HUAWEI Watchfaces Tools & make guide
- TXK
- Has thanked: 149 times
- Been thanked: 97 times
The following content is the Chinese language
Please use the online translation function to read the following:
https://cn.ui.vmall.com/thread-20748955-1-1.html
https://developer.huawei.com/consumer/c ... oc/5050601
https://cn.club.vmall.com/thread-21776359-1-1.html
https://www.bilibili.com/video/av73407528/
[Tips] dial File in. HWT format, which can be renamed. Zip file for decompression and viewing
- TXK
https://developer.huawei.com/consumer/cn/doc/5050601
2. Huawei watch dial development tool
(1) Huawei watch dial development tool:
Windows:https://obs.cn-north-2.myhwclouds.com/h ... 0.1.16.zip
(2) Huawei watch dial test tool: https://communityfile-drcn.op.hicloud.c ... eName=true
如果APP被强制升级,不能使用,请按下列方法操作:
1.断开手机的WiFi 和流量上网,进入APP后就可以装表盘了,
2.进入APP后需要再打开网络,才能添加手表和进入表盘市场。
If the APP is forced to upgrade and cannot be used, please do the following:
1. Disconnect the WiFi and traffic of the mobile phone to access the Internet. After entering the APP, you can install the dial,
2. After entering the APP, you need to open the network again to add watches and enter the dial market.
问: 怎么安装了还是不能安装表盘呢?里面还是只有一个[隐私声明],没有[添加表盘]的选项
答: 从[隐私声明]点进去,先撤销[华为主题服务],再退出来,同意[华为主题服务],就可以了。
Q: how can I install the dial or not? There is only one privacy statement in it, and there is no option to add a dial
A: go in from the [privacy statement], cancel [Huawei theme service] first, and then back out, and agree to [Huawei theme service]. ok.can add a dial
I can't find it on the website. Its still in Chinese language. If u have the link then please give.
Guys I would really thank you so much if you could upload here the tool when It will be released in english because at the moment I am not able to use the chinese one(I'm bad).
- GIK-Team
- root
- Has thanked: 1141 times
- Been thanked: 276 times
https://obs.cn-north-2.myhwclouds.com/h ... .0.100.zipmanny69 wrote: 09 Jan 2020, 20:39Guys I would really thank you so much if you could upload here the tool when It will be released in english because at the moment I am not able to use the chinese one(I'm bad).
Plz tell me which language i have to learn for making watch faces
Hi guys I am based in NZ using Huawei P30 Pro and GT2 watch 46mm atm and had been trying to use various methods to install custom watch faces but so far unsuccessful.
Had tried chinese ID and beta Health app but still no luck.
Had tried Xposed and TaiChi method but stuck at reinstalling.
Not sure what else I could try as I understand so far different region has different watch face store/app policy which I think NZ would probably be a bit behind.
Can anyone shed some bright light if you know what is the easier way to install custom faces to solve my eagerly patience?
Thanks a lot in advance!!
Q
Q
Im based in the US and am trying to et watch faces. I have the TaiChi method as well with no success.
Simracing83
Hello i'm based in Europe and tried these methods as well also with no succes.
