Search found 13 matches
Return
by osmat
06 Jul 2019, 07:07
Jump to forum
Jump to topic
Re: Amazfit Tools Mi Band 4
Stupidiputs wrote: 05 Jul 2019, 09:53
Is there any manual in this community about how to edit json files? I dont know what some variables mean.
We are preparing the most complete information that we have today and will soon publish it.
by SashaCX75
09 Oct 2021, 14:14
Jump to forum
Jump to topic
If you have any questions about the GTS 2 mini, it is better to contact the neFAST user. As far as I know, he has made a lot of progress in terms of working with these dials. Maybe he wants to create a separate thread on this forum.
Those who have problems installing python can use this utility. It ...
by SashaCX75
12 Nov 2021, 19:19
Jump to forum
Jump to topic
Max88
In addition to the information in the quoted message, I have no other
by asoo
07 May 2022, 00:43
Jump to forum
Jump to topic
Guys, do you know if there is a tool to extract and rebuild bin for amzfit bip U ?
Editor on web. ( only layout )
https://tnxec2.github.io/amazfit-gts2mini-watchface-static/
https://github.com/Tnxec2/amazfit-gts2mini-watchface-static
Huaim online editor ...
by asoo
07 May 2022, 12:40
Jump to forum
Jump to topic
Huaim online ...
by asoo
22 Jan 2024, 03:45
Jump to forum
Jump to topic
Hello guys. I need help with this watchface:
https://amazfitwatchfaces.com/gts/view/8791
I'd like to understand how has the autor managed to reproduce the behaviour of original watchface of apple watch.
When I load this watchface inside this editor I don't understand where the 12 images have ...
by asoo
22 Jan 2024, 09:44
Jump to forum
Jump to topic
Ah ok, so it's quite more difficult than when I made wf for gts 2 mini :lol:
Thank you for help.
Just one thing, is there any guide to learn how to make wf now for zeppOs?
I don't know anything of that code, so I wouldn't know how to implement the necessary modifies or how to understand what I ...
by SashaCX75
30 Jan 2024, 17:13
Jump to forum
Jump to topic
@Max88
Not all watch faces can be unpacked. Therefore, not all watch faces can be converted.
These watches have different aspect ratios. When converting, the aspect ratio does not change, the watch face is simply scaled in width.
by asoo
23 May 2025, 12:28
Jump to forum
Jump to topic
Hello guys. I have an amazfit bip 6 since yesterday and this tool is amazing.
I had already used it previously, but it has reached an super level of customization.
Sasha, is there a way to add a shortcut or something else to the watchface to recall zepp flow?
I know it can be done with long press ...
by SashaCX75
24 May 2025, 18:05
Jump to forum
Jump to topic
Given that different versions of Zepp Flow have different IDs, it may change in future versions.
by asoo
26 May 2025, 14:53
Jump to forum
Jump to topic
hmApp.startApp({ appid: 1076308, url: 'page/gtr/home/index.page'});
Tested on by Bip6 it's work
Asoo could you tell me where to look for the app id of zepp flow? So, if it changes in future, I'll know where to find it.
Thank you ^^
I look at the App.json file of the program.
You can find ...
by asoo
24 Jan 2024, 02:02
Jump to forum
Jump to topic
Re: Tool to unpack gts 2 mini
https://amazfitwatchfaces.com/forum/viewtopic.php?p=12537#p12537
Thank you. I had already seen that post, but that main.exe file doesn't work for me.
It doesn't unpack wf I have downloaded from this site.
Moreover, to be honest I haven't understood exactly how to use it.
I have imagined it ...
by asoo
24 Jan 2024, 09:59
Jump to forum
Jump to topic
if you want to use main.exe , main.exe must be in the same folder as file.bin that you want to unpack.
Or, if you don't want to copy main.exe into the same folder as file.bin, you can copy main.exe into the folder c:\windows or the folder where Windows is installed. Doing this, you can run main.exe ...
