Been thanked: 1029 times
Further support for the editor has been discontinued due to the loss of the computer.
Has thanked: 1137 times
Been thanked: 275 times
SashaCX75 wrote: 27 Mar 2022, 08:44
Привіт! Може, є якісь варіанти і ми можемо чимось допомогти?
TaZoUn3t
Post by TaZoUn3t »
hi guys,
i'm new here and i try to create my own watch face.
thank you for this beautiful software, it will help lots of noobs like me ^^.
Consider the situation, i really hope you are all safe...
Now i'm trying to pack my watch face, but i have a big error :
i have this message for all images of the watch face. i really don't understand how it could be, so...
Is someone knows how to fix it ?
EDIT :
I solved the problem moving the forder of the editor from the desktop to C:
like i said before, i'm a noob ^^
rondolfo
Post by rondolfo »
Thank gods you're still alive! I imagine you have other life priorities right now and probably forever more, but I for one would be happy to contribute to a new computer when things settle down for you. Please stay safe!
R
shivman1990
Post by shivman1990 »
Hi Guys..i want to create my first watchface for zepp os. Can someone please make online tutorial on how to do a basic watchface? i have the tool but struggling to make sense of it. Thank you very much :)
Farron
Post by Farron »
shivman1990
Every single part, whether number, pointer, background or marker must be present as .png. You can also take the images from templates and resize them accordingly or design them yourself.
The editor helps you only to arrange everything sensibly.
Good luck
shivman1990
Farron wrote: 06 Apr 2022, 15:28
@shivman1990
Good luck
Thanks for your help. Which is the best source to find templates ?
Mixmaxmux
Post by Mixmaxmux »
I wanted to congratulate for your work.
I wanted to ask you, if possible, how to implement smooth seconds.
using this tool, perhaps starting from a watchface that already implemented.
Evilmind_04
Been thanked: 14 times
Post by Evilmind_04 »
Damn :cry: ! I hope you're still okay.
Stay safe my friend.
FeRu
Has thanked: 14 times
Been thanked: 8 times
Post by FeRu »
Did anyone notice that after FW update for GTR3 and GTR3Pro moon phases stoped working?
Or they working fine and this is only some kind bug in my watch....
babigiov
Has thanked: 9 times
Post by babigiov »
FeRu wrote: 29 Apr 2022, 10:17
Ciao Feru
I just upgraded to firmware 8.37.3.2 on GTR3 Pro and moon image in the watchface is correct. Could you please provide some more details about the malfunction?
Have you checked if the problem persists even with the store's Sun & Moon watchface?
FeRu
Post by FeRu »
babigiov wrote: 29 Apr 2022, 10:34
Ciao Feru
With sun and moon wf moon phases are not working also. In every wf with moon phases is empty area :roll:
I tried restart watch, reconnecting with phone etc and still no luck.
babigiov
Post by babigiov »
FeRu wrote: 29 Apr 2022, 10:46
Maybe try to wait a few days hoping it is a synchronization problem between the mobile app and some servers.
For example, a couple of days ago it happened to me that the sunrise and sunset times were wrong and the next day everything was back to normal.
We cross our fingers and I wish you everything works out
Ciao
Max88
Post by Max88 »
Guys, do you know if there is a tool to extract and rebuild bin for amzfit bip U ?
Has thanked: 414 times
Been thanked: 2073 times
Max88 wrote: 06 May 2022, 16:13
Editor on web. ( only layout )
https://tnxec2.github.io/amazfit-gts2mi ... ce-static/
https://github.com/Tnxec2/amazfit-gts2m ... ace-static
Huaim online editor
https://watchface.huami.com/create
source for make main.exe to pack and unpack "BIN"
main.exe
viewtopic.php?p=12537#p12537
Max88
Post by Max88 »
asoo wrote: 07 May 2022, 00:43
Huaim online editor
main.exe
Thank you for infos. About main.exe I haven't understood how to use it.
Max88 wrote: 07 May 2022, 11:58
Huaim online editor
main.exe
you can see command line main.exe by Type main /help or main -h in cmd ( Dos mode )
d:\#GTS2mini-BipU>main -h
usage: main [-h] [--vergelite] [--gtr {42,47}] [--gtr2 {42,47}] [--gts] [--gts2] [--trexpro]
            [--oldformat] [--gts2mini] [--bipu] [--trex] [--x] [--file FILE [FILE ...]] [--to_raw]
            [--from_raw] [--border_alignment]
optional arguments:
  -h, --help            show this help message and exit
  --vergelite           force VergeLite watchface
  --gtr {42,47}         force GTR watchface
  --gtr2 {42,47}        force GTR2 watchface
  --gts                 force GTS watchface
  --gts2                force GTS2 watchface
  --trexpro             force TRexPro watchface
  --oldformat           force old json format for GTS2 or GTR2
  --gts2mini            force GTS2 Mini watchface
  --bipu                force Bip U watchface
  --trex                force T-REX watchface
  --x                   force AmazfitX watchface
                        watchface.bin - unpacks watchface images and config watchface.json - packs
                        config and referenced images to bin file
  --to_raw              save raw header and resources
  --from_raw            generate bin from raw folder
  --border_alignment    draw border around aligned objects in preview
Ex. command line unpack file BipU ( BIN )
Ps.
I think if asking about Bip U, I suggest you open a new topic in forum about Bip u viewforum.php?f=6 because this question may not be related to this topic.
demiurg1
Has thanked: 23 times
Been thanked: 17 times
Post by demiurg1 »
Does anyone know any program to automatically convert watch faces from GTR 2 to GTR 3? They have the same size of watch faces. I would like to convert my projects for GTR 2 to GTR 3. Because these are my projects, so if necessary, I can disable eg editable zones.
demiurg1
Post by demiurg1 »
demiurg1
Post by demiurg1 »
Hello. I have been designing watch faces for Amazfit smartwatches for quite a long time. First there were watch faces for the GTR 47, then for the GTR 2 and now for the GTR 3. Due to for the possibility of using authentic animations, not quasi animations, as I did for the GTR 2, I was tempted to make a project using the online tool from HUAMI (Amazfit manufacturer). I made the project and uploaded the watch face to my GTR 3 using the QR-code displayed on the website (https://developer.zepp.com/#/home). The watch face works and it's OK. However, I would like to share it with other GTR 3 users who are not registered Amazfit watch face designers. I have the option to generate and download a file with a watch face design. In the case of my watch face it is some zipped file "VR MONTBLANC clex G3.zab" which contains: another zipped file "amazfit-gtr-3.zpk" and a file "manifest.json". This * .zpk file contains 2 consecutive zipped files: "app-side.zip" and "device.zip". The first one contains only the "app.json" file, and the second one contains 2 "assets" directories (with PNG images unreadable for me) and the "watchface" directory with the "amazfit-gtr-3" directory containing only one "index.js" file and in addition to this directory also 2 additional files: 'app.json' and 'app.js'. Does anyone know anything about what can be done next? If interested, I can try to send someone the "amazfit-gtr-3.zpk" file.
I am a fan of the watch face editing program from SashaCX75. I have always shared the watch faces made in it without any problems, and now I don't really know how to do it. Of course, these dials without animation and without editable zones will still be made with the SashaCX75 tool and made available in the traditional way through this website.
demiurg1
The "device.zip" file (which contains the "assets" directory) is the watch face. To check, you can try downloading it to your watch or open it in my editor.
Recently, the structure of the watch faces created on the Huami website has changed slightly, so they may not open in my editor.
demiurg1
Post by demiurg1 »
SashaCX75 wrote: 15 May 2022, 16:38
Failure to load the file "device.zip" into your editor.
Unfortunately, this "device.zip" file downloaded from Huami's website in your editor does not open. There are only errors from the very beginning until the end of trying to load the watch face into your editor. However, all my designed graphics (including animation files) were properly unpacked to the "Watch_face \ device \ assets" directory. Unfortunately, the "json" file did not appear. I uploaded it to the "manually" directory, and then unpacked graphics appeared in your editor, but without any settings. The "device.zip" file was uploaded to the watch without any problems. Therefore, it is a half-success, because I can make such a watch face available, but not via this website.
don1yoor
Post by don1yoor »
Hello Guys I need help. How to create animated watchface for GTS 3
1mylord
Post by 1mylord »
The needle and cycle of the heart rate do not work the same.
This is because the needle is divided into six sections and acts like an image.
If possible, request that the needle and cycle work together.
