Been thanked: 1029 times
Has thanked: 414 times
Been thanked: 2073 times
wp456 wrote: 27 Dec 2022, 14:08
Hi, what is the difference why one step progress circle renders with continous color vs. the other one renders in a segmented way? I can't spot the diff in the resp. watchface json nor in the editor :)
From the picture you attached, my guess is as follows.
- circle renders with continous color, it's made by use function "Circle progress"
- circle renders in a segmented way it's made by use function " Images "
or put a transparent image (icon) only on the part you want to display, overlaid on the "circle progress".
"circle progress" will show values more precisely than using "images"
mirda69
Post by mirda69 »
I have a question:
In Sasha's editor, the animation for GTR4 is properly displayed in the preview and saved as such, but when the file is transferred to the watch, the animation does not work
I don't know if I'm doing something wrong or if it's an error in the editor. If anyone knows, please help and explain to me
If necessary, I can also attach a zip file so that someone can see what I'm doing wrong
Twist.zip
(366.74 KiB) Downloaded 277 times
Darkstalix
Post by Darkstalix »
I dont know why but when i add image files (png) after the repack it i get lots of artifacts
Im trying to change some timer "hands" with some of my own but the quality get destroyed
Is there a limitation?
1mylord
Post by 1mylord »
mirda69...
In my experience, in the case of gtr4,
The image must be in the assets folder, not the animation folder.
Additionally, you must change the animation path in the index file to anim_path: "".
1mylord
Post by 1mylord »
SasHAcx75...
Thank you very much.
Soft Seconds Example 2 seconds faster when applied.
Is it possible to edit it?^^
mirda69 wrote: 27 Dec 2022, 21:06
I have a question:
As far as i know in GTR4 ( Zepp OS verison 2 )
Some animation commands have been removed to increase some the OS's capabilities, causing GTR4 to not be able to display rotation animations. But as i know, you can also use Animation frame by frame to make animation.
wp456
Post by wp456 »
Ah yes, thank you, this is what's going on: both watchfaces use "circle progress", but the segmented one has an alpha-layered overlay image defined that "overpaints" and thus makes "segments" on the "circle progress" painting, nice. Only strange thing is that this overlay is defined as a symbol on a rather unrelated setting ("digital time -> Hours")
(btw, this is the watchface I inspected for the segments circle: https://amazfitwatchfaces.com/gtr/view/25006)
ZduneX25
Been thanked: 6 times
Post by ZduneX25 »
Change/show/hide elements in real time on click:
hmUI.createWidget(hmUI.widget.BUTTON, {
            x: 128,  // x coordinate of the button
            y: 308,  // y coordinate of the button
            text: '',
            w: 24,  // button width
            h: 24,  // button height
            normal_src: 'btn1.png',  // button image
            press_src: 'btn1.png',  // button image
            click_func: () => {
                analog.setProperty(hmUI.prop.VISIBLE, false)
                analog2.setProperty(hmUI.prop.VISIBLE, true)
                bg.setProperty(hmUI.prop.VISIBLE, false)
                bg2.setProperty(hmUI.prop.VISIBLE, true)
                week.setProperty(hmUI.prop.VISIBLE, false)
                week2.setProperty(hmUI.prop.VISIBLE, true)
                steps.setProperty(hmUI.prop.VISIBLE, false)
                steps2.setProperty(hmUI.prop.VISIBLE, true)
            x: 314,  // x coordinate of the button
            text: '',
            normal_src: 'btn2.png',  // button image
            press_src: 'btn2.png',  // button image
            click_func: () => {
                analog.setProperty(hmUI.prop.VISIBLE, true)
                analog2.setProperty(hmUI.prop.VISIBLE, false)
                bg.setProperty(hmUI.prop.VISIBLE, true)
                bg2.setProperty(hmUI.prop.VISIBLE, false)
                week.setProperty(hmUI.prop.VISIBLE, true)
                week2.setProperty(hmUI.prop.VISIBLE, false)
                steps.setProperty(hmUI.prop.VISIBLE, true)
                steps2.setProperty(hmUI.prop.VISIBLE, false)
Rotation animation not working on GTR4 (Zepp OS verison 2).
Darkstalix For clocks, the images are recoded into a color map format. If the dial has a smooth change in transparency, this adds a lot of artifacts. Artifacts can also appear on smooth gradients, but they are usually not noticeable.
1mylord wrote: 28 Dec 2022, 00:20
Absolutely wrong statement.
1mylord wrote: 28 Dec 2022, 01:24
SasHAcx75...
I didn't understand this message.
mirda69
Post by mirda69 »
Thanks guys...and I thought it was up to Zepp OS :(
Darkstalix
Hey thanks a lot for answering!
Is there any way bypass this? the images i use and get recoded were from a GTS2 WF i had made with your previous tool and this limitation wasnt there. I mean i used the exact same files i had in gts2 wf for a GTS4 skin and they get lots of artifacts :(
We happen to know what color map format they get recoded so i can do it myself and not to go back and forth reinstalling the WF etc?
Darkstalix You can try transcoding images in the official editor. They know better the features of the image format on their watches and perhaps they have a better encoding algorithm.
It seems that for xiaomi mi band 7 there is a utility that recodes images without quality loss. But I have not tested it and do not know if such images work on our watches. The format of the dials is the same there so it can work.
bfermar
Post by bfermar »
Is there a way to implement the continuous moving second hand with the editor?
Regards
1mylord
Post by 1mylord »
Thank you always.
Can you tell me the address of the battery shortcut?
Version 6.1
Mirror
1mylord
hmApp.startApp({ appid: 1, url: 'LowBatteryScreen', native: true })
1mylord
Post by 1mylord »
Thank you very much.^^
Version 6.3
Mirror
Powerade001
Has thanked: 12 times
Post by Powerade001 »
WOW!
Added support for notification when BT is connected/disconnected is great! I did not know that this feature was embedded in watchface?
It was the only feature missing for me in the GTR series and now, thanks to SashaCX75, it is now available.
Thanks a lot!
Version 6.4
Mirror
kwakykwaky1
Has thanked: 8 times
Post by kwakykwaky1 »
Hello, would it be possible to add Czech??
kwakykwaky1
I don't do translation. If there are people who want to make a translation or improve an existing one, then write in personal messages.
ZiMiZ
Post by ZiMiZ »
Sasha! i am editing a previous created watchface, and this watch come with some shortcuts, but i wanted to add others shortcuts, like "Alexa" or "Music player"
How i can do?
Lattenknaller
Has thanked: 60 times
Been thanked: 132 times
Post by Lattenknaller »
ZiMiZ
You have to include the extra shortcuts manually in index.js
for example: "Musicplayer"
normal_img_click_1 = hmUI.createWidget(hmUI.widget.IMG, {
              x: 000,			 // Coordinates X
              y: 000,			 // Coordinates Y
              w: 000,			 // Width
              h: 000,			 // Height
              src: 0000.png',       // transparent image
	    normal_img_click_1.addEventListener(hmUI.event.CLICK_DOWN, function (info) {
		hmApp.startApp({ appid: 1, url: 'PhoneMusicCtrlScreen', native: true })
civicdriver80
Post by civicdriver80 »
I have a question about the Bluetooth issue. Is that also present in older watchface editor for example for the gtr2
Users browsing this forum: drex60 and 1 guest
