T-REX 3
dporte
T-REX 3
Post by dporte »
What about T-REX3 please ?
Thank you.
David.
Has thanked: 1165 times
Been thanked: 279 times
dporte wrote: 11 Sep 2024, 16:01
Thank you.
David.
Hi David,
Could you please clarify what specifically you're asking about the T-REX 3? Are you referring to watch face support or some other feature? Thank you.
Has thanked: 421 times
Been thanked: 2129 times
Watchface maker.png (132.52 KiB) Viewed 14002 times
Test_Trex3.zip
(148.96 KiB) Downloaded 135 times
This is an example watch face for T-Rex 3 created using https://watchface.zepp.com (WatchfaceMaker), the official editor for Amazfit series. As far as I tested, the watch face created for T-Rex 3 can be used with Amazfit Balance, so I guess Amazfit Balance watch face can be used with T-Rex 3. However, I am not sure the "Balance watch face" is fully compatible with T-Rex3 or not .
Has thanked: 14 times
https://watchface.zepp.com (WatchfaceMaker) creates two different packages for T-Rex 3 and for Balance. The images in them are also different. But the way of encoding images in them is similar. Perhaps T-Rex 3 does not support ARGB images, so some of the images for it were packaged differently. Only watch owners will be able to fully check the compatibility of watch faces. But I think there should be no problems.
Legorille
Post by Legorille »
Cela fonctionne également de la Balance à la T-rex 3 . Je vient juste de tester .
Evilmind_04
Been thanked: 14 times
Post by Evilmind_04 »
I tried to install multiple balance watchfaces on the t-rex 3.
Some do work, but most faces with alot of info or certain js coding don't.
It gives a parsing error on the zepp app and jumps from watchface to mini program when it gives the error.
The thing I do miss on amazfaces is that there are no qr codes generated for the t-rex 3 like there are for the balance.
Hopefully it will be added soon.
Return to “Device discussion”
