Amazfit Balance
Moderatori: asoo, Internal error, Watchmens
massi131
Messaggio da massi131 »
I've done everything but when I use the Zepp scan it says: Download failed, error code"
What do you use to generate a qrcode?
Been thanked: 1029 times
Messaggio da SashaCX75 »
Not all servers process requests correctly if zpkd1:// is written instead of http://.
To start with, you can try just pasting the address that starts with zpkd1:// into the address bar of your browser and see if the download starts.
Stephthouv
Has thanked: 7 times
Messaggio da Stephthouv »
Hi everyone. An idea for amazfaces team, maybe stupid idea, but...
If the method mentioned above works, why not using it for amazfaces? There could be a QR code for each face ?
Maybe it's a bad idea and if it is, sorry for amazfaces team. Many Many thanks for your work.
Has thanked: 1137 times
Been thanked: 275 times
Messaggio da GIK-Team »
Stephthouv ha scritto: 09 dic 2023, 10:02
The concept of using QR codes for each watch face is certainly interesting and worth considering.
However, currently, we are focused on enhancing the standard installation process to ensure it works seamlessly within the app. Our goal is to provide a user-friendly and efficient experience for downloading and applying watch faces. Rest assured, we are always looking for ways to innovate and improve our service.
Your suggestions and support are very valuable to us. Please keep them coming, and thank you for your kind words about our work!
Best regards
Stephthouv
Hi, need more help, if you agree and you have time.
I have opened a altervista account. What is the way to load my file in altervista ? Is it in media library ?
How do you obtain the zpk file ? By changing the file extension in file explorer ? Is it before uploading in altervista ?
Do you need to uplaod zip file AND zpk file in altervista ? When I try with zpk file, altervista tells me I'm not allowed to load files with this extension (zpk).
To sum up, I'm lost ...
In advance many thanks for your help.
supersufa ha scritto: 06 dic 2023, 13:48
Stephthouv ha scritto: 06 dic 2023, 07:09
Hello, Could you please explain me too?
supersufa ha scritto: 05 dic 2023, 11:27
I sent you a pvt... Check and tell me!
Bye
Sure!!
Once you have built your WatchFace.zpk file you have to load it online....
In order to be sure that the procedure works fine you have to load the file in a webspace which provide you a direct link. For example you can create an account on Altervista, because i know that everything works without any issues...
Immagine for example that you chose Stephthouv as your nickname on Altervista.... Your loaded file could be for example http ://Stephthouv.altervista.org/WatchFace.zpk ok?
The last step is to generate a QR code... By performing this action however the QR code have to point to zpkd1: //Stephthouv.altervista.org/WatchFace.zpk
In this way, by using Zepp to scan the just generated QR code the watchface will be installed automatically....
supersufa
Messaggio da supersufa »
You have to create the zip file and rename it in windows yes...
Then you have to load it in altervista via Dasboard - File magement - upload file
In this way you can load every file with any extension.
==Francesco==
Messaggio da ==Francesco== »
Good morning,
Unfortunately I am unable to rename the uploaded file (in zip format) on the Altervista portal.
Can you help me?
Thank you
Buongiorno,
io purtroppo non riesco a rinominare il file caricato (in formato zip) sul portale Altervista.
Riuscite ad aiutarmi?
Grazie
ragdolled
Messaggio da ragdolled »
Is there anyone who actually got this to work yet?
One BIG problem is that you simply cannot upload a zpk file on alter vista.
I try to follow all the steps but it simply does not work
Stephthouv
Actually there are 2 types of altervista accounts. One is a blog, the other allows theoretically to upload files, whatever the extension of the file.
But despite I used a vpn to change my country, impossible to subscribe to a "file server" profile: unavailable in my country (I tried several countries).
After several attempts, I gave up....
Stephthouv
Rename it in windows explorer before uploading it in altervista portal 😉.
==Francesco== ha scritto: 15 dic 2023, 08:46
Good morning,
Can you help me?
Thank you
Buongiorno,
Grazie
==Francesco==
Grazie per la risposta, purtroppo non riesco a caricare il file, risponde che il file non è una watchface.
Thanks for the reply, unfortunately I can't upload the file, I reply that the file is not a watchface.
==Francesco==
Buongiorno, ho raccolto le varie informazioni sul forum per caricare le watchfaces sul Balance, purtroppo non ci sono riuscito, avrò sicuramente sbagliato in qualche passaggio. Qualcuno sarebbe così gentile da creare una guida (passo, passo) per noi ignoranti in materia? Grazie come sempre e buon lavoro a tutti!
Good morning, I collected the various information on the forum to upload the watchfaces to the Balance, unfortunately I didn't succeed, I must have made a mistake in some steps. Would someone be kind enough to create a (step by step) guide for us ignorant people on the subject? Thanks as always and good work everyone!
==Francesco==
Poi pensavo un'altra cosa: ma qualcuno non potrebbe creare direttamente il qrcode funzionante su uno spazio Altervista? C'è qualcosa che non lo permette di fare?
Then I thought about something else: couldn't someone directly create the working qrcode on an Altervista space? Is there anything you can't do?
supersufa
The most important step is to create the file WatchFace.zip containing:
- device.zip (your favourite watchface renamed)
- app-side.zip (support file here attached)
Then you have to renamed the file in WatchFace.zpk.
Then you have to load the renamed file on altervista.
Then you have to generare the QR code (renaming from http:// to zpkd1://)
Without these steps the intall phase is impossible!
Allegati
app-side.zip
(644 Byte) Scaricato 530 volte
Stephthouv
Balance updated tonight to 3.16.4.3 firmware. Still no abilities to sync faces with third party app.
Ultima modifica di Stephthouv il 19 dic 2023, 19:47, modificato 1 volta in totale.
Stephthouv
Thank you but... You can add two zip files in one zip file? 🤔
supersufa ha scritto: 19 dic 2023, 11:22
supersufa
Absolutely yes!
I don't know what software you use to build a .zip file... But with winrar i.e. you can select both zip file (device.zip and app-side.zip), right mouse button then "add to archive" in order to create the WatchFace.zip file.
Test it!
pixelator99
Messaggio da pixelator99 »
Just tried this on my Balance, and it works perfectly. Thank you so much for the solution, @supersufa !
Stephthouv
Failed again 😔
Merry Christmas to all.
ragdolled
The app is updated. Just switch your model to balance and everything should work. I just download my first watch face couple of minutes ago!
Stephthouv
ragdolled ha scritto: 25 dic 2023, 10:47
I'm afraid the app is not updated in Google play store. The last update is on 6th of December.
Stephthouv ha scritto: 25 dic 2023, 20:27
@ragdolled is talking about the iOS version ;)
Stephthouv
I'm a bit curious : can someone explain why (technically) the app works on IPhone and not on android? Many thanks in advance.
GIK-Team ha scritto: 25 dic 2023, 22:58
Stas
Been thanked: 34 times
Messaggio da Stas »
Yes, Android and iOS for Balance are different, the iOS installation has not changed, and the Android company Zepp did it in a completely different way, we hope that in the near future we will try to adapt the Android version.
Stephthouv ha scritto: 30 dic 2023, 09:50
MikeZuul
Messaggio da MikeZuul »
SashaCX75 ha scritto: 08 dic 2023, 08:21
I've followed all instructions. I get the same result as massi131: Download failed, error code: null. When I put the address that starts with zpkd1:// in the address of my browser I do not get a download (or anything). Though with the http:// I do get a download. Any ideas?
Thanks for everything! Your answers and this thread are super helpful!
Torna a “AmazFaces app”
