MOD port [GTR 3 PRO]
keval.p21
- Has thanked: 2 times
Could someone please port the following face to the GTR 3 PRO
https://amazfitwatchfaces.com/gtr/view/12410
If possible, I would like the weather to be changed for battery % and heart beat (one on top of the other) instead.
Any help with this is greatly appreciated.
Alternatively, If someone can show me how to extract the images, I am willing to learn and recreate using huami tools
- Has thanked: 415 times
- Been thanked: 2083 times
You can use "AmazFit WatchFace editor 2 for Windows" to extract this BIN file.keval.p21 wrote: 18 Nov 2021, 13:49Alternatively, If someone can show me how to extract the images, I am willing to learn and recreate using huami toolsSpoiler
viewtopic.php?p=8392#p8392
ALL file png from nwremake7
keval.p21
Thank you, however I failed miserably at making this for the GTR 3 PRO. Going back to stock faces for nowasoo wrote: 18 Nov 2021, 14:17You can use "AmazFit WatchFace editor 2 for Windows" to extract this BIN file.
PNG-nwremake7_gtr2.zip
- New upload fixed issue analog hand clock not on the top layer- Full AOD
Please read carefully
This watchface I do not test on real device. Because I don't have GTR3/3PRO
Anyone who wants to try it , can take it and try it for themselves.
This watchface only create and test on "dev.huami.com"
This watchface I create for test about GTR3 only. I have no plans to do watchface GTR3 right now.
If this watchface not work please tell me. I will delete it.
phoenix1988
- SashaCX75
- Has thanked: 13 times
- Been thanked: 1030 times
The dial works. But almost all elements are located above the hour hands and overlap them.
patrickcentral
- Has thanked: 3 times
How did you go about putting the zip on your GTR3Pro? I have a couple designs I've been working on and cannot get them on my device to test.phoenix1988 wrote: 19 Nov 2021, 12:49everything works. you are well done. Thank you very much from Russia.
Thank you SashaCX75 so much , Now I fixed , I change the analog time to top layer , But I don't know it work on real device or not , I can test only on "dev.huami.com"SashaCX75 wrote: 19 Nov 2021, 21:49The dial works. But almost all elements are located above the hour hands and overlap them.
viewtopic.php?p=11103#p11103
with respect
- SashaCX75
keval.p21
Please note this is the reply given to me by phoenix1988. I PM'd him, and this was his reply and it worked out great! (I hope he doesn't mind I shared this info)patrickcentral wrote: 20 Nov 2021, 01:11How did you go about putting the zip on your GTR3Pro? I have a couple designs I've been working on and cannot get them on my device to test.
It may take a few attempts to get it rightphoenix1988 wrote:Substitute of local files of the stock dial (this is on Android, on IOS I do not know).
Put the watch face from the Zepp store. Then find its files through the file manager (Android / data / com.huami.watch.hmwatchmanager / files / watch_skin_local). Rename the custom watch face archive to the name of the stock archive and drop it into the stock clock folder with Then you sync again in Zepp the dial that you replaced.
