Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
macgd016
Post by macgd016 »
SashaCX75 wrote: 05 Jan 2021, 19:43
@macgd016
Reset the settings. Do not change the path to the packer.
Many thanks for that, all working again.
Is there any way to obtain the 'distance' in miles instead of km?
noender
Set the Animation Time parameter equal to the Animation speed parameter or twice as much.
NikiWafa
No, there is no possibility to add an altimeter.
macgd016
No, this cannot be done in the editor.
It is possible to manually edit the json file before creating the bin file, but it is difficult.
ivasfc
Post by ivasfc »
Hi! I´m having problems to compile the archives for GTS WF. When I click to compile, and I select the modified json, nothing occure. Can you help me, please??
noender
Post by noender »
Thank for your responses SashaCX75
After a LOT of testing I think I found a problem within the "Move Between Coordinates" function. If the image is numbered"0036" or over, it does not render in the watch. However, It does render correctly in the preview and the "Animation Preview", but once the watch face is installed in the watch, those images do not show. Do you think it is fixable?
Thank you!
noender
Images for animation should not be the last in the list. I don't know any other dependencies on the image number.
noender
Post by noender »
Correct. I did tests with different parameters and the consistency was that any images after "0035" (0036, 0037...) do not show in the installed watch face. As far as I know this is the only function with this issue. I'll let you know if I find anything else. Thank you.
NikiWafa
Post by NikiWafa »
Hello SashaCX75 I am a newbie, I really like your program
I tried to make WF with Javanese calendar, the calendar only has five cycles. I tried it on the IMAGE COUNT on DAY OF THE WEEK, I filled it: 5, but why after I tried the cycle still 7?
May You Understand in my Language :)
NikiWafa
The watch only supports the Gregorian calendar.
The number of pictures for the days of the week can be set 7 or 21 (7 days for 3 languages, I did not fail myself, but in earlier versions it was possible to set only 21)
1immortal
Post by 1immortal »
Getting this after the trial of the GTx2x unpacker from 4pda:
2021-01-18 16:47:06,699 - root - DEBUG - Opening watch face 'D:\GTR_Watch_face_(without_Python)\Watch_face\uncomp.ifellclassic-433119-a7525b1ea0.bin'
2021-01-18 16:47:06,704 - root - DEBUG - Reading parameters...
2021-01-18 16:47:06,704 - root - INFO - Reading header...
2021-01-18 16:47:06,705 - root - INFO - Header was read:
2021-01-18 16:47:06,705 - root - INFO - Signature: b'UIHH\x02\x00\xff', Unknown: 4294967295, ParametersSize: 4294967295, isValid: False, deviceId: 59
2021-01-18 16:47:06,706 - root - DEBUG - Parsing parameters...
2021-01-18 16:47:06,706 - root - CRITICAL - 'Reader' object has no attribute '_parameters'
File "program.py", line 164, in parseResources
File "watchFaceParser\reader.py", line 13, in getParameters
AttributeError: 'Reader' object has no attribute '_parameters'
1immortal morta
The program does not support and will not support GTR 2
1immortal
Post by 1immortal »
SashaCX75 wrote: 19 Jan 2021, 19:30
@1immortal morta
Got it, thanks for clearing that out.
Will a new app be made for GTx2x or you're dropping the entire project?
Sorry if I'm being too intrusive.
BR,
Pavel
1immortal
Perhaps there will be a new application. But there is no time to do this now.
cmelcher78
Post by cmelcher78 »
jeffrey38 wrote: 22 Dec 2019, 15:30
For GTR2? Compressed?
conchodaus
Post by conchodaus »
Thank you SashaCX75 for the great Watchface Editor!
I´m having problem with the animation function for GTS WF. I have tried everything but not work. Before packed, i checked total size <1.5mb, don't put image's animation in the end, installed window 10...But animation don't work. I even downloaded a watch face with animation in forums, unpacked and packed it again without fixing anything, the animation still does not work...
Do I need to install additional plugin to software? eg dotnet, visual c ++, or java or anything...?
conchodaus
If a bin file is created, you do not need to download anything additionally.
Does animation work on other watch faces? Not all models and not all firmwares support animation.
Pistinnaga
Post by Pistinnaga »
Hi guys, what's the difference between "pack" and "compress" bin files? Only the size?
Immagine 2021-01-22 161013.png (5.47 KiB) Viewed 12377 times
conchodaus
SashaCX75 wrote: 22 Jan 2021, 15:09
@conchodaus
I tested watchface gts in forum. Animation work well. But when i unpack file .bin have animation and pack it again. Animation don’t appear anymore.
franluciani
Has thanked: 9 times
Been thanked: 6 times
Post by franluciani »
Hi, do you know if there are some tool for create watchfaces for Honor Band 6?
Joniariete
Post by Joniariete »
I pack the bin and then I get firmware error, and with just one unpacking it and only packing it gives me a firmware error
its a t-rex watch
why??
pmedina2222
Post by pmedina2222 »
Please, does anyone know a decompressor for GTS 2 .bin files?
JPinTX
Post by JPinTX »
I just want to thank SashaCX75 for all the hard work it must take to create and support a tool like this. I have learned a LOT from reading everyone's questions/answers and spending hours learning how to use the tool and improving my image editing skills (hint: your question has probably been answered before, so search through the forum and you'll probably find answers/suggestions to try). I struggled at first, but taking the time to try, research, try again until I figure issues out has led to me creating over a dozen watch faces. I don't think I could ever live with a standard watchface again. I hope this tool lives on through firmware updates on my GTS and hope new watch versions (e.g. GTS2) get supported in the future. Thanks again!
Been thanked: 2122 times
Version 10.0 Beta for "GTR , GTS , T-Rex , Verge Lite "
Link :
https://github.com/SashaCX75/AmazFit_Wa ... v10.0-beta
Thank SashaCX75 for the best program
demiurg1
Has thanked: 23 times
Been thanked: 17 times
Post by demiurg1 »
It's nice that you are developing this program. I just downloaded the 10.0-beta. I just hope that someday you will be able to extend the program to support GTR 2. Thank you for your work so far.
andand1
Post by andand1 »
Hi guys. I looked online but i cannot find an answer. It's possible to edit a ZEPP watchface? i'm very into the "fluorescence" watchface but i do not know how to "extract" this one from zepp. Any advice? thank you in advance :D
OldManGir42
Post by OldManGir42 »
So...
I just started using this editor today for my Amazfit X and I'm finding myself having a weird problem. No matter how I save the main background image (in this case 0061.png) I can't seem to get the watch face to compile. I've tried the troubleshooting steps in the stuck post and I've even tried opening the original and overriding it with the exact same settings, but it doesn't seem to help...I'm not sure what else to do, and unless I missed something in the 20 pages of responses on this thread, I don't see anyone else posting a solution...
