Version 7.3
Fixed known display bugs.
v 7.2
v 5.0
v 4.1
v 4.0
v 3.1
Added French.
Added support for T-Rex Pro.
Found bugs fixed.
v 2.1
Fixed bugs in display AOD.
Added support for AOD.
Added Chinese translation.
v 1
Added English translation.
v 1.2 Added Spanish language
mira.vorlik
Post by mira.vorlik »
RTMhun wrote: 15 Nov 2022, 10:14
whitch project of me?
Ihave not made watchface for T-Rex only GTR2 ...
Sorry, that was meant for another post.
NanR20
Post by NanR20 »
Big thanks to SashaCX75 for this awesome tool.
Keep it up with the great work.
Cheers buddy!!! ;)
Evergreen777
Post by Evergreen777 »
Hello and thanks for this program! I'm new to making watchfaces. I decompiled and edited a few to see how it works.
I am now working on a watchface from scratch to get the hang of it.
I only have a background image and a couple of numbers and it looks fine in the editor, but when I export it to my GTS2e the "preview" image that already has a static Time on it is used as background, meaning the actual Time display is overlayed on top. I must be doing something wrong, but I don't know what :( .
Below is a screenshot of the editor, a picture of how it looks on the GTS2e itself and the packed .bin is attached to this post.
Thanks in advance and may you all have a nice day :)
SolitonRadarAlert_packed.bin
bin file
(51.15 KiB) Downloaded 855 times
Been thanked: 2122 times
Evergreen777 wrote: 22 Nov 2022, 09:44
I attached a screenshot of the editor to this post, as well as a picture of how it looks on the GTS2e itself:
I think it those interested in helping you would be difficult to answer the question asked.
I suggest you attach a file of your work.
or the job's .json file
rodblochon
Post by rodblochon »
Hi
Is there a way to test a watchface on GTR2 before uploading on your website then downloading back on the mobile phone ? It is important when I develop new watchface that sometimes have bugs...
thank you for your incredible software !!
Evergreen777
asoo Thanks, I'm going to add the packed .bin. What would be the most convenient way to add the .json? I cannot attach it to my post, the forum won't allow it.
Evergreen777 wrote: 22 Nov 2022, 15:42
@asoo Thanks, I'm going to add the packed .bin. What would be the most convenient way to add the .json? I cannot attach it to my post, the forum won't allow it.
If you can send a BIN file, that's enough.
json is already in BIN
But is the file you sent is the one that caused the problem as you stated?
Because from the picture that you have attached before, there are 12 image files.
But the BIN file you attached contains only 11 images.
Since I don't have GTR2, I can only verify the json file.
As far as looking at the json there shouldn't be any problem in the file you attached.
little introduction
if possible
I suggest that the main screen and preview files should be
0001 and 0002 respectively.
Imran_00_7
Post by Imran_00_7 »
Hello!
Can anyone help me in converting watchface of gtr 2 to zepp e circle?
How to convert it & how to unpack .bin file?
rodblochon
Hello
On GTR2, When you long-press the screen, you can swipe between your installed watchfaces.
For my creations, the preview is always too large or not centered. How to properly generate it with the editor ? and what is the line in the JSON ?
I created a 306x306px preview, saved as 0065.png and specified in the very first line of the JSON
"Background": {
    "Preview": [
        "LangCode": "All",
        "ImageSet": {
          "ImageIndex": 65,
          "ImagesCount": 1
    "BackgroundImageIndex": 1
What's wrong ?
Thank you :-)
fertrema
Post by fertrema »
SashaCX75, firstly, congratulations on the beautiful work, intended for the various versions of the Amazfit gtr. I liked this watch face (image attached) on my gtr 47mm, and because it is sensational, and created by the brilliant me el-professor, I decided to use it on my gtr 2. Ok, I did the conversion using your program, but the analog step pointer, It didn't appear on the clock. Do you know what happened? Is there a way to resolve this? Thank you again, and success always!!
fertrema wrote: 11 Oct 2023, 23:08
If you use program".AmazFit_Watchface_Editor_(GTR47ToGTR2)" to convert GTR47 to GTR2
SashaCX75 has already stated that There may be some components not working.
According to this topic
viewtopic.php?p=8844#p8844
fertrema
Post by fertrema »
@fertrema Converting watch faces uses undocumented features of watch faces and therefore may not work properly. The most reliable way is to make a new watch face for the desired model in the appropriate editor.
fertrema
Post by fertrema »
@SashaCX75, thank you very much for your willingness to respond, and I would really like to learn how to make a watch face, but I don't know where to start. Could you direct me, brilliant professional!! Thank you and have a great day!!
@fertrema Unpack some finished watch faces and see how they are arranged. Change the parameters and see the result.
fertrema
Post by fertrema »
@SashaCX75, Thank you very much once again for yours kindness, I will do as for yours guidance and have a great weekend!!
domenicopardo
Post by domenicopardo »
Unfortunately I'm terrible at using forums and I hope this post is read as much as possible.
Can someone explain to me how to draw and position the hands of an analogue dial?
Thank you
Dw_p
Post by Dw_p »
domenicopardo wrote: 18 Nov 2023, 16:55
Thank you
Go into the edit menu then the time menu from the right and then in the analog clock section you will see the rotation center coords and rotation point offset as options to change so the rotation point offset requires the coords of where on the dial image your axis/centre will be and the rotation center coords will move the image around with the axis/centre as its anchor.
this might not be most best explaination so if you are still confused you could dm me on discord at @.dweep.
domenicopardo
Perfect ! Thank you so much. Works very well, thanks again.
Royalka
Post by Royalka »
Hello. Please help me. I can't change it so that the hour clock hand doesn't move 360 degrees, I would need less. I try to make changes to the program during editing, but it always writes it back. Or do I want to modify it in the wrong place?
@Royalka This is not possible for these watch models.
Royalka
Post by Royalka »
Hello. Thanks for the quick response. :!: Do you have an idea how I could display a specific image at a specific time? eg: a cat at one o'clock, a dog at two o'clock...
@Royalka If I remember correctly, you can use 24 images to display the watch.
To do this, open the watch face json file in a text editor and change the "ImagesCount" value for the watch to 24 and the "DisplayFormAnalog" value to true, save the changes. After that, open the file in the watch face editor and pack the watch face without changing anything in it.
toolsrme
Has thanked: 9 times
Post by toolsrme »
SashaCX75 wrote: 08 Jun 2021, 14:39
The size of the system font should not be more than 47, it can cause an infinite reboot watch.
@SashaCX75 Does this issue with system font size still exist? Does it exist on the T-Rex 2 also?
BTW - Do you know what font is the system font? I've yet to find it detailed anywhere.
I don't follow this model, but I don't think anything has changed in terms of font handling.
The T-Rex 2 has more font options, but still has some problems.
Users browsing this forum: alex1969 and 2 guests
