Messaggio da SashaCX75 »
Version 7.3
Fixed known display bugs.
v 7.2
v 5.0
v 4.1
v 4.0
v 3.1
Added French.
Added support for T-Rex Pro.
Found bugs fixed.
v 2.1
Fixed bugs in display AOD.
Added support for AOD.
Added Chinese translation.
v 1
Added English translation.
v 1.2 Added Spanish language
Ultima modifica di SashaCX75 il 01 giu 2022, 07:19, modificato 32 volte in totale.
Pal57
Add new png files to the project folder. Reopen the json file of the project. Before opening the project file, the editor will offer to save the changes made.
KoltesPunti
Messaggio da KoltesPunti »
SashaCX75 ha scritto: 08 mar 2021, 17:47
@KoltesPunti
If by "Starimage" we mean the image that appears when the goal of the steps is reached, then it is not yet known how to show it.
Yes i meant the goal of the steps! Ok thanks!
wolfgangausw
Messaggio da wolfgangausw »
SashaCX75 ha scritto: 08 mar 2021, 17:50
wolfgangausw ha scritto: 08 mar 2021, 17:06
@Naddus
Yes, I lnow. I want to show the broken connection on the idle screen.
My editor doesn't support idle screen (AOD) yet. And, as far as I know, in this mode you cannot display status icons, including bluetooth.
Thanks for the answer
eliasf
Messaggio da eliasf »
KoltesPunti ha scritto: 08 mar 2021, 16:59
Nice Job mate ;)
Is there a function for the Starimage on GTS2? (like on the gts)
If you re not using the Image Progress for displaying the Steps progress on that particular wf then you can do the following:
Specify only two images for steps image progress instead of the default 10. Your first can be a blank image or just matching the background and the second should be your star image.
That way as soon as you reach the steps goal it switches to the second image and simulates what you want to achieve.
demiurg1
Has thanked: 23 times
Been thanked: 17 times
Messaggio da demiurg1 »
SashaCX75 ha scritto: 08 mar 2021, 15:36
@demiurg1
Make sure to extract all files from the archive. Go to the program settings and click the "Reset" button. Restart the program.
Yes, I unpacked everything properly. Nothing is missing, because all watch faces unpack correctly except this one. Shows unpacking, but does not display any files, just a LOG file with an error indication.
This is also correct: "pack_unpack_dir": "C: \\ xxxxxxxxxxx \\ Tools \\ main.exe"
Once again I am providing the link to this watch face (in Dropbox):
https://www.dropbox.com/s/gkm7um6yehifk ... e.zip?dl=0
The reset in the program did not change anything either.
mickdu59
Messaggio da mickdu59 »
Good work Sacha 👍😁
I wait to finish it to have the on / off on the icons bluetooth, Lock, NDP, alarm
kontranik
Messaggio da kontranik »
this can be shown with help of StepsProgress as ImageProgress:
two images needed: first Image is blank and second with starimage
kontranik
demiurg1 ha scritto: 08 mar 2021, 19:50
@demiurg1
in log is this line:
2021-03-07 22:42:11,806 - root - WARNING - Resource is not an image
2021-03-07 22:42:11,806 - root - ERROR - Image signature doesn't match.
that says it all.
not all bin files can be unpacked with this util from Sasha
demiurg1
kontranik ha scritto: 09 mar 2021, 08:36
@demiurg1
that says it all.
Oh. I didn't know that there might be some files packed in a BIN file that couldn't be properly interpreted (recognized). Thanks for the info.
rubiales41
Messaggio da rubiales41 »
hello, how much can the sphere weigh in megabytes, at most ?, for GTR 2?
demiurg1
This watch face doesn't really unpack. But in your first message there was a screenshot with an error that has nothing to do with the dial.
If it helps, here are the resources from this watch face.
Allegati
Young_And_Clear.zip
(305.02 KiB) Scaricato 411 volte
Ultima modifica di SashaCX75 il 09 mar 2021, 16:15, modificato 1 volta in totale.
rubiales41 ha scritto: 09 mar 2021, 12:43
No one has yet figured out the maximum possible size of the dial and whether there is a limit at all. But with large dials, the clock works slower.
rubiales41
SashaCX75 ha scritto: 09 mar 2021, 15:24
thanks, I come from an amazfit gts, where the maximum size is 1.5 megabytes, and it is a real headache.
KoltesPunti
eliasf ha scritto: 08 mar 2021, 19:46
Nice Job mate ;)
kontranik
I already use the Step Progress function in this Watchface - so this is not an option for me ;)
Version 1.2
AlterEgo
Messaggio da AlterEgo »
I cannot find Shortcuts in this version (1.1). So I have to edit those directly in json?
And also this version unpacks very few GTR 2 watchfaces, but same watchfaces do unpack
using GTR/GTS/t-rex/Verge version (version 10.0).
The editors for GTR and GTR2 are different and not compatible with each other.
There are no shortcuts in the editor because I have not yet seen a single watch face where they work.
Negesin
Messaggio da Negesin »
thanks for your work!
NeoPhyTe-x360
Messaggio da NeoPhyTe-x360 »
Nice @SashaCX75 ,
Good work like ever
Regards
demiurg1
Great job as always, Sasha. Even the lack of Polish language does not bother me. It is a pity that the Chinese did not introduce other interesting functionalities, such as in the GTR 47.
demiurg1
SashaCX75 ha scritto: 11 mar 2021, 18:05
Best regards
Demiurg1
MichaRe
Messaggio da MichaRe »
This is one of my first watch faces with the new editor from Sasha. Many Thanks :D !
It works, but this is still in beta. The final is underway.
The packed file has a size of 539 kB.
I solved the problem with Bluetooth "off" by an overlay in my background file (picture 0000). It's a workaround and a little tricky, but it works:
All status icons are initially gray on the background image. Only the active Blootooth symbol is colored. Finaly I select a gray overlay fot the Blootooth symbol in the editor.
Sorry for the static picture. This version of the editor does not yet create any animated gifs.
Ciao ...
Micha
kk171189
Messaggio da kk171189 »
@ SashaCX75. Thank you very much for you work. i really appreciate your efforts. I tried to download the app but it seems the link is not working. If you could, please provide the another source to download the app.
Thank you once again.
demiurg1
I checked and the link works. Try again. This is the same Dropbox link: https://www.dropbox.com/s/hm22uuqp5hoy4 ... 2.zip?dl=0 .
bvannier
Has thanked: 10 times
Messaggio da bvannier »
Good evening,
Does anybody knows which firmware fixes the frozen seconds-hand?
This happens sometimes on my gtr 2
V5.1.0.4
Think you
Torna a “Watchfaces tools”
