MOD port [GTR 3 PRO]
keval.p21
Post by keval.p21 »
Could someone please port the following face to the GTR 3 PRO
https://amazfitwatchfaces.com/gtr/view/12410
If possible, I would like the weather to be changed for battery % and heart beat (one on top of the other) instead.
Any help with this is greatly appreciated.
Alternatively, If someone can show me how to extract the images, I am willing to learn and recreate using huami tools
Has thanked: 404 times
Been thanked: 2024 times
keval.p21 wrote: 18 Nov 2021, 13:49
You can use "AmazFit WatchFace editor 2 for Windows" to extract this BIN file.
viewtopic.php?p=8392#p8392
ALL file png from nwremake7
PNG-nwremake7_gtr2.zip
(379.34 KiB) Downloaded 151 times
keval.p21
Post by keval.p21 »
asoo wrote: 18 Nov 2021, 14:17
Thank you, however I failed miserably at making this for the GTR 3 PRO. Going back to stock faces for now
NwRemake7-GTR3_1.zip
(952.53 KiB) Downloaded 167 times
NwRemake7-GTR3-PRO1.zip
(1009.68 KiB) Downloaded 230 times
- New upload fixed issue analog hand clock not on the top layer
- Full AOD
Please read carefully
This watchface I do not test on real device. Because I don't have GTR3/3PRO
Anyone who wants to try it , can take it and try it for themselves.
This watchface only create and test on "dev.huami.com"
This watchface I create for test about GTR3 only. I have no plans to do watchface GTR3 right now.
If this watchface not work please tell me. I will delete it.
phoenix1988
Post by phoenix1988 »
everything works. you are well done. Thank you very much from Russia.
Been thanked: 1007 times
The dial works. But almost all elements are located above the hour hands and overlap them.
patrickcentral
Post by patrickcentral »
phoenix1988 wrote: 19 Nov 2021, 12:49
How did you go about putting the zip on your GTR3Pro? I have a couple designs I've been working on and cannot get them on my device to test.
SashaCX75 wrote: 19 Nov 2021, 21:49
Thank you SashaCX75 so much , Now I fixed , I change the analog time to top layer , But I don't know it work on real device or not , I can test only on "dev.huami.com"
viewtopic.php?p=11103#p11103
with respect
Now everything seems to be fine.
keval.p21
Post by keval.p21 »
patrickcentral wrote: 20 Nov 2021, 01:11
Please note this is the reply given to me by phoenix1988. I PM'd him, and this was his reply and it worked out great! (I hope he doesn't mind I shared this info)
phoenix1988 wrote:
Substitute of local files of the stock dial (this is on Android, on IOS I do not know).
Put the watch face from the Zepp store. Then find its files through the file manager (Android / data / com.huami.watch.hmwatchmanager / files / watch_skin_local). Rename the custom watch face archive to the name of the stock archive and drop it into the stock clock folder with Then you sync again in Zepp the dial that you replaced.
It may take a few attempts to get it right
