For all Android users, you can try this option to upload to your Balance: https://discord.com/channels/6872628817 ... 1866498069
I don't own an Android device so I cannot test it.
搜索找到 7 个匹配
- 06 12月 2023, 13:48
- Jump to forum
- Jump to topic
Re: Amazfit Balance
Hello, Could you please explain me too?
ok.
I didn't understand this part. what is it my Web space
After this you have to modify the file extension from WatchFace.zip to Watchface.zpk.
Load the file on your web space and copy the file url....
ie http:// yourspace / Watchfile.zpk and ...
- 10 12月 2023, 07:57
- Jump to forum
- Jump to topic
Re: Amazfit Balance
You have to create the zip file and rename it in windows yes...
Then you have to load it in altervista via Dasboard - File magement - upload file
In this way you can load every file with any extension.
- 20 12月 2023, 07:19
- Jump to forum
- Jump to topic
Re: Amazfit Balance
Absolutely yes!
I don't know what software you use to build a .zip file... But with winrar i.e. you can select both zip file (device.zip and app-side.zip), right mouse button then "add to archive" in order to create the WatchFace.zip file.
Test it!
Test it!
- 25 12月 2023, 22:58
- Jump to forum
- Jump to topic
Re: Amazfit Balance
@ragdolled is talking about the iOS versionStephthouv 写了: 25 12月 2023, 20:27I'm afraid the app is not updated in Google play store. The last update is on 6th of December.
- 12 1月 2024, 19:13
- Jump to forum
- Jump to topic
Re: Amazfit Balance
I'm not sure where I'm at with my file, but I tried the qr code now on the site and it works! And for GTR 3 Pro as well. So thank you for the heads up! And thank you Amazfitwatchfaces!
- 14 1月 2024, 20:08
- Jump to forum
- Jump to topic
Re: Amazfit Balance
Yes, i confirm that with the updated app it works with QR on Android. Just click "download" and then the QR icon. Send the picture to the pc and scan it
