Regras do fórum
Avatar do usuário
Registrado em: 26 Out 2019, 15:18
Been thanked: 1044 times
Contato:
Mensagem por SashaCX75 »
v18.1
Version 18.1
Editado pela última vez por SashaCX75 em 10 Set 2026, 17:16, em um total de 54 vezes.
Avatar do usuário
ZduneX25
Registrado em: 12 Out 2022, 16:22
Been thanked: 6 times
Contato:
Mensagem por ZduneX25 »
SashaCX75 do you know any way to recognize screen wake event? the problem is i would like to start animation only after raise to wake gesture instead of having it keep starting everytime i switch view back to the main screen
Avatar do usuário
Contato:
ZduneX25 There is no easy way. In WIDGET_DELEGATE, you can track the on and off of the screen, you can switch between the normal screen and AOD. It is unlikely that it will be possible to determine the reason for turning off the dial, whether the screen went out or simply switched to another program.
Avatar do usuário
ZduneX25
Contato:
SashaCX75 i started with WIDGET_DELEGATE yet it cannot separate both wake and back to the main screen events, then i tried hmSetting.screen_type.WATCHFACE and i was only able to start animation once for the first time, finally tried onResume and onStart no luck
i cannot remember how to create log in zepp app
EDIT: found it, but they disabled it.. https://docs.zepp.com/docs/guides/tools ... chine-logs
Xemic
Registrado em: 24 Jan 2023, 21:52
Contato:
Mensagem por Xemic »
SashaCX75 oh sorry, just noticed my error with the screenshots. i added the right one this time :) . cheers.
i noticed that if i add icon to "Digital Time - Hours" it overlays over Minute and Seconds, regardless of how it's arranged. If i put Hour at bottom and Minute at the top the icon still overlays.
e.g. This is the design and layout on watch face editor.
Imagem
But I get this on the watch.
Imagem
Is this something that can change in the index.js file?
Avatar do usuário
ZduneX25
Contato:
Xemic you split time widget then place the one you want to see on top > below
typical digital clock looks this way:
Imagem
Xemic
Contato:
Thank you ZduneX25 and SashaCX75
I tried your suggestions. I even went as far as moving the icon bit up. At this point I'm sure I broke something as the watch face was completely bank. (I'm sure it was commenting out "show_level: hmUI.show_level.ONLY_NORMAL," beneath the hour code).
Imagem
Haven said that i found a way round the issue., I used the icon as seconds.
Avatar do usuário
ZduneX25
Contato:
Xemic your IMG widget is missing H and W properties that's for sure, second: uncomment because you did it wrong
Avatar do usuário
Contato:
For an IMG widget, the height and width properties are optional. Commenting out the line "show_level: hmUI.show_level.ONLY_NORMAL," is optional, it only affects the display on the AOD screen. It is definitely not necessary to comment the next line, without it there will be errors.
Avatar do usuário
ZduneX25
Contato:
SashaCX75 do you know appid to add shortcut for Dialer/Phone app and Store Cards?
Imagem
Avatar do usuário
Contato:
ZduneX25
Perhaps
Código: Selecionar todos
hmApp.startApp({ appid: 1, url: 'CardsScreen', native: true })
hmApp.startApp({ appid: 1, url: 'PaymentCardScreen', native: true })
But most likely it only works on the Chinese version of the watch
Dial
hmApp.startApp({ appid: 1, url: 'DialCallScreen', native: true })
Avatar do usuário
ZduneX25
Contato:
SashaCX75 thank you, so PaymentCardScreen is not working, CardsScreen it works, but like you said it opens some chinese page (i believe there is another name that will trigger proper page), finally DialCallScreen is taking me to a fake call screen when watch rings and i see reject/accept buttons, i would be satisfied with call history, favorite contacts or dialer itself (if you have any ideas)
santicam
Registrado em: 19 Jan 2023, 17:00
Contato:
Mensagem por santicam »
SashaCX75 escreveu: 13 Dez 2022, 18:17
A collection of code examples for use in watch faces.
- smooth second hand for GTR 3;
- smooth second hand for GTR 4;
- change the background with a button on the screen;
- switching between different elements with a button on the screen;
- starting vibration;
- data output at an angle;
- data output in a circle.
Does anyone know the necessary code to display/hide elements of the AOD screen, by pressing a button on the main screen?
SashaCX75's sample code only works to show/hide main screen elements, but not in AOD.
santicam
Contato:
Another doubt that I have. I need to change the background image of the AOD screen by pressing a button on the main screen, but the sample code does not work.
The same thing happens to me as in the previous case. It is not possible to change the AOD screen background image using SashaCX75's sample code, only the main screen image can be changed. Does anyone know how to do it?
Avatar do usuário
ZduneX25
Contato:
santicam escreveu: 15 Fev 2023, 12:58
@SashaCX75's sample code only works to show/hide main screen elements, but not in AOD.
I had to add SysProSetBool then SysProGetBool to pass a variable and make AOD display exactly what I wanted.
santicam
Contato:
ZduneX25 escreveu: 15 Fev 2023, 14:22
Thanks ZduneX25, but I don't know how to use this in the index.js javascript code.
Please can you post a js code example of how to use SysProSetBool and SysProGetBool?
Thank you so much.
Avatar do usuário
ZduneX25
Contato:
santicam above initview() add:
hmFS.SysProSetBool('a_word', false);
then inside initview():
const bool_name = hmFS.SysProGetBool('a_word')
in the place you want to control:
hmFS.SysProSetBool('a_word', true);
if (screenType = hmSetting.screen_type.AOD)
and finally:
if (bool_name === true) {
    dial2_normal_step_circle_scale.setProperty(hmUI.prop.VISIBLE, true);
} else {
    dial2_normal_step_circle_scale.setProperty(hmUI.prop.VISIBLE, false);
Avatar do usuário
Contato:
A small utility for converting images from a watch face to a regular Png and vice versa, into the format required for watch faces.
Unlike the editor, the image should be converted with less loss, this will be especially noticeable on images with a gradient.
It can also be useful if you just want to translate the watch face without changing anything else in it.
demiurg1
Registrado em: 23 Fev 2020, 22:49
Has thanked: 23 times
Been thanked: 17 times
Contato:
Mensagem por demiurg1 »
A very useful tool. It's a pity that it can't handle encrypted image files.
But it's nice to have a program like this.
1mylord
Registrado em: 18 Jan 2022, 02:52
Contato:
Mensagem por 1mylord »
Thank you always.
Can you tell me the address of the compass shortcut?
santicam
Contato:
Thanks ZduneX25, but I'm still having problems with SysProSetBool/SysProGetBool.
I've tried your suggestions, but can't get them to work in my project.
I will send you my code via telegram. Please, if you can, take a look to see what I'm doing wrong.
Avatar do usuário
Contato:
1mylord
hmApp.startApp({ appid: 1, url: 'CompassScreen', native: true })
Avatar do usuário
Contato:
Version 7.0
Mirror
demiurg1
Contato:
Do the changes in version 7.0 also apply to editable watch hands? I don't think so because I don't see that option.
Avatar do usuário
Has thanked: 438 times
Been thanked: 2142 times
Contato:
Mensagem por asoo »
demiurg1 escreveu: 01 Mar 2023, 09:02
I am not sure you mean this function or not ?
Imagem
demiurg1
Contato:
OK. I didn't check where it should be.
Responder
Quem está online
Usuários navegando neste fórum: Nenhum usuário registrado e 4 visitantes
