Huawei watchface extractor
Hi.
I found some pretty need watchfaces for Huawei GT3, but I have a Amazfit GT3 Pro.
How can I extract contents from a *.hwt file for use in SashaCX75 editor?
Hazzing
Hazzing
- Has thanked: 411 times
- Been thanked: 2050 times
SashaCX75 editor use for edit " (Huami Amazfit ) GTR 3, GTR 3 Pro, GTS 3, T-Rex 2, GTR 4, GTS 4 Mini, Amazfit Band 7 (not to be confused with Mi Band 7)".Hazzing wrote: 10 Oct 2022, 19:47Hi.
Hazzing
Not for use with HUAWEI
if you use HUAWEI try to see this :
viewtopic.php?t=1005
asoo ....no, I was not too clear....I want to extract the content (png files) from the Huawei and use them to create a watchface for Amazfit GT3 Pro
Sorry in the UNPACK tool of HuaweiHazzing wrote: 11 Oct 2022, 14:57@asoo ....no, I was not too clear....I want to extract the content (png files) from the Huawei and use them to create a watchface for Amazfit GT3 Pro
I don't know about it either.
Lattenknaller
- Has thanked: 58 times
- Been thanked: 130 times
Lattenknaller ....oh, I've done that.....and you don't need to rename the file....all I get is a *.watchface file and a *.xml file and 2 preview png's.....I somehow need to extract the *.watchfile
Lattenknaller
I found program extract file "com.huawei.watchface" in 4pda
https://4pda.to/forum/index.php?showtop ... ry98008683
Thank owner for this program
I tested program can unpack normal . ( Test with watchface Huawei GT3 )
Mirror :
If I'm not mistaken, the program needs a java runtime.
Please install java runtime before use.
https://www.java.com/en/download/manual.jsp
Mirror :
command line to use :
Usage: HuaweiWatchFaceExtractor input [outputDir]
input *.hwt or com.huawei.watchface file
outputDir optional output directory for extracted images. Defaults to <input>_extraPlease install java runtime before use.
asoo ....wow....thank you, but I'm not quite sure how to use the program.
It says, that you can drag and drop on the exe file, but I get nothing.
How did you get files extracted?
You installed java runtime or not ? if you do not install java runtime , program will not work .Hazzing wrote: 13 Oct 2022, 14:27Spoiler
@asoo ....wow....thank you, but I'm not quite sure how to use the program.
you can see java runtime in this link :
I tried the program it work normal ( you can drag and drop or go to run on dos (CMD ) )
This picture in spoiler show the program work normal.
- SashaCX75
- Has thanked: 13 times
- Been thanked: 1029 times
As far as I know, Huawei watch faces can be created in the usual form and in encrypted form. If the author decided to encrypt his watch face, then it will not work to extract resources from it. Most of the new watch faces are created in encrypted form and therefore it is impossible to extract resources from them. But I had little to do with Huawei dials, so I could be wrong.
asoo ....somehow I got it working, but as SashaCX75 says.....some files can be encrypted. I tried two different files....one worked and one didn't......
