T-REX 3
- GIK-Team
- root
- Has thanked: 1155 times
- Been thanked: 278 times
Hi David,
Could you please clarify what specifically you're asking about the T-REX 3? Are you referring to watch face support or some other feature? Thank you.
- Has thanked: 419 times
- Been thanked: 2109 times
- SashaCX75
- Has thanked: 13 times
- Been thanked: 1036 times
https://watchface.zepp.com (WatchfaceMaker) creates two different packages for T-Rex 3 and for Balance. The images in them are also different. But the way of encoding images in them is similar. Perhaps T-Rex 3 does not support ARGB images, so some of the images for it were packaged differently. Only watch owners will be able to fully check the compatibility of watch faces. But I think there should be no problems.
- Evilmind_04
- Has thanked: 3 times
- Been thanked: 14 times
I tried to install multiple balance watchfaces on the t-rex 3.
Some do work, but most faces with alot of info or certain js coding don't.
It gives a parsing error on the zepp app and jumps from watchface to mini program when it gives the error.
The thing I do miss on amazfaces is that there are no qr codes generated for the t-rex 3 like there are for the balance.
Hopefully it will be added soon.
