Amazfit Balance Faces
Been thanked: 1029 times
@BigBlind68 If there is animation in the watch face, you can try to set the GTR 4 model in the editor before building.
Or you can edit the configurations file in the model_config folder. At the end of the file change the "versionOS" value from 1 to 3.
There is no easier way to make an animation for Balance in my editor at the moment.
Powerade001
Has thanked: 12 times
Post by Powerade001 »
SashaCX75 wrote: 25 Sep 2023, 15:44
@Sharpshot90 Is this problem present in both dials I posted or just one? Is it on the main screen or only on the AOD?
Hi Sasha,
I too have a Balance and have tested both dial. Device.zip will have green tint on AOD but not Test-balance.zip
Something wierd: both watchfaces flikered rapidly when on AOD ? I tried a custom watchface converted from gtr4 to Balance with your tool (version 9.0) and AOD does not fliker but as a greenish tint.
If I can help further, please PM me and I will gladly assist.
Allan
@Powerade001 Flickering at low brightness is a problem with all AMOLED screens. On the Amazfit, it is noticeable when a bright background is used for AOD. If the background is dark and there are only a few bright elements, flickering is almost never noticeable. This effect is seen on many models and watch faces.
Device.zip is a watch face created in the official editor. And I am oriented on the work of the official editor. If colours are mixed up (e.g. blue is displayed instead of red) I can try to fix it. But a slight colour change is like a screen problem. Because even if you use the same images for the main screen and for AOD, on AOD you can sometimes notice a slight change of shade. The only difference is that on AOD the screen brightness is less. This tint change is not always visible, maybe it depends on the colour of the image. For some colours it is noticeable more and for some less.
gtung3388
Post by gtung3388 »
GIK-Team wrote: 30 Sep 2023, 21:58
gizmo2k4 wrote: 30 Sep 2023, 08:30
hi , i bought a Balance too. I have a Google Pixel 7a . the Same Problem , i can choose Balance in the App or GT3 pro , but when Balance is selected it cant bei found . when GT3 pro ist selected i can Transfer but it doesn't Transfers.
Need Help 🙈
Thx 4 Help
You need to wait for the app update, where support for Balance will be added.
got the latest update of amazfitwatchfaces apps , still cant download the WF for my Balance..
Has thanked: 1137 times
Been thanked: 275 times
gtung3388 wrote: 10 Nov 2023, 04:19
Better follow this thread here: viewforum.php?f=23
K4rol
Post by K4rol »
asoo wrote: 21 Sep 2023, 03:20
1. The amazfit Balance has the same 480x480 screen size as the GTR3pro and uses zepp OS as the operating system.
So there is a possibility To be able to use Sasha's editor.
viewtopic.php?t=2743
you may try selecting the model as GTR3pro and create for your watchface
However, the watchface that will be edited must be The dial uses a standard script with no coding, so the editing program can unpack correctly.
2. In this question, do you mean where the png of the watch face is stored? If used, it's in the assets folder in the watch face ( zip ) file.
The image inside is a zeppOS encoded png. If you want to edit the image, you need to unpack it with Sasha's program mentioned in point 1. When you're done, you'll find a normal png image that can be edited with any image editor program.
However, You must perform the test yourself. Since I don't have an Amazfit Balance, I wasn't able to test it.
can i use GTS3/4 watchfaces from amazwatchfaces app for amazit ACTIVE? size is the same, but i am not sure, can i brick my device bc of this?
thanks in advance
Has thanked: 414 times
Been thanked: 2073 times
K4rol wrote: 31 Jan 2024, 12:04
thanks in advance
You can find information about your inquiry in this Topic.
viewtopic.php?p=17278#p17278
