Amazfit Balance
Rlh1963
- Has thanked: 3 times
Amazfit Balance
I understand the GTR3 Pro and the new Balance have the same ppi. I have tried to sync some of the faces, but the Balance isn't listed in the app and the attempted install of a GTR3 Pro face just freezes. Can you adjust the app to recognize the Balance? Thanks
Xphyle1971
- Has thanked: 4 times
- Been thanked: 7 times
I'm in the exact same situation! I can't get the app to recognize the Balance, so I'm unable to install any watch faces. I've got 3 other Amazfit watches and the app works just fine with them all.Rlh1963 wrote: 23 Sep 2023, 21:27I understand the GTR3 Pro and the new Balance have the same ppi. I have tried to sync some of the faces, but the Balance isn't listed in the app and the attempted install of a GTR3 Pro face just freezes. Can you adjust the app to recognize the Balance? Thanks
Xphyle1971
Yes the app doesn't see the watch. Visibility is already turned on for me and the app still doesn't see it, but it sees all 3 of my other Amazfit watches. I think the app needs to be updated to support the Balance watch properly.
- Stas
- Been thanked: 34 times
Have you tried to connect by MAC address?
Xphyle1971 wrote: 25 Sep 2023, 21:20Yes the app doesn't see the watch. Visibility is already turned on for me and the app still doesn't see it, but it sees all 3 of my other Amazfit watches. I think the app needs to be updated to support the Balance watch properly.
Xphyle1971
Of course. It doesn't work. On 3 different phones. After researching, It appears that the watch is seen on APPLE iOS devices (in the AmazFaces app) but is NOT seen on Android devices.Stas wrote: 26 Sep 2023, 06:18Have you tried to connect by MAC address?
- SashaCX75
- Has thanked: 14 times
- Been thanked: 1043 times
I want to try to create a watch face with parallax effect (background movement depending on the clock tilt). It works in the simulator, but I'm not sure it will work on a real device. If any of the watch owners are interested in this and are ready to participate in testing the watch face, please write in private messages.
- GIK-Team
- root
- Has thanked: 1172 times
- Been thanked: 281 times
You can add your watch face to our catalog, where there are currently only a few watch faces available. This way, other watch owners can assist you in testing and provide feedback on how it performs on real devices. Feel free to upload it there, and let's see how the community responds!SashaCX75 wrote: 26 Sep 2023, 20:42I want to try to create a watch face with parallax effect (background movement depending on the clock tilt). It works in the simulator, but I'm not sure it will work on a real device. If any of the watch owners are interested in this and are ready to participate in testing the watch face, please write in private messages.
Xphyle1971
You know what would be helpful in testing? If you fixed the Android AmazFaces app so that it could actually work with the Balance watch on Android devices. It appears only the iOS Apple devices can detect the Balance watch currently based on posts here.GIK-Team wrote: 26 Sep 2023, 22:28You can add your watch face to our catalog, where there are currently only a few watch faces available. This way, other watch owners can assist you in testing and provide feedback on how it performs on real devices. Feel free to upload it there, and let's see how the community responds!SashaCX75 wrote: 26 Sep 2023, 20:42I want to try to create a watch face with parallax effect (background movement depending on the clock tilt). It works in the simulator, but I'm not sure it will work on a real device. If any of the watch owners are interested in this and are ready to participate in testing the watch face, please write in private messages.
- GIK-Team
- root
I was hoping you could show me how to do this without watch faces.Xphyle1971 wrote: 27 Sep 2023, 12:50You know what would be helpful in testing? If you fixed the Android AmazFaces app so that it could actually work with the Balance watch on Android devices. It appears only the iOS Apple devices can detect the Balance watch currently based on posts here.
- BigBlind68
- Been thanked: 4 times
FYI I can't see my Balance with iOS app either but use a workaround to upload to my Balance. When I select the GTR 3 Pro in the app it will detect my Balance without setting the MAC address manually. The only problem with the app when you use this workaround is that you can't see the Balance watch faces, only the GTR 3 Pro ones. With the help of @Lattenknaller I managed to upload a very nice watch face to my Balance. Let's just sit and wait till the developers update the app for both Android and iOS so the Balance will work as default instead of a workaround.
- Stas
There will be an update soon, Balance will be added there.
You can still download the watch face file and import it into the app
BigBlind68 wrote: 30 Sep 2023, 07:53FYI I can't see my Balance with iOS app either but use a workaround to upload to my Balance. When I select the GTR 3 Pro in the app it will detect my Balance without setting the MAC address manually. The only problem with the app when you use this workaround is that you can't see the Balance watch faces, only the GTR 3 Pro ones. With the help of @Lattenknaller I managed to upload a very nice watch face to my Balance. Let's just sit and wait till the developers update the app for both Android and iOS so the Balance will work as default instead of a workaround.
Xphyle1971
Yeah but on the ANDROID app, the app doesn't see the Balance at ALL. Even if you try selecting GTR 3 Pro. Even if you set the MAC address manually. It just doesn't work whatsoever.Stas wrote: 30 Sep 2023, 08:36There will be an update soon, Balance will be added there.
- GIK-Team
- root
We heard you. Repeating the same thing won't change anything. Please be patient and wait for the app update.Xphyle1971 wrote: 30 Sep 2023, 20:20Yeah but on the ANDROID app, the app doesn't see the Balance at ALL. Even if you try selecting GTR 3 Pro. Even if you set the MAC address manually. It just doesn't work whatsoever.
- BigBlind68
Can @GIK-Team give an ETA when the app will come with this update?GIK-Team wrote: 30 Sep 2023, 21:03We heard you. Repeating the same thing won't change anything. Please be patient and wait for the app update.Xphyle1971 wrote: 30 Sep 2023, 20:20Yeah but on the ANDROID app, the app doesn't see the Balance at ALL. Even if you try selecting GTR 3 Pro. Even if you set the MAC address manually. It just doesn't work whatsoever.
- GIK-Team
- root
We're constantly updating the beta version of the app almost every day. However, for the stable release, we can't provide an exact ETA at the moment. We recommend trying the beta version if you want the latest fixes and features. Thank you for your patience and understanding.BigBlind68 wrote: 14 Oct 2023, 14:49Can @GIK-Team give an ETA when the app will come with this update?
- BigBlind68
Where can I find the beta version for iOS?GIK-Team wrote: 14 Oct 2023, 16:06We're constantly updating the beta version of the app almost every day. However, for the stable release, we can't provide an exact ETA at the moment. We recommend trying the beta version if you want the latest fixes and features. Thank you for your patience and understanding.BigBlind68 wrote: 14 Oct 2023, 14:49Can @GIK-Team give an ETA when the app will come with this update?
- GIK-Team
- root
Stephthouv
- Has thanked: 7 times
I sent this to Amazfit via Zepp (Users comments). I think all Balance users should do the same. Hope this helps.
"Hi, just to let you know that it is not possible to add faces in ma balance with third party app with an android phone. I owned gtr 3 pro and gtr 4, it was available, and it was one of the reasons I bought it. If you don't allow this, balance will be my last amazfit watch. Thank you."
- Stas
Unfortunately, due to technical limitations, our app is currently unable to add watch faces to Amazfit Balance, I hope this issue will be resolved in the near future.
Stephthouv wrote: 10 Nov 2023, 15:46I sent this to Amazfit via Zepp (Users comments). I think all Balance users should do the same. Hope this helps.
Stephthouv
Hi everyone. Today 3.15.10.1 watch update... But still no connection with amazfaces
- Stas
We hope to solve this problem in the near future before the end of the month
Stephthouv wrote: 20 Nov 2023, 19:35Hi everyone. Today 3.15.10.1 watch update... But still no connection with amazfaces![]()
- BigBlind68
For all Android users, you can try this option to upload to your Balance: https://discord.com/channels/6872628817 ... 1866498069
I don't own an Android device so I cannot test it.
Link seems not working... Discord doesn't open any server and/or discussion....BigBlind68 wrote: 21 Nov 2023, 12:19For all Android users, you can try this option to upload to your Balance: https://discord.com/channels/6872628817 ... 1866498069
