搜索找到 9 个匹配
- 21 1月 2024, 14:46
- Jump to forum
- Jump to topic
Re: Change data type of widget
I don't know if you can change the widget type. But you can definitely make several different widgets and change their visibility.
- 09 11月 2022, 19:16
- Jump to forum
- Jump to topic
Jel If the watch supports the functions "new Date()" and "getMilliseconds()" then this method should be better. This eliminates possible calculation errors. If you use "new Date()" and "getMilliseconds()" then the line "const now = hmSensor.createSensor(hmSensor.id.TIME);" probably not needed.
I'm ...
I'm ...
- 05 4月 2023, 06:01
- Jump to forum
- Jump to topic
But I would like to be able to see the possibilities of all the codes out there, even downloaded apps, where do you get those codes from?
This data is taken from the available watch firmware. The list can be viewed here, but it is better to search for this information in your language.
https ...
- 27 12月 2023, 18:41
- Jump to forum
- Jump to topic
toolsrme There is no need to create any folder structure in the editor. There is a button in the editor to create a new project. You only need to select an empty folder for it. Then add the necessary images to the project and use them to create the necessary vidgets. When creating a watch face, the ...
- 03 1月 2024, 18:02
- Jump to forum
- Jump to topic
It is necessary to save the setting if you want to save the settings when switching watch faces. It is also required if you want to change settings related to the AOD screen. In other cases it is not necessary. To save a setting, you usually use something like this
hmFS.SysProSetInt('js_test_int ...
- 16 1月 2024, 06:22
- Jump to forum
- Jump to topic
Zeus creates a project for its further compilation. The editor creates a project for direct work on the clock. Therefore their structure is different. Even if you create a project in Zeus and then compile it, the structure of the source and destination files will be slightly different.
That's why ...
That's why ...
- 17 1月 2024, 06:33
- Jump to forum
- Jump to topic
The use of skins is enabled in the settings. They are used when saving the preview in a png or gif file.
The use of shortcut pointer is also enabled in the settings. It is only used when saving the preview to a gif file.
- 29 1月 2024, 08:50
- Jump to forum
- Jump to topic
Hi @SashaCX75
I believe at one point I read a post somewhere in the forum that I believe was from you, but for the life of me I can't find it again. I could be wrong though, but just wanted to check.
Did you possibly mention a tool that you like that can convert the Zeppos special TGA images ...
- 29 1月 2024, 15:53
- Jump to forum
- Jump to topic
Thanks, but I don't believe so. That tool looks like it is for creating targa images that are used on the watch.
The link is just a utility that can convert images from watch face to normal png (it can convert images both ways).
There is also a "[TBUI] Watch face tool". It is designed for other ...
