https://i.postimg.cc/PrMjngqJ/2020-09-14-19-39-23.png
Not all ...
Pesquisa resultou em 4 ocorrências
- 17 Dez 2019, 17:06
- Jump to forum
- Jump to topic
- 05 Jan 2021, 19:40
- Jump to forum
- Jump to topic
Re: AmazFit WatchFace editor for Windows by SashaCX75
noender
1 No. Read the first post in this thread.
2 No, the size of the image depends on its size in pixels, there is no scale.
3 For animation of movement, you can add different images on different lines. There are dials where this animation works.
- 06 Jan 2021, 15:30
- Jump to forum
- Jump to topic
noender
Set the Animation Time parameter equal to the Animation speed parameter or twice as much.
NikiWafa
No, there is no possibility to add an altimeter.
macgd016
No, this cannot be done in the editor.
It is possible to manually edit the json file before creating the bin file, but it is ...
NikiWafa
macgd016
- 07 Jan 2021, 12:41
- Jump to forum
- Jump to topic
noender
Images for animation should not be the last in the list. I don't know any other dependencies on the image number.
