Search found 12 matches
Return
by asoo
11 Jan 2024, 22:49
Jump to forum
Jump to topic
Further update: I found some mentions on Discord about changes to QR code generation, and it seems to affect the upcoming version 10.8.5.
Some changes are coming to the way your custom QR Codes with perma links like the one put on `github` pages, are processed.
Starting from zepp app `10.8.5 ...
by GIK-Team
04 Feb 2022, 19:11
Jump to forum
Jump to topic
Re: Can't "make Private" for Watch face testing.
I am a new user and the 'make private' option is not available. So, If I understood correctly, as a new user, the watchface uploaded will be automatically private? I'm asking because I want to upload a personnal watchface so I can transfert to my watch thru your app. It is the only way available ...
by supersufa
24 Nov 2023, 08:23
Jump to forum
Jump to topic
Re: Amazfit Balance
I done it yesterday evening but moderation delete my message....
I'm sorry....
I retry to explain in other words...
The procedure is quite simple... You have to download your favorite watchface from the site, then rename the file in device.zip....
This file has to be added into this archive http ...
by SashaCX75
07 Jan 2022, 14:16
Jump to forum
Jump to topic
- Amazfit Bip 5 ...
by SashaCX75
30 Jan 2022, 11:59
Jump to forum
Jump to topic
Version 2.0
Added Italian ...
by asoo
17 Sep 2022, 00:37
Jump to forum
Jump to topic
Hi Asoo!
Thanks for your reply. My watch is already set to follow watch face.
My previous watch was a Gtr 3 Pro and have had no problem with custom watch watch. All I did was convert all my previous watchfaces to Gtr4 with the new SachaCX's 5.0 tool. But aod does not work. I even tried watch faces ...
by SashaCX75
17 Sep 2022, 06:32
Jump to forum
Jump to topic
Powerade001
Try this file.
If it doesn’t help and you are still ready to test the watch faces, then after the weekend I will try to make a simpler watch face, on which it will be easier to find the differences between the working and non-working versions.
by SashaCX75
19 Sep 2022, 12:23
Jump to forum
Jump to topic
Version 5.0.1
Mirror
Fixed work in AOD mode for GTR 4.
If you do not create watch faces for GTR 4, then you can not download this version.
by SashaCX75
19 Dec 2022, 16:22
Jump to forum
Jump to topic
Version 6.0
Mirror
by SashaCX75
02 Jan 2023, 12:22
Jump to forum
Jump to topic
Version 6.1
Mirror
by SashaCX75
07 Jan 2023, 20:18
Jump to forum
Jump to topic
Version 6.3
Mirror
by SashaCX75
14 Oct 2023, 12:20
Jump to forum
Jump to topic
Re: Amazfit Balance Faces
Powerade001 Flickering at low brightness is a problem with all AMOLED screens. On the Amazfit, it is noticeable when a bright background is used for AOD. If the background is dark and there are only a few bright elements, flickering is almost never noticeable. This effect is seen on many models and ...
