Been thanked: 2122 times
June 17, 2026
Preview
============ if update Zepp to version 10.8.1+.
Now cannot be installed via this method. A fix is ​​expected to be implemented soon. =============
Youtube how to use zepp app
Note :
ZPK
Download Program
CreateZPK+2.zip
(48.39 KiB) Downloaded 1472 times
WinRAR :
7zip:
ืNote :
CreateZPK.zip
(90.62 KiB) Downloaded 1427 times
Or you can use
permanent :
catbox.moe
storage time limit :
litterbox.catbox.moe
to upload the file
Let's edit it to
Note:
QRCoder+zpkd1-link1.1.zip
(217.3 KiB) Downloaded 664 times
( By taw_bip )
viewtopic.php?p=22191#p22191
viewtopic.php?p=22231#p22231
Developer Mode ( 24-08-2025 )
or see this clip
- select General
- select Developer Mode
- select SCAN
My Note :
SnakeAU
Post by SnakeAU »
CreateZPK+2 opens but everything is greyed out, any reason this would occur?
BigBlind68
Post by BigBlind68 »
SnakeAU wrote: 12 Jan 2024, 06:24
You have WinRar or 7-Zip on your PC?
Please install winrar or 7zip on your PC
WinRAR :
7zip:
OR if you do not want to install compress program please try this :
CreateZPK.zip
(90.62 KiB) Downloaded 671 times
I noticed that https://amazfitwatchfaces.com Added a section for the "Amazfit Balance" "File Download". That add in section is a QR code that can be used with the Zepp App.
That means you just upload the watch face you want to the web and you will get a QR code ready to use with the Zepp App.
SnakeAU
Post by SnakeAU »
BigBlind68 wrote: 12 Jan 2024, 10:23
I do have it installed, but still greyed out, I will try the other app.
SnakeAU wrote: 13 Jan 2024, 05:35
I am not sure why installed it's will not work for you
I tested, if I uninstall winrar and open program it will be gray ( can not use )
But after install winrar and open again it will be use normally
@SnakeAU
Max88
Post by Max88 »
Just as info for other users.
Although this thread mentioned only balance model, I have tried to reproduce the steps of the guide also for Amazfit Active.
It works.
I have previously downloaded a watchface for Gts 4, converted it for Active with Sasha tool and then I have followed this guide to create the QR code to use trhough Zepp app.
Thanks guys
Hispanico957
Post by Hispanico957 »
YESSSSSSSSSS YOU ARE GREAT
THANK
KIRA
Vegastar
Post by Vegastar »
BRUH! You are awesome!
With this method I managed to add converted watchfaces on Amazfit Active!
Thank you!!
Sejra
Post by Sejra »
Can some one explain the contents of the ZPK file? Or possibly share some example `dial.zip` and `dial.zpk` so that I can check myself?
I would assume ZPK stands for ZPack compression algorithm. There are other tools (GitHub...), which I could possibly use to repack ZIP to ZPK.
P.S. The utility ZPK+2.exe or ZPK.exe do not work for me. I have only Win 7 32bit. 7-Zip is installed in C:\Program Files and it seems to be recognised by ZPK+2.exe program as it offers 7-Zip bullet option in the GUI.
The error is:
System.IO.FileNotFoundException: Could not load file or assembly 'System.IO.Compression, Version=4.2.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' or one of its dependencies. The system cannot find the file specified.
File name: 'System.IO.Compression, Version=4.2.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'
   at CreateZPK_2.Form1.CreateZPK(String fullFileName)
   at CreateZPK_2.Form1.button_Create_Zpk_Click(Object sender, EventArgs e)
EDIT: Okay, got the ZPK.exe working - I can convert the ZIP to ZPK now - the error was due to a missing dependency of Microsoft .NET.
domenicopardo
Post by domenicopardo »
Amazfit Balance and Zepp on Android
ZEPP V. 3.25.5.3 for Android does not allow access to Developer Mode. How to install Watchface by scanning the QR Code ?
@domenicopardo
No need to write in large font.
ZEPP V. 3.25.5.3 does not exist. The latest version is 9.2.2.
In the latest version of Zepp the developer mode is activated in the same way as in previous versions. In the application settings, click the application icon several times.
domenicopardo
, I made a mistake. Problem solved
Dimitry
Post by Dimitry »
Hello everyone,
Amazfit Balance and zepp on Android.
I create a watchface using zepp watchface maker and i am able to download it on m'y watch using tCreateZPK+2 , PCCloud and zint .
But if i modify the code just by adding an import
 import Colors from "../../utils/config/constants";
to another file which contain constant with color définition:
 export const Colors = {
    default:0xfc6950,
    defaultTransparent:0xababab,
    white:0xffffff,
    black:0x000000,
    bgHigh:0xffa0a0,
    bgLow:0x8bbbff,
    accent:0xffbeff37
( i'm not even use this color in m'y index.js for now) the watchface can be donwloaded but the screen stay black without nothing display on it.
Do you have an Idea why just this import made the screen black ?
You are trying to go 2 levels higher in the folder structure. What folder do you think the link ../../ should point to? You should probably change it to
import Colors from "./../utils/config/constants";
or
import Colors from "../utils/config/constants";
Dimitry
Post by Dimitry »
Hello SashaCX75 thanks for your answer.
My index.js file is in watchface/default-target/ directory.
So for me if i go up 2 level higher. i will go here :
So for me i need to go 2 level higher. I try to modify it and even to put thé file in thé same folder with :
 import Colors from "./constants";
and i have the same issue
@Dimitry
1. Set the ‘mode’ parameter in the ‘packageInfo’ section of the app.json file to ‘development’. Then you will be able to look at the logs and it may become clear what the error is.
"mode": "development",
2. Try to run the watch face in the ZeppPlayer simulator. There you can also look at logs and debug the code in the watch face. But not all functions work.
3. Reassemble the watch face in Zeus and debug it in the official editor.
UlliT.
Post by UlliT. »
Thanks for your help to get my first watchface on my amazfit active 2.
I like many information in bigger digits so i can read it without glasses..
I am happy to get the altitude and the sensor-temperature working.
The battery bar seems to be wrong - t
But there are two issues left:
- the position of all most texts is wrong (different to the editor)
- the step bar at the bottom is missing
the text positions i can easily change, but that seems to be a issue in the watchface editor.
because the missing step bar, i have no idea....
Ulli
al0o0z
Has thanked: 9 times
Post by al0o0z »
Can anyone please help on how to get the .bin file of a watch face from amazfaces that I make some edits or oort for my watch?
Thanks in advance for your help.
al0o0z wrote: 22 Nov 2025, 23:23
Which device model watchface are you talking about? You should specify this, otherwise it will be difficult for someone trying to help you to advise you.
Also, I don't think your question should be in this topic. I suggest you start a new topic in the appropriate area.
al0o0z
Post by al0o0z »
asoo wrote: 23 Nov 2025, 07:13
Thanks for your kind reply. Please point me to the forum area which should be appropriate for this question.
I am using active 2 square।
al0o0z wrote: 24 Nov 2025, 04:10
The "Active 2 square" watchface file should be a .zip file, not a .bin file.
But if you mean index.bin in the zip, this file cannot be edited because it is encrypted by owner. The only way to edit it is to contact the watch face owner and ask him to edit what you want.
If you want to discuss "Active 2 square" watchfaces, recommend using this forum.
Amazfit watches (Global) [ Amazfit Falcon, Cheetah, Balance, Active ] < Watchfaces discussion :
viewforum.php?f=178
mbmuch
Post by mbmuch »
I'm lost.
What's wrong?
What can I do?
Cheers
(279.69 KiB) Downloaded 232 times
