Version 7.3
Fixed known display bugs.
v 7.2
v 5.0
v 4.1
v 4.0
v 3.1
Added French.
Added support for T-Rex Pro.
Found bugs fixed.
v 2.1
Fixed bugs in display AOD.
Added support for AOD.
Added Chinese translation.
v 1
Added English translation.
v 1.2 Added Spanish language
vlado153
Post by vlado153 »
Could you reupload the latest AmazFit WatchFace editor 2 please?
demiurg1
Has thanked: 23 times
Been thanked: 17 times
Post by demiurg1 »
Franj097
Post by Franj097 »
Hello, have a simple question, how can I create a wf with AOD or keep it when unzipping a downloaded one? I get error when i want to unzip wf i have AOD
Been thanked: 2122 times
Franj097 wrote: 07 Jul 2022, 03:32
I suggest you attach the WF you mentioned.
To provide information to people who want to help you as information in the check it.
demiurg1
Post by demiurg1 »
Send or indicate where to download the ZIP file of this watch face from AOD, then it will check where the error is.
It looks ok. Now I don't have my smartwatch, but at home I will check what it looks like after uploading the ZIP file to the watch.
Franj097
Post by Franj097 »
asoo wrote: 07 Jul 2022, 04:32
Sorry, I realized that I downloaded the wrong program. However, now that I have the correct program AmazFit_Watchface_Editor_2.exe version 7.3 (this one has AOD), I wanted to know if any older version can add Shortcuts, because in the program AmazFit_Watchface_Editor_(GTR47ToGTR2) it could add Shortcuts but it didn't have AOD. I have a GTS 2
Franj097 wrote: 08 Jul 2022, 23:36
AmazFit_Watchface_Editor_2 is real editor for GTR2 format and GTR2 not have shortcuts function so editor can not and any shortcuts.
But the official editor ( https://watchface.zepp.com/create )has a shortcut part.
Ex. ( shortcut in step)
"Activity": [
        "Type": "Steps",
        "PointerProgress": {
          "X": 170,
          "Y": 165,
          "Pointer": {
            "Coordinates": {
              "X": 14,
              "Y": 70
            "ImageIndex": 58
          "StartAngle": 263.0,
          "EndAngle": 371.0
        "Shortcut": {
          "BoxElement": {
            "TopLeftX": 195,
            "TopLeftY": 184,
            "Width": 250,
            "Height": 50
          "ImageIndex": 59
        "Digits": [
            "CombingMode": "Single",
            "Digit": {
              "Image": {
                "X": 252,
                "Y": 188,
                "MultilangImage": [
                    "LangCode": "All",
                    "ImageSet": {
                      "ImageIndex": 41,
                      "ImagesCount": 10
              "Spacing": 1
testshortcutonstep.bin
(491.54 KiB) Downloaded 466 times
But the last time I tested It doesn't work either.
and now I'm not using GTR2 so can't test if it works now or not.
AmazFit_Watchface_Editor_(GTR47ToGTR2) can add shortcuts because it use script GTR47mm to make GTR2 . it's not a real GTR2 format and have some element not work on the GTR2 although it can be displayed correctly on the editor program but some element not work on real device.
Franj097
Post by Franj097 »
Hello, I have a question, How can I upload my own watchface to the page amazfitwatchfaces?
Franj097 wrote: 30 Jul 2022, 05:35
https://amazfitwatchfaces.com/upload
MikeCarbajal
Post by MikeCarbajal »
Hello, I would like to know how I can extract spheres from the zepp store, I would like to modify some of the spheres that appear in the store, I would appreciate them very much.
Fearslayer
Post by Fearslayer »
Anyone can help? i am trying to make a mario watchface but when i upload it to gtr 2 it wont work, it shows the first clock watch without any custom made i did, the watchface was from gts but i unpacked all files and made it from scratch
ghosthouse.zip
(956.3 KiB) Downloaded 456 times
Fearslayer wrote: 15 Oct 2022, 14:36
The problem is most likely caused by the default file.
The GTR2 default file must start at 0001.png.
But in the file you've attached it starts at 0000.png.
I've attached an example I tried to edit for you to check out.
Ghosthouse.zip
(1.5 MiB) Downloaded 496 times
Fearslayer
asoo wrote: 15 Oct 2022, 15:31
Ghosthouse.zip
Thank you, made my adjusts and its very beauty, is there any way to rotate an object? like i made that ghost change, i could make some images and make him move in diagonal, i tried to put angle: -70 but wont work
Fearslayer wrote: 15 Oct 2022, 20:34
Sorry , Now I'm not using GTR2 so I am not sure that can do or not
But if editor can not do it , I think it's can not do too
Fearless-Week
Post by Fearless-Week »
I've been trying for two days now with a skin for T-Rex Pro and all I got is a black screen on the watch when I upload it. I dont know what to. I was using this editor and never have any problems. I tried everything, disabling every pointer, numbers, etc and when I up it to my T-Rex I only have a black screen, the watch look dead but its running.
I dont know what to do, maybe the editor compile wrong something I couldnt find.
Actually was this editor and its version is 7.3
opelnight
Post by opelnight »
ciao qualcuno mi puo' aiutare non riesco a modificare faces
la volevo con l'ora e minuti completamente bianca
e il giorno sabato in verde
BIG.bin
(82.43 KiB) Downloaded 439 times
opelnight wrote: 04 Nov 2022, 23:59
First of all, I recommend that you post in the right area.
- This area is about SashaCX75's editor program.
It is not a place to request corrections watchface.
If you want to request i recommend please use this forum.
viewforum.php?f=39
- If possible, please specify the name of the device you are using.
the file you attached It looks like GTS, but in this area is the GTS2 editor.
Ok, which device watchface do you want, please specify clearly in the request.
- Please follow the Forum rules.
RTMhun
Been thanked: 11 times
Post by RTMhun »
hi.
I made some WatchFaces (GTR2) with this app (WF editor 2), and sometimes I got same error messages while generate bin file - in log file. And bin has not created.
all png files are made by own. I've drawn its in Xara Designer or DotNetPaint
whitch file sould I check or remake/save ?
2022-11-05 17:49:55,102 - root - ERROR - Preview Generate Error...
2022-11-05 17:49:55,103 - root - ERROR - cannot open resource
OSError: cannot open resource
(I've upload two bin file with same errors)
many thanks
_RTMhun_KiteCat_v3_packed.bin
(424.56 KiB) Downloaded 435 times
RTMhun_AlwaysLate_v3_packed.bin
(1.09 MiB) Downloaded 362 times
RTMhun If bin files are not created, what kind of files did you post here? Files that were created without errors? You put here a project in which an error occurs, or at least a complete log file. Usually such errors occur when there is an image not in 32bit format.
RTMhun
Post by RTMhun »
oops you're right. the bins created after I deleted some features while I've searched error solutions.
or created, but does not works like in the editor, as I planned
if you try 3rd version of my CiteCat face, the balls around cathead not moves (followed time) and eyes of the cat does not move like in editor (if you decompile it)
https://amazfitwatchfaces.com/gtr/view/28361
but my new creation doesn't work so I haven't uploaded yet - pls see attachement
and 'course I upload first bin about I talked - KiteCat
(because of got answer, I deleted my json files at this post)
RTMhun wrote: 08 Nov 2022, 09:40
If I'm not mistaken, GTR2 can't use System fonts and custom fonts at the same time . In this case, your problem might be that you are showing Digital time in seconds with custom font and System font at the same time, which might be the reason for the problem you are having. You only have to choose one or the other.
RTMhun
Post by RTMhun »
this can a correct way for sollution
I'll Try!!!
THANKS
RTMhun
Post by RTMhun »
OOOOUUUHH!
it works!
my some projects occures same errors
so sure same solutions wait for me
many and more thanks
you made my day!
mira.vorlik
Post by mira.vorlik »
Hello, after uploading to the watch, the fat burning (Numerical values) item does not appear. Could it be fixed please? This is a T-Rex Pro watch. Editor version 7.3. Thank you MV
RTMhun
Post by RTMhun »
whitch project of me?
Ihave not made watchface for T-Rex only GTR2 ...
