anuraag488
Post by anuraag488 »
I'm using font to create watchface for bip 6. When i hover over size there is a message about size that "it is not recommended to set a size larger than 150". Why?
@anuraag488
Because a large font size may not be displayed on the watch. The value of 150 is an approximation. It may vary depending on the model and firmware of the watch.
rush2112
Has thanked: 119 times
Post by rush2112 »
@SashaCX75
Air Quality (AQ) ( Balance ) :D
I just wanted to give a quick update about my Amazfit Balance. The Air Quality (AQ) feature was working perfectly after the last update (version 3.26.4.1). However, now it’s just blank, even though I’m on the latest firmware. It’s not showing up on my face watch or in the app. I’ve contacted the Amazfit support team and sent them pictures showing the blank AQ display and explained the issue. I hope they can fix it. Has anyone else experienced a similar problem?
anuraag488
SashaCX75 wrote: 27 Jun 2025, 08:57
We do not use the 12-hour time format. Therefore, I do not know the specifics of its use. How common is it to display only numbers without AM/PM designation. I don't think it is common. That is why there is no option to switch it off in the editor.
And as I wrote in the post above you can use a set of images instead of a font. If there are no necessary images they will not be displayed.
You should consider adding an option to remove am/pm. Everytime editing that js file after modification is painful.
frankh93
Has thanked: 24 times
Post by frankh93 »
@anuraag488 its not that complicated to edit the lines to remove the AM/PM, in 2 mins you get it dont and ready to use.
@SashaCX75 is there a way to make the watch vibrates as feedback? im making a watchface with a menu to change some styles and colors, but i'd like to make it vibrates when tapping a button, is that possible?
@frankh93
An example of vibration can be seen if you set a switchable background.
AlexisZ
Post by AlexisZ »
I create a watch face and add animation to it, but when I put it on the watch, everything comes out except the animation. I have a GTR 3 Pro. Is there a solution?
Been thanked: 2122 times
AlexisZ wrote: 07 Aug 2025, 22:46
Recommend that you submit the project you're having trouble with with your question, as the information provided may be difficult to answer.
However, are you following the animation requirements?
Files in the animation folder must be named according to the specified format:
And for frame animations in ZeppOS 1, it's recommended to have at least six images, as sometimes fewer than that number will cause the animation to fail.
If you use less than 6 images to make an animation, although the preview is displayed normally in the editor, when installed on the clock, the animation may not be displayed.
If you follow these steps and your animation still doesn't work, i think you'll need to attach your project for review.
AlexisZ
Post by AlexisZ »
asoo wrote: 08 Aug 2025, 00:21
Yes, I just read the solution on previous pages, thanks, the one that should start at 0 worked.
frankh93
Post by frankh93 »
@SashaCX75 tysm, i was able to use it in the watchface i just posted but i'd like to hide the settings menu like when the screen gets off... there's a way to detect when the screen gets off?
Bresbres
Post by Bresbres »
hi there i want to install the latest version of Watch_Face_Editor_(ZeppOS). i downloaded it and unzipped it. When i try to execute Watch_Face_Editor_(ZeppOS) nothing happens. :( I use a windows 11 machine. I have installed .NET. What am i missing?
@frankh93
You need pause_call from WIDGET_DELEGATE.
https://docs.zepp.com/docs/watchface/ap ... de-example
Bresbres
Post by Bresbres »
Thanx! now it works. lets start making watchfaces ! :-)
frankh93
Post by frankh93 »
@SashaCX75 that worked, ty... now im dealing with something else. I wanna change the color of the current temperature, been trying with many things...
setProperty(hmUI.prop.MORE, { color: xxxxxx })
setProperty(hmUI.prop.COLOR, xxxxxx)
but all this didnt work... got it working in two different ways...
1. Making the widgets for all the colors and showing/hiding them as i need but i dont feel like its the best way
2. Removing the current one and creating the new one with the desired color, but it wont show instantly... gotta change the screen and come back to the watchface to see the change
maybe im missing something changing the color with setProperty? or it isnt possible that way? thank you beforehand
If setProperty(hmUI.prop.COLOR, xxxxxx) does not work, try setProperty(hmUI.prop.MORE, { color: xxxxxx }). If that does not work either, try hmUI.prop.MORE and change all parameters at once.
Yoshihiro Morigami
Post by Yoshihiro Morigami »
Watch face editor for Amazfit watch on ZeppOS not work
I have installed previous versions (7, 8, and 13), but they no longer work.
I'm using an Amazfit Active 2, so the version is 13.1 or later.
It worked when I used it to change the face about a month ago.
Please understand that this is powered by Google Translate.
event viewer log
event viewer log:
logname: Application
source: .NET Runtime
date: 2025/08/14 7:44:27
event Id: 1026
task categoly: none
level: error
keyword: classic
youser: N/A
computer: Dragonfly
exp:
application:Watch_Face_Editor_(ZeppOS).exe
flamework version:v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception information:System.ComponentModel.Win32Exception
System.Diagnostics.Process.StartWithShellExecuteEx(System.Diagnostics.ProcessStartInfo)
System.Diagnostics.Process.Start()
System.Diagnostics.Process.Start(System.Diagnostics.ProcessStartInfo)
Watch_Face_Editor.Form1.SplashScreenStart()
Watch_Face_Editor.Form1..ctor(System.String[])
Watch_Face_Editor.Program.Main(System.String[])
event XML:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name=".NET Runtime" />
<EventID Qualifiers="0">1026</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2025-08-13T22:44:27.9882886Z" />
<EventRecordID>1822</EventRecordID>
<Correlation />
<Execution ProcessID="2356" ThreadID="0" />
<Channel>Application</Channel>
<Computer>Dragonfly</Computer>
<Security />
</System>
<EventData>
<Data>applicatin:Watch_Face_Editor_(ZeppOS).exe
framework version:v4.0.30319
Description: The process was aborted due to a no handle exception.
place System.Diagnostics.Process.StartWithShellExecuteEx(System.Diagnostics.ProcessStartInfo)
place System.Diagnostics.Process.Start()
place System.Diagnostics.Process.Start(System.Diagnostics.ProcessStartInfo)
place Watch_Face_Editor.Form1.SplashScreenStart()
place Watch_Face_Editor.Form1..ctor(System.String[])
place Watch_Face_Editor.Program.Main(System.String[])
</Data>
</EventData>
</Event>
Log Name: Application
Source: Application Error
Date: 2025/08/14 7:44:28
Event ID: 1000
Task Category: Application Crash Event
Level: Error
Keywords:
User: DRAGONFLY\yoshi
Computer: Dragonfly
Description:
Faulting Application Name: Watch_Face_Editor_(ZeppOS).exe, Version: 14.1.1.0, Time Stamp: 0xacc329dc
Faulting Module Name: KERNELBASE.dll, Version: 10.0.26100.4946, Time Stamp: 0x40de7ee7
Exception Code: 0xe0434352
Fault Offset: 0x00160714
Faulting Process ID: 0x934
Faulting Application Start Time: 0x1DC0CA3D188AD37
Faulting Application Path: C:\Users\yoshi\Downloads\Watch_Face_Editor_(ZeppOS)_v14.1.1(2)\Watch_Face_Editor_(ZeppOS)\Watch_Face_Editor_(ZeppOS).exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report ID: f3dc9b52-f336-45b5-a123-a79a06a92067
Faulting package full name:
Faulting package-relative application ID:
Event XML:
<System>
<Provider Name="Application Error" Guid="{a0e9b465-b939-57d7-b27d-95d8e925ff57}" />
<EventID>1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000000</Keywords>
<TimeCreated SystemTime="2025-08-13T22:44:28.3080071Z" />
<EventRecordID>1823</EventRecordID>
<Correlation />
<Execution ProcessID="4480" ThreadID="17112" />
<Security UserID="S-1-5-21-2205718831-3528315262-3633828058-1001" />
</System>
<EventData>
<Data Name="AppName">Watch_Face_Editor_(ZeppOS).exe</Data>
<Data Name="AppVersion">14.1.1.0</Data>
<Data Name="AppTimeStamp">acc329dc</Data>
<Data Name="ModuleName">KERNELBASE.dll</Data>
<Data Name="ModuleVersion">10.0.26100.4946</Data>
<Data Name="ModuleTimeStamp">40de7ee7</Data>
<Data Name="ExceptionCode">e0434352</Data>
<Data Name="FaultingOffset">00160714</Data>
<Data Name="ProcessId">0x934</Data>
<Data Name="ProcessCreationTime">0x1dc0ca3d188ad37</Data>
<Data Name="AppPath">C:\Users\yoshi\Downloads\Watch_Face_Editor_(ZeppOS)_v14.1.1(2)\Watch_Face_Editor_(ZeppOS)\Watch_Face_Editor_(ZeppOS).exe</Data>
<Data Name="ModulePath">C:\WINDOWS\System32\KERNELBASE.dll</Data>
<Data Name="IntegratorReportId">f3dc9b52-f336-45b5-a123-a79a06a92067</Data>
<Data Name="PackageFullName">
</Data>
<Data Name="PackageRelativeAppId">
</Data>
</EventData>
</Event>
Yoshihiro Morigami wrote: 14 Aug 2025, 07:28
Judging by the logs, the error occurs in the system files. So look for the problem in your system. As an option, set the file properties to run in compatibility mode with earlier versions of the system.
marrud12
Post by marrud12 »
I have created a watchface with V 14.1.1 and it is allmost finished. One problem: I used Barometer -> Numerical values (altitude). I suppose it is in meter? But when I click "Random preview", the maximum of the values is 280, never 4 digits. Is this an error in configuration?
marrud12 wrote: 15 Aug 2025, 17:48
On the preview data tab, you can configure altitude readings in a wider range. When generating random data, the limits are restricted so that it resembles the data of most users.
marrud12
Post by marrud12 »
Thanks, but 280 m is very low. Zurich is 405 m, most swiss people live between 400 and 1800 m, I live on 650 m. The limit of preview is 3000, in Zermatt is a aerial cableway up to 3883 m... Hope next version has higher limits. But thanks for your very good program.
280 is a three-digit number, and this is enough to understand how the three-digit numbers of this widget will look on the watch face. If you increase the maximum limit for random values, the probability of two-digit numbers appearing will decrease, and it will be more difficult to understand how the two-digit numbers of this indicator will look on the watch face. Therefore, I do not plan to change the limits for random previews.
Bresbres
Post by Bresbres »
is it possible to make a week of the year in the Bip6 Screen? I don't see it in the items.
