• Адміністратор
Правила форуму
Аватар користувача
Контактна інформація:
Повідомлення SashaCX75 »
Востаннє редагувалось 17 червня 2026, 20:16 користувачем SashaCX75, всього редагувалось 53 разів.
Аватар користувача
ZduneX25
З нами з: 12 жовтня 2022, 16:22
Been thanked: 6 times
Повідомлення ZduneX25 »
SashaCX75 do you know any way to recognize screen wake event? the problem is i would like to start animation only after raise to wake gesture instead of having it keep starting everytime i switch view back to the main screen
Аватар користувача
ZduneX25 There is no easy way. In WIDGET_DELEGATE, you can track the on and off of the screen, you can switch between the normal screen and AOD. It is unlikely that it will be possible to determine the reason for turning off the dial, whether the screen went out or simply switched to another program.
Аватар користувача
ZduneX25
SashaCX75 i started with WIDGET_DELEGATE yet it cannot separate both wake and back to the main screen events, then i tried hmSetting.screen_type.WATCHFACE and i was only able to start animation once for the first time, finally tried onResume and onStart no luck
i cannot remember how to create log in zepp app
EDIT: found it, but they disabled it.. https://docs.zepp.com/docs/guides/tools ... chine-logs
Xemic
З нами з: 24 січня 2023, 21:52
Повідомлення Xemic »
SashaCX75 oh sorry, just noticed my error with the screenshots. i added the right one this time :) . cheers.
i noticed that if i add icon to "Digital Time - Hours" it overlays over Minute and Seconds, regardless of how it's arranged. If i put Hour at bottom and Minute at the top the icon still overlays.
e.g. This is the design and layout on watch face editor.
Зображення
But I get this on the watch.
Зображення
Is this something that can change in the index.js file?
Аватар користувача
ZduneX25
Xemic you split time widget then place the one you want to see on top > below
typical digital clock looks this way:
Зображення
Xemic
Thank you ZduneX25 and SashaCX75
I tried your suggestions. I even went as far as moving the icon bit up. At this point I'm sure I broke something as the watch face was completely bank. (I'm sure it was commenting out "show_level: hmUI.show_level.ONLY_NORMAL," beneath the hour code).
Зображення
Haven said that i found a way round the issue., I used the icon as seconds.
Аватар користувача
ZduneX25
Xemic your IMG widget is missing H and W properties that's for sure, second: uncomment because you did it wrong
Аватар користувача
For an IMG widget, the height and width properties are optional. Commenting out the line "show_level: hmUI.show_level.ONLY_NORMAL," is optional, it only affects the display on the AOD screen. It is definitely not necessary to comment the next line, without it there will be errors.
Аватар користувача
ZduneX25
SashaCX75 do you know appid to add shortcut for Dialer/Phone app and Store Cards?
Зображення
Аватар користувача
ZduneX25
Perhaps
Код: Виділити все
hmApp.startApp({ appid: 1, url: 'CardsScreen', native: true })
hmApp.startApp({ appid: 1, url: 'PaymentCardScreen', native: true })
But most likely it only works on the Chinese version of the watch
Dial
Код: Виділити все
hmApp.startApp({ appid: 1, url: 'DialCallScreen', native: true })
Аватар користувача
ZduneX25
SashaCX75 thank you, so PaymentCardScreen is not working, CardsScreen it works, but like you said it opens some chinese page (i believe there is another name that will trigger proper page), finally DialCallScreen is taking me to a fake call screen when watch rings and i see reject/accept buttons, i would be satisfied with call history, favorite contacts or dialer itself (if you have any ideas)
santicam
З нами з: 19 січня 2023, 17:00
Повідомлення santicam »
SashaCX75 писав: 13 грудня 2022, 18:17
A collection of code examples for use in watch faces.
- smooth second hand for GTR 3;
- smooth second hand for GTR 4;
- change the background with a button on the screen;
- switching between different elements with a button on the screen;
- starting vibration;
- data output at an angle;
- data output in a circle.
Does anyone know the necessary code to display/hide elements of the AOD screen, by pressing a button on the main screen?
SashaCX75's sample code only works to show/hide main screen elements, but not in AOD.
santicam
Another doubt that I have. I need to change the background image of the AOD screen by pressing a button on the main screen, but the sample code does not work.
The same thing happens to me as in the previous case. It is not possible to change the AOD screen background image using SashaCX75's sample code, only the main screen image can be changed. Does anyone know how to do it?
Аватар користувача
ZduneX25
santicam писав: 15 лютого 2023, 12:58
@SashaCX75's sample code only works to show/hide main screen elements, but not in AOD.
I had to add SysProSetBool then SysProGetBool to pass a variable and make AOD display exactly what I wanted.
santicam
ZduneX25 писав: 15 лютого 2023, 14:22
Thanks ZduneX25, but I don't know how to use this in the index.js javascript code.
Please can you post a js code example of how to use SysProSetBool and SysProGetBool?
Thank you so much.
Аватар користувача
ZduneX25
santicam above initview() add:
Код: Виділити все
hmFS.SysProSetBool('a_word', false);
then inside initview():
Код: Виділити все
const bool_name = hmFS.SysProGetBool('a_word')
in the place you want to control:
Код: Виділити все
hmFS.SysProSetBool('a_word', true);
if (screenType = hmSetting.screen_type.AOD)
and finally:
Код: Виділити все
if (bool_name === true) {
    dial2_normal_step_circle_scale.setProperty(hmUI.prop.VISIBLE, true);
} else {
    dial2_normal_step_circle_scale.setProperty(hmUI.prop.VISIBLE, false);
Аватар користувача
A small utility for converting images from a watch face to a regular Png and vice versa, into the format required for watch faces.
Unlike the editor, the image should be converted with less loss, this will be especially noticeable on images with a gradient.
It can also be useful if you just want to translate the watch face without changing anything else in it.
demiurg1
З нами з: 23 лютого 2020, 22:49
Has thanked: 23 times
Been thanked: 17 times
Повідомлення demiurg1 »
A very useful tool. It's a pity that it can't handle encrypted image files.
But it's nice to have a program like this.
1mylord
З нами з: 18 січня 2022, 02:52
Повідомлення 1mylord »
Thank you always.
Can you tell me the address of the compass shortcut?
santicam
Thanks ZduneX25, but I'm still having problems with SysProSetBool/SysProGetBool.
I've tried your suggestions, but can't get them to work in my project.
I will send you my code via telegram. Please, if you can, take a look to see what I'm doing wrong.
Аватар користувача
1mylord
Код: Виділити все
hmApp.startApp({ appid: 1, url: 'CompassScreen', native: true })
Аватар користувача
Version 7.0
Mirror
demiurg1
Do the changes in version 7.0 also apply to editable watch hands? I don't think so because I don't see that option.
Аватар користувача
Been thanked: 2122 times
Повідомлення asoo »
demiurg1 писав: 01 березня 2023, 09:02
I am not sure you mean this function or not ?
Зображення
demiurg1
OK. I didn't check where it should be.
Відповісти
Хто зараз онлайн
