Version 7.3
Fixed known display bugs.
v 7.2
v 5.0
v 4.1
v 4.0
v 3.1
Added French.
Added support for T-Rex Pro.
Found bugs fixed.
v 2.1
Fixed bugs in display AOD.
Added support for AOD.
Added Chinese translation.
v 1
Added English translation.
v 1.2 Added Spanish language
hemendex
Post by hemendex »
Please, has the issue with year editing in T-Rex pro face editor been resolved? Still can't add year :(
Judging by the screenshot you are using not editor but a converter to watch faces. The description of the converter says that not all elements work in this mode.
So if you need the year in the watch face, use the editor and reassemble the watch face.
cycy1218cycy
Post by cycy1218cycy »
thank you!
hemendex
Post by hemendex »
SashaCX75 wrote: 14 Feb 2024, 17:37
Thanks, I understand that the best solution is to make the watch face without converting - from scratch. Too bad the touch zones don't work, they only worked on T-Rex. never mind :)
bjk8kds
Has thanked: 12 times
Post by bjk8kds »
Thank you!
42west
Post by 42west »
Hello Sasha, I've had a look at the 7.3 app, and it looks impressive. Thank you for your hard work in creating this.
I was wondering if there is a newer version of the app that supports the Amazfit Balance (or any of the new models from 2023 etc)
Been thanked: 2122 times
42west wrote: 21 Feb 2024, 21:23
viewtopic.php?t=2743
hemendex
Post by hemendex »
Sasha, help me :)
Please is it possible to assign KM or MILES units (2 png files) under the numerical value? The program allows only to the right of the number. I have to put it as in the attached picture.
@hemendex
This is not officially supported. But I can suggest a way to try to do it.
Make the image of digits wider (about as wide as 3 digits). The digit itself should be on the right side of the image.
Make the image of units of measurement higher by about 2 times. The units of measurement should be placed in the lower left corner. Set the negative space to be about the size of 2 digits.
ZiMiZ
Post by ZiMiZ »
How can i edit this WF? https://amazfitwatchfaces.com/gts/view/3856 i dont find the right software
ZiMiZ wrote: 06 Dec 2024, 11:06
link you post is GTS
if you want to edit or modify you must use "AmazFit WatchFace editor for Windows by SashaCX75"
viewtopic.php?p=3789#p3789
"AmazFit WatchFace editor 2 for Windows" not for GTS
