaces (including the ones from Zepp) show 'unknown weather'. However, the watchfaces by mirda69 always indicate 'rain'. I ...
- 13 березня 2025, 12:33
- Jump to forum
- Jump to topic
I think it's more correct to write to Amazfit support to have them fix this issue.
This may be a temporary solution for now. But you have to decide what is better for you: sometimes showing unknown weather instead of rain or sometimes showing rain instead of unknown weather. Personally, I've only ...
- 14 березня 2025, 06:22
- Jump to forum
- Jump to topic
Re: Change minute and hour color
Hello Devs,
How are you? I am trying to create a watchface where the digits on minute and hour hand change. I have followed the code implemented by @asoo but it seems I am missing a point. I have attached the screenshots of my folder and code. Please assist me on this.
https://i.postimg.cc ...
- 14 березня 2025, 10:51
- Jump to forum
- Jump to topic
The incorrect part is that the colors of minutes and hour digits are not changing on click. All the other items are changing apart from the digital time.
If your script is correct, when you change the color of some elements, it does not change color. You try to turn off the screen and turn it ...
- 14 березня 2025, 10:56
- Jump to forum
- Jump to topic
Thank you very much @asoo. I will attach the entire project once I leave my office. Should I PM you or its okay if I attach it here.
If you don't want to publish the project yet, PM me.
Or if you want others to help you fix it, you can attach it in the post.
PS. Others may have different and ...
