搜索找到 6 个匹配
Return
28 1月 2023, 17:26
Jump to forum
Jump to topic
Re: System Shortcut Features equiv in zeppOS watchface?
Here is a list of all the parameters related to training
SportAutoRecogScreen
SportCategoryListScreen
SportEditScreen
SportListScreen
SportPickerScreen
SportRecordListScreen
SportScreen
SportSettingAssistantScreen
SportSettingAutoLapScreen
SportSettingAutoPauseScreen
SportSettingBackScreen ...
Stas
12 1月 2025, 19:50
Jump to forum
Jump to topic
Re: AmazFaces for Android [Support]
We’ve made the necessary changes to ensure the app becomes compatible with your device. The update will be available soon, and you’ll also be able to download the APK directly from our website.
Google Play says AmazFaces app is not compatible with my Redmi 8, Android 10, works fine on Redmi K70 ...
T_5
01 6月 2023, 10:01
Jump to forum
Jump to topic
Greetings,
Here is the essential diff of API 2.0 vs. API 2.1 in GTR4 via dumping simulator's device image:
--- dump_gtr4_api2_0_simple_2.txt 2023-06-01 18:54:14.815758019 +0900
+++ dump_gtr4_api2_1_simple_2.txt 2023-06-01 18:54:06.031868273 +0900
@@ -1,7 +1,7 @@
.Object=function ...
31 7月 2023, 13:08
Jump to forum
Jump to topic
@ZduneX25 It can be installed in the same way as a regular watch face. But this is not the best way. With this method, the program can only be uninstalled using a third-party file manager utility. And if the program has an app-side part, then it will not work.
13 4月 2023, 17:46
Jump to forum
Jump to topic
Re: New GTR Mini
ZduneX25 I don't plan to add terminal mode work. A little later I will clean up the code and post it. Then whoever wants can remake it to their needs.
25 5月 2023, 04:54
Jump to forum
Jump to topic
Re: Plum Watchface with more colors
This watch face is made using encrypted code and therefore cannot be modified by normal means, if you need any modifications, it is recommended to contact the owner. watchface directly
