Search found 4 matches
Return
by asoo
16 Mar 2026, 08:31
Jump to forum
Jump to topic
Re: Is any step by step Guide how to protect your watchfaces?
can you refer me to a guide how to use "uglify"?
If you want to 'uglify' JavaScript, I recommend checking out:
https://github.com/mishoo/UglifyJS
The website provides step-by-step instructions on usage and installation.
However, if excessive uglifiy with index.js might that index.js will ...
by asoo
17 Mar 2026, 09:20
Jump to forum
Jump to topic
What is the "index.js"?
are u talking about the prime "json" file in the root folder or the files inside the JS folder.
so i understand i need to use the UglifyJS before im packing a watchface to zip file
"index.js" is not included in the project's boundary package.
To implement UglifyJS, you ...
by frankh93
17 Mar 2026, 17:50
Jump to forum
Jump to topic
Re: a free website that can upload zip file and it will generate qrcode?
You can check this guide viewtopic.php?t=3873 to make the qr uploading the zpk to sites like catbox.moe or pcloud, but basically you can generate the qrcodes for your watchfaces using any site that provides the direct link to the file, otherwise it won't work
by asoo
11 Jan 2024, 22:49
Jump to forum
Jump to topic
Further update: I found some mentions on Discord about changes to QR code generation, and it seems to affect the upcoming version 10.8.5.
Some changes are coming to the way your custom QR Codes with perma links like the one put on `github` pages, are processed.
Starting from zepp app `10.8.5 ...
