Mano.Laikrodis wrote: 15 Mar 2026, 08:03
Hello, I would like to ask why does adding ttf does not work? I mean it shows as though it is added, but it is still using system fonts i guess. How do i make it use my added font?
Edit: All is working, somehow my system can use this ttf font, but editor does not, although other fonts do work. Sorry.
Please send me the project where the font isn't displaying, and I'll have a look.
Been thanked: 2122 times
demiurg1 wrote: 15 Mar 2026, 10:48
Question: https://amazfitwatchfaces.com/balance/view/744
Can this watch face be converted into a watch face compatible with the GTR3 using the editor?
I was unable to import this watch face into the editor.
demiurg1 wrote: 15 Mar 2026, 13:09
Unfortunately, I was unable to create numerical seconds running around the circumference of the watch face for the GTR 3. That's what I cared about most. It's probably not possible for this model.
It is possible to do that. On GTR3, Have someone modified and convert my watchface to GTR3 and it's working on now.
https://amazfitwatchfaces.com/gtr/view/44643
demiurg1
Has thanked: 23 times
Been thanked: 17 times
Post by demiurg1 »
Thank you.
It loaded correctly onto my GTR 3 smartwatch, and most importantly for me, the numerical (digital) seconds hand moves around the dial.
Is it possible to import this dial into the editor and modify it to another language? In the Saha editor, the ZIP file unpacks correctly, but I can't do anything with it because only "Bacgound" is available for editing. The parameters are imported, but they can't be edited.
demiurg1 wrote: 16 Mar 2026, 08:47
Thank you.
If you're referring to the GTR3
that file cannot be unpacked in the editor because the creator has uglified the index.js file. Therefore, if you want the unuglified file,that can unpack with editor , I recommend contacting the creator.
If you just need to translate the text, there’s no need to load the project into the editor. You can simply unpack the watch face in the editor to extract the images, translate them, and repack them in the editor. Then, in the original watch face file, replace the image files with your own from the repacked watch face.
You can even manage without the editor altogether. There is a utility for converting images to a standard format and then to the ZeppOS format.
demiurg1
Post by demiurg1 »
Thanks, I'll try.
sadc
Post by sadc »
Thanks Sasha fro your great work!
Do you plan to add the "inversion" option to the Circle progress bar in BioCharge?
sadc wrote: 17 Mar 2026, 10:42
No. That’s not possible at the moment.
sadc
Post by sadc »
Hi Sasha,
I've found a little error in the Italian translation.
When selecting the days of week via font, the program puts the following string in the name of week field:
Lu,Ma,Me,Gi;Ve,Sa,Do
There is a ";" instead of "," between "Gi" and "Ve"
sadc wrote: 18 Mar 2026, 12:41
Hi Sasha,
I'll fix it.
sadc
Post by sadc »
Hi guys!
If I had to switch from Windows PC to a Macbook Air, is there a (simple) way to run the Watch face editor on it? Is anybody doing it in this forum?
Thanks in advance!
From Windows to Mac :o
Emiliomc
Post by Emiliomc »
Hello. I'm not sure if I'm doing something wrong. When the background sphere in a project is not a color but an image (PNG), and I add it to the AOD and package the project, the background sphere image in the AOD "shakes" if it's made up of several PNG images. I don't know if this can be fixed.
Emiliomc wrote: 01 Apr 2026, 08:26
I'm not sure which device you're referring to, and what kind of shaking you're experiencing.
For some devices, like "Balance", if the background image in AOD has a gray tone, when using AOD , the screen will have a greenish tint and "flicker." If this happens, I recommend make the AOD BG png to black, which will reduce the flickering. But if you mean that when entering AOD, the screen "shakes" up and down, left and right in a rhythmic way at certain times, this is the system adjusting the screen to prevent pixel burn. This cannot be fixed; it's a requirement in the firmware.
I'm not sure what kind of shaking you're referring to.
But if the problem isn't either of the two types mentioned, I recommend attaching your project for who want to help you , they will easier review, or at least providing a video example of the problem.
Note : If possible, it's recommended to ask your question in the "Device-Related" section.
Emiliomc
Post by Emiliomc »
Thank you so much for your help. It is indeed a Balance 2, and it was the first scenario you mentioned. The dial I created has several layers (PNGs) with black and gray colors. What you described is happening. When I create a dial for the project using all black colors for the AOD, this problem is resolved. But now I've encountered another issue. The transition from the on-screen display to the AOD display is abrupt. The first thing it does is switch from gray to black, and then the brightness decreases. This all happens in a fraction of a second, but it looks rather clunky. Also, I can't find the section you suggested I look in. My apologies.
Emiliomc wrote: 02 Apr 2026, 21:20
I don't have a Balance 2, so I can't answer your further questions.
Regarding that section, if you want to ask about watchface issues for the Balance model, I recommend checking out the topic:
Amazfit Watch faces Board index Amazfit watches (Global) Amazfit Falcon, Cheetah, Balance, Active Watchfaces discussion
viewforum.php?f=178
ComerFeng
Post by ComerFeng »
Where is the app to be download? I cann't see it.
ComerFeng wrote: 05 Apr 2026, 15:23
Click on " Version 16.1 " and click on "Archive"
you can select Download from Dropbox or GoogleDrive
ComerFeng
Post by ComerFeng »
Great! I am wondering of it!
EmaPolice
Post by EmaPolice »
I have a question. If I want use custom font function e not PNG for numbers, where I need to put ttf font file? For example in a folder called "font" but where? In root or in asset folder created? Sorry for my English and thanks in advanced
EmaPolice wrote: 10 Apr 2026, 20:07
There is a button in the editor for adding a font. Click it, and the font file will be copied to the correct directory.
EmaPolice
Post by EmaPolice »
How? The button is greyed out
https://ibb.co/SDSWvpgy
EmaPolice wrote: 10 Apr 2026, 21:01
If you see any part grayed out in the program,
it may mean:
1. That watch model doesn't support that feature.
2. Or it may mean the widget isn't enabled yet.
But from the image you sent, you're using a GTR3, so it's likely first reason.
EmaPolice
Post by EmaPolice »
Solved by change watch model in T-Rex Ultra (my whatc) model. Now I can set custom font. Many thanks guys.
Version 17.0
Puckersunch
Post by Puckersunch »
I get the following error when using a font:
Could you advise, what I am doing wrong? The font is copied into the fonts folder inside the assets folder of the project.
