Has thanked: 14 times
Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
maortrol wrote: 06 Jun 2020, 22:26
SashaCX75 wrote: 05 Jun 2020, 15:19
Where is that option located? Can't find it... Thanks in advance! ;)
[mention]xMrPhede[/mention]
See the first post in the thread.
I am using XnView. If you work in Photoshop, it is better that there is at least one transparent pixel in the picture.
xMrPhede
Post by xMrPhede »
[mention]SashaCX75[/mention]
Thanks for your answer, i added a transparent pixel and I got it working, but still the watchface doesn't work on my GTS, I think because of its weight, but I'm not sure
watch996
Post by watch996 »
SashaCX75 wrote: 02 Jun 2020, 14:36
@watch996
Your dial on the third link saved for GTR was set normally for me.
When using weather, I recommend that you always add weather day / night (you can use it outside the screen if it is not needed.
thank you for the answer. the weather did not work for me.
could you help with opening this ?
https://amazfitwatchfaces.com/verge-lite/view/264
[mention]watch996[/mention]
This dial has a problem with the arrows, so normally it does not decompress. There is no weather on this dial.
https://drive.google.com/file/d/10GyaJq ... sp=sharing
If the watchface is installed but the weather does not appear, then most likely these are Amazfit program errors. Turning GPS on the phone helps some. Some use the program "Notify & Fitness for Amazfit", it seems like you can change the weather server.
watch996
Post by watch996 »
SashaCX75 wrote: 08 Jun 2020, 15:56
@watch996
thank you
watch996
Post by watch996 »
@watch996
mybe this one ?
https://amazfitwatchfaces.com/verge-lite/view/255
Taahz
Post by Taahz »
Hi, I don't know if i'm in the right place, but I created a watchface with time and date and it works but if I add a battery indicator with several pic I add then I can't sync on my watch, any idea why?
wing0826
Has thanked: 9 times
Post by wing0826 »
hi, i am a beginer to make watchface
when i try to compressed bin, i dont know why nothing happen...
can someone help me? thanks!
maortrol
Has thanked: 27 times
Post by maortrol »
wing0826 wrote: 25 Jun 2020, 13:50
Check the transparency of the 0000.PNG image, it must be enabled (I use Microsoft Paint 3D: upper menú - Canvas - Transparent Canvas : enabled).
wing0826
Post by wing0826 »
maortrol wrote: 25 Jun 2020, 14:09
thanks your reply!
i got it!
shlide
Post by shlide »
Awesome tool and thank you for releasing it for the community!
I'm having issues with the Shortcuts on watchface https://amazfitwatchfaces.com/gtr/view/6635
I couldn't get Veahcen's Marine Commander from https://amazfitwatchfaces.com/gtr/view/1483 to load so I took WakeUpich's Marine Commander from https://amazfitwatchfaces.com/gtr/view/1549 and started back filling the images. I also brightened up some images. and all of that works fine. As soon as I add a shortcut over the weather area, it fails to load on my watch. I've used other faces that have working shortcuts on my watch. Is there something special that needs to happen to get shortcuts to work on this watchface (https://amazfitwatchfaces.com/gtr/view/6635)
Just had a thought - can we have shortcuts on analog watchfaces with the hands "moving in front of" the shortcut area?
[mention]shlide[/mention]
Try adding the day / night temperature off the screen. At GTR 47, it helped.
wing0826
Post by wing0826 »
I have a question...
when I want to use AM/PM
code is right
but the image of the bin file is error after I updated
it always take the number 09 &10 to AM/PM?
shlide
Post by shlide »
either I added the day/night temperature wrong, or it didn't work.
I'm going to try downloading another watchface with working shortcuts and see if I can unpack and repack it to see if it works. The one I like is joebar78's Nightlights: https://amazfitwatchfaces.com/gtr/view/2660. that one lets me pack and compress and install correctly on my 42mm watch.. I'm also only uploading the Packed bin, not the Packed_zip bin. is that the correct thing to do?
There is no difference in the operation between the files * _packed_zip.bin and * _packed.bin. The _packed_zip.bin file is installed a little faster, this is all the difference.
I can only test on GTR 47 and the watchface works with these settings for me, check to see if it starts up with you.
https://drive.google.com/file/d/1jWrqie ... sp=sharing
Evilmind_04
Been thanked: 14 times
Post by Evilmind_04 »
I am busy editing a watchface and keep running into the same problem.
It keeps telling me "unknown whatchface 16" twice.
Got no idea why, in Sacha's program it all looks fine but when i pack & compress bin its the first thing it says, if i do try it on my gtr it just wont load.
Does anyone have the solution?
shlide
Post by shlide »
[mention]Evilmind_04[/mention]
I've seen previous posts in this thread that say that message is okay to see.
The message "unknown whatchface 16" refers to the creation of a preview of the packaging utility for the bin file, and does not affect the operation of the watchface.
To understand what exactly does not work, it is better to apply a link to the project or at least a json file.
If the weather is used, then in 70% of cases, adding day / night temperature off the screen helps.
If you just write that the watchface does not work, then no one can tell you the reason.
Evilmind_04
[mention]SashaCX75[/mention] thanks for the reply.
i thought maybe that was the problem, i do make / edit the images in photoshop and had an idea something went wrong.
Current weather is turned on and did try to add day & night weather but for now it doesnt make any difference.
i uploaded the bin files (normal & zip) : https://drive.google.com/drive/folders/ ... sp=sharing
thanks in advance for your help :) .
As I wrote, the problem was in the absence of temperature day / night.
PS. It’s not enough to just turn on the temperature; you must also set the “ImageIndex” parameter.
You have not yet set the parameter "Error symbol" for the weather. Because of this, the dial may not display correctly (see the photo in the bottom right corner).
https://drive.google.com/file/d/10FpUpr ... sp=sharing
PS2. Files 0004.png and 0073.png (file names might have changed during unpacking) for the second hand and date are the same. Why make two identical files? The bin file size allows you to add a normal picture for preview, rather than reducing it to 1 pixel.
Evilmind_04
[mention]SashaCX75[/mention] thanks alot for your help. 👍🏻.
I send the ones without day/night because it didn't made any difference of working but didn't add the image parameter.
Do you always have to activate them to get the weather working properly? See many watchfaces without it.
I did change the images you chose for the day/night weather for blank ones and now it looks okay.
The error symbol for the weather was included in the bin file, no idea why it didn't show it for you but it's working after choosing it again 😅.
The 2 images who looks the same, before one had a different color.
About the preview image, I got it replaced because the program sayd it will surpass 1.9 mb and might gives a problem.
Many whatchfaces I unpacked have the preview image replaced so it saves size.
Still got a few small thing to fine tune but this is it working at the moment.
It is not always necessary to add day / night temperature, but this is the first thing I check if the dial does not work.
"Error symbol" for the icon and for the text are different values. The second parameter is usually forgotten.
The size of the image for preview does not have to be reduced exactly to one pixel, the main thing is that the size of the bin file does not exceed the maximum. For GTR 47, it usually works normally if the size is up to 2MB, but if the size is close to the maximum then you need to check.
Evilmind_04
[mention]SashaCX75[/mention] i will keep all the options in mind so won't run into another non working watchface 😅.
Thanks again for you're help and thanks for making this program, I know me and many others do appreciate it alot 👍🏻.
shlide
Post by shlide »
Thanks, the weather trick worked this time. I made sure to do the day/night temperature larger than a 0,0 box for both day and night and it's working now. Thank you for the help!
Users browsing this forum: Google Adsense [Bot] and 2 guests
