Search found 5 matches
Return
by SashaCX75
11 Jan 2022, 18:47
Jump to forum
Jump to topic
Dema
No, this cannot be changed for a set of images. To change this for circular or linear progress you need to open the watch face, in the "watchface" folder open the "index.js" file. In this file, find the line let progressHeartRate = (valueHeartRate - 71) / (targetHeartRate - 71); and in it ...
by SashaCX75
13 Dec 2022, 18:17
Jump to forum
Jump to topic
A collection of code examples for use in watch faces.
- smooth second hand for GTR 3;
- smooth second hand for GTR 4;
- change the background with a button on the screen;
- switching between different elements with a button on the screen;
- starting vibration;
- data output at an angle;
- data ...
by ZduneX25
15 Feb 2023, 14:22
Jump to forum
Jump to topic
Does anyone know the necessary code to display/hide elements of the AOD screen, by pressing a button on the main screen?
@SashaCX75's sample code only works to show/hide main screen elements, but not in AOD.
I had to add SysProSetBool then SysProGetBool to pass a variable and make AOD display ...
by ZduneX25
16 Feb 2023, 09:32
Jump to forum
Jump to topic
santicam above initview() add:
hmFS.SysProSetBool('a_word', false);
then inside initview():
const bool_name = hmFS.SysProGetBool('a_word')
in the place you want to control:
hmFS.SysProSetBool('a_word', true);
if (screenType = hmSetting.screen_type.AOD)
mFS.SysProSetBool('a_word', true ...
by brunoandreotti
27 Jul 2023, 03:57
Jump to forum
Jump to topic
Is there a way to add an custom AOD to use even with different custom watchfaces?
