@diver787
If a watch face is not installed via Zepp, its preview is not displayed in Zepp. The only exception is a watch face made on the basis of an official watch face with ID preservation.
Usually in such cases Zepp will display a preview of the last official watch face installed. Therefore, it may appear that a watch face installed from another source is also previewed in Zepp.
@TRK88PL
I plan to add new data types in the next version. But I'm not sure that there will be sleep. I think that if I add sleep, I should add a sleep graph at once. Then it is more difficult to add a graph to an existing widget. And sleep graph is a non-standard widget and we will have to think about its implementation. I also haven't checked whether the standard widget displays sleep time with wake-up time or not. And I don't know how to make it more correct. So probably in the next updates.
About the animation of seconds passing in a circle, I'm not sure I understood you correctly. Can you show an example of how it should look like?
TRK88PL
Has thanked: 67 times
Been thanked: 40 times
Post by TRK88PL »
I mean something like this https://amazfitwatchfaces.com/gtr/view/41640 this watch face it's coded but this show what I mean when I talk about seconds on circle.
TRK88PL wrote: 20 May 2025, 18:33
That is, the display of time is not arrows, but filled circles. I think it can be done. Only the analogue of a smooth second hand is unlikely to be made.
diver787 wrote: 20 May 2025, 11:28
The format of the digital time display depends on the setting of the watch.
Max88
Post by Max88 »
Hello guys. I have an amazfit bip 6 since yesterday and this tool is amazing.
I had already used it previously, but it has reached an super level of customization.
Sasha, is there a way to add a shortcut or something else to the watchface to recall zepp flow?
I know it can be done with long press of the physical button, but it would be great also having a shortcut on the watchface.
Thanks ^^
Been thanked: 2122 times
Max88 wrote: 23 May 2025, 10:14
Thanks ^^
Please try to read in this link :
viewtopic.php?p=19558#p19558
Sorry :
hmApp.startApp({ appid: 1038314, url: 'page/gtr/home/index.page'});
This is not flow appid for Bip6, I tested it on my Bip6 and it can not work on Bip6.
I found appid flow 1.8.2 on Bip6
hmApp.startApp({ appid: 1076308, url: 'page/gtr/home/index.page'});
Tested on by Bip6 it's work
Because Zepp Flow has a different ID on different models, I don't plan to add its shortcut to the editor.
Max88
Post by Max88 »
asoo wrote: 23 May 2025, 12:28
Thanks ^^
Sorry :
Thank you a lot. I'll try as soon as I can.
@SashaCX75
Thank you however, I understand it would be a mess supporting this function for every model.
Maybe, if i can suggest it, you could add a note to the first post with the right command for every model. Just for the users who wants to add it to their watchface
Thanks again to all.
Given that different versions of Zepp Flow have different IDs, it may change in future versions.
rush2112
Has thanked: 119 times
Post by rush2112 »
@SashaCX75
Hello, thank you for the great work you're doing on the watch editor V 13.2. I have a GTR3 Pro, and I've noticed that when I create a watch face, the current temperature value at the angle doesn't display any numbers it's blank. Additionally, the value on the circle also remains blank, and the overall watch face appears empty. Are you able to fix this issue? :D
rush2112 wrote: 25 May 2025, 09:56
@SashaCX75
I think the problem is unlikely to be with the Editor program.
If I remember correctly, The function that you mentioned, It not support in ZeppOS 1 .
rush2112
Post by rush2112 »
Okay. Thanks
Max88
Post by Max88 »
Asoo could you tell me where to look for the app id of zepp flow? So, if it changes in future, I'll know where to find it.
Thank you ^^
Max88 wrote: 26 May 2025, 11:55
Thank you ^^
I look at the App.json file of the program.
You can find the program here.
https://mmk.pw/en/zepp_explorer/1015833 ... 7/?v=1.8.2
Note: If there is a new update, you may have to wait for the web update before you can download it.
There may be other ways to do it, but for now I only know this one.
@rush2112
I don't understand what is not working. In your screenshot, the angled temperature display and the circular temperature display are disabled. Of course, if they are disabled, they will not display data.
There are 2 ways to display the temperature at an angle. One of them doesn't work on GTR3 Pro and that's why it is inactive on your screenshot. But the second way works and you just need to switch it on where the arrow is showing.
Guydu91
Has thanked: 58 times
Post by Guydu91 »
Adrian
Your problem may be with the preview image, which, according to the official ZeppOS documentation, should be 324x324...
https://docs.zepp.com/docs/reference/re ... th-zepp-os
Best regards,
Guy.
Mihhaili
Post by Mihhaili »
can someone point me in right direction. how to make watchfaces for bip s?
Mihhaili wrote: 13 Jun 2025, 15:02
If you mean bipS Editor, this Editor is not for BipS
You can find more information about BipS by searching here
search.php?keywords=BipS
support Bip5 , Bip5 Unity, Bip6 only
lesly2316 wrote: 20 Jun 2025, 11:00
Hey everyone! I'd love some help editing this watchface to make the background completely black. I think it would look much better aesthetically and also make better use of the Bip 6's AMOLED screen. I downloaded the latest version of the editor from the awesome sachacx75, but I'm having trouble understanding how to use the app. The watchface is this one: https://amazfitwatchfaces.com/bip/view/43897
@lesly2316
1. Download the watch face file.
2. In the editor, click ‘Unpack watch face’ and select the downloaded file.
3. Open the folder with the unpacked watch face. You can click the ‘Open folder’ button in the editor or find it yourself in the folder with the editor.
4. Edit the images in any graphics editor.
5. Pack the watch face in the editor.
For more complex watch faces, the procedure may differ.
frankh93
Has thanked: 24 times
Post by frankh93 »
Recently bought the Bip 6 and already published my first watchface going really basic on it... I'm working on another one but have been dealing with a issue, which I dont know if it's just me being dumb setting things or this behavior is intended.
I'm trying to add a digital clock like that, but wanna get rid of the AM/PM thing. Found that reducing the height of the element is a workaround and it seems to be working on the clock, but I noticed the clock gets misaligned a bit to the left, so I don't know if there's a way to do it or if I'm missing something could someone guide me?
Thank you beforehand fot the help, and also thank you SashaCX75 for such amazing tool for watchfaces creation.
frankh93 wrote: 25 Jun 2025, 21:58
I'm not sure if I understand correctly. From what I see you are using
"TT Hour:minute" to display the clock and don't want to display AM PM and you found issue in the alignment. If so, I would suggest you try using "TT Hour in font" and "TT Minutes in font" instead. You will have more flexibility in the alignment of the Hour and Minutes.
However, as far as I have tested, some True Type fonts sometime it not display on the device same as the preview shown in the editor, so in this case, you have to adjust it to suit your needs by viewing the results on the actual device.
Emiliomc
Post by Emiliomc »
I'm not sure I understood you correctly. I think you want the time in 24-hour mode. That way, AM/PM is suppressed. To do this, just go to the SashaCX75 app settings and select/unselect that option.
Emiliomc
Post by Emiliomc »
I've been using SashaCX75's app for a while to create my watchfaces for my GTS 4. Every time I create a digital watch and use "Value by Font" (with any font I use and without separating or joining the fonts) the classic ":" separator in the app image appears correctly located in the center. Not at the same level (below) where the hour and minutes are. However, when I install the created watchface (even after restarting) the ":" appear at the bottom, not in the center. I don't know if I'm doing something wrong or if there is no solution.
frankh93
Post by frankh93 »
Thanks @asoo and @Emiliomc. I'm using the text font thing for digital clock, centered horizontally, with top alignment on the text and reduced height to hide the AM/PM thing... In the preview it seems to work as I want and so in the watch, but only when 24h format clock is used, when I use clock with AM/PM format the clock gets a bit to the left, no centered as it's supposed to be.
I don't know if I'm missing something or if its creator (Sasha) could add an option to hide AM/PM thing from digital clock.
