https://i.postimg.cc/g28GYVds/en.gif
Not all dials can be unpacked ...
Se encontraron 10 coincidencias
- 07 Mar 2021, 10:37
- Jump to forum
- Jump to topic
- 16 Mar 2021, 14:30
- Jump to forum
- Jump to topic
I just guess. In fact, it happens that the seconds hand "freezes" for a while in some watch faces. The GTR 2 stores all loaded watch faces and may run out of memory. It may also be caused by an overly large BIN file (with some applied graphics) which has to be processed by the watch firmware. It can ...
- 17 Mar 2021, 15:15
- Jump to forum
- Jump to topic
Of course the editor will be updated and new features will be added. But it takes time.
- 21 Mar 2021, 14:18
- Jump to forum
- Jump to topic
Salut,
1) Use "unpack compressed .bin " button and choose the bin file you would like to modify
2) This will create a new folder in "Watch_face" folder with png and json files
3) Replace english png files by french ones and adjust positions if needed (this will modifiy json file)
4) Save json file ...
- 25 Mar 2021, 12:00
- Jump to forum
- Jump to topic
- 05 Oct 2022, 07:23
- Jump to forum
- Jump to topic
bvannier
No, that won't work. If you want to check the operation of this method, then you need to change the "hour_array" parameter (line 194) in the ready-made dial index.js file by adding the necessary images to it
- 19 Ene 2021, 21:10
- Jump to forum
- Jump to topic
Re: GTR 2 watchface...
idimas, uses Huami open platform for developers. He made a video in his channel and explains how to do it, even if it is in Russian, however explanatory.
https://www.youtube.com/channel/UCCvb6XT-3YqhLXXcJY3MXlg
I also registered on the huami site and am awaiting evaluation for access, hopefully good ...
- 21 Ene 2021, 14:54
- Jump to forum
- Jump to topic
Online usage only.bvannier escribió: 21 Ene 2021, 08:17Good morning, after being certify "developper" by dev.huami...., do you dowload a software on your computer, and do you have to be on line to use it?
regards
- 22 Ene 2021, 00:04
- Jump to forum
- Jump to topic
idimas
Thank you so much for your video explaining the Huami tool, I have mine working on my device and I am thrilled with it - almost ready to post here.
Was wondering if you or anyone had any insight as to how the "jump" feature works - I defined a hot spot zone and put a transparent image in ...
