bigdigital.kov
Been thanked: 9 times
Messaggio da bigdigital.kov »
How to use it.
Codice: Seleziona tutto
Notes .
-cmp2 Compress gtr2(gts2) bin
-unc Decompress
Current version 0.2
Chagelog
v0.2
Added widgets.
Allegati
(323.58 KiB) Scaricato 2333 volte
Ultima modifica di bigdigital.kov il 31 gen 2021, 18:53, modificato 3 volte in totale.
Has thanked: 419 times
Been thanked: 2107 times
Messaggio da asoo »
Test Report
- GTR2_Packer.exe can uncomprss and compress but the file size not same Original file.
- Main can pack and unpack BIN ( uncompress ) but File BIN after pack file size not same Original file.
- File BIN after pack by "main" can link to the watch but some option is loss. it's not same Original show.
However, I think this is a good step forward for the GTR2.
Thank you for your share
PS. Test on GTR2e
dboro
Messaggio da dboro »
@bigdigital.kov
This is a great news!!
Thank you!
Now just if @SashaCX75 could adapt his awesome tool to use this and generate the correct Json... :roll:
demiurg1
Has thanked: 23 times
Been thanked: 17 times
Messaggio da demiurg1 »
I'm for it too!
demiurg1
What am I doing wrong? When unpacking a BIN type file, I get a file with the extension * .bin.unc, not cmp.
bigdigital.kov
demiurg1 ha scritto: 29 gen 2021, 11:58
It's ok. Just rename it back to bin and try to parse.
demiurg1
I did it, but I guess I'm still doing something wrong or missing something.
I have unpacked the tool in a separate directory "py_amazfit_tools-GTR2".
1. I have uploaded a watch face file to this directory, named: test.bin
2. I ran the command: GTR2_Packer.exe -unc2 test.bin
3. I have received a new file: test.bin.unc
4. I have changed its name to test.bin
5. I ran the command: python main.p --gtr2 47 --file test.bin
Previously, I installed the "python-3.9.1" program in the "Python" directory and uploaded a copy of the new file to this directory: test.bin
6. Unfortunately, this command: "python main.p --gtr2 47 --file test.bin" has no effect both when running it in the "Python" directory and in the "py_amazfit_tools-GTR2" directory.
What else am I doing wrong?
I am asking for tips - help. I don't program in Python. My programming experience is just old Borland Pascal and then a bit of Delphi. Currently I deal more with computer graphics.
joebar78
Messaggio da joebar78 »
Maybe you didn't install pillow after installing python ?
Try to execute with a command prompt:
python -m pip install --upgrade pip
python -m pip install --upgrade Pillow
From
C:\Users\your user\AppData\Local\Programs\Python\Python39 (or where is python installed)
And then try to unpack again your bin file.
Also i think you should write main.py instead of main.p
python main.py --gtr2 47 --file test.bin
demiurg1
Thank you so much for help. Your advice allowed me to translate the test face of the GTR 2 watch into Polish. I just had to make sure that instead of just indicating the file name, write the full path to this file (along with the name of the directory, which was created with the same name as the file name) .
Thanks again. If you were here in Poland, I would be happy to invite you for a beer for your effective help.
mamunabrar
Messaggio da mamunabrar »
bro please make a video and upload in youtube
afwafwafw
Been thanked: 14 times
Messaggio da afwafwafw »
great job! glad to hear someone did this.
eliasf
Messaggio da eliasf »
Worked as expected for a couple of watchfaces on my gtr2e, thank you very much for your time spent @bigdigital.kov!
Had a look at the code, it's not as easy as one might think, mainly due to the differences in gtr2's json file as I perceive it.
I agree with the need for a GUI like @SashaCX75's tool, I imagine that if there was access to the source code it wouldn't be super hard to implement the necessary adaptations for the gtr2.
Anyway, we can only hope and wait for the developers to continue their hard work for all of us and our favorite devices!
demiurg1
I made, or actually converted into Polish, my first watch face for the GTR 2.
I did it thanks to the information posted here by "bigdigital.kov" and also thanks to a lot of help from "joebar78".
This is a remake of the "Classic Touch Blue" dial placed here by "Do_bro" and, as he wrote, created by "Kivan".
I hope that they will not be offended when the Polish version of this shield for GTR 2 appears here. I just wanted to show that the advice published here is effective. I wrote to "Do_bro" about this but he didn't reply. If there is such a wish, I can delete this watch face.
I will publish it under the original name with the addition of PL, which is "Classic Touch Blue PL". I am enclosing a photo of the final watch face. Unfortunately, the colors are slightly different from the actual ones. In fact, this watch face is prettier (it looks better on a watch).
By the way.
I had to take a photo of the watch to send the final image.
Does anyone know of any other way besides the tedious drawing of a working watch face?
demiurg1
This Polish redesigned watch face is here: https://amazfitwatchfaces.com/gtr/view/12098
demiurg1
I made a second watch face for the GTR 2. This time I really "carved" it by designing it "by hand".
Here you can see it and read about it in English and Polish, and of course download the BIN file.
Link: https://amazfitwatchfaces.com/gtr/view/12120
Messaggio da asoo »
Test py_amazfit_tools-GTR2_v0_2.zip ( Fixed Images loss when packing bin file).
Now Program can pack and unpack normal .
Thank bigdigital.kov for fixed the program.
demiurg1
I also join the thanks.
Messaggio da asoo »
Test Version 0.2
- Test on GTR2e , it's work normal
https://amazfitwatchfaces.com/gtr/view/12140
PS. Edit .json with notepad.
Ultima modifica di asoo il 01 feb 2021, 19:04, modificato 2 volte in totale.
demiurg1
Everything is displayed in my dial where I planned. I only have a problem with the signs: bluetooth and alarm. Both icons do not want to be displayed on the watch face. Maybe you have any idea?
I set the Bluetooth and Alarm settings as it is in another watch face. These characters are displayed in the "master" dial, and unfortunately not in the new dial after merging into BIN.
demiurg1
I can see that many people are already creating watch faces for the GTR 2. I am also trying to design them and I have already made two of them public. However, I do not know, for example, how to make a GIF file for presenting the watch face, or at least a PNG file so as not to take a photo of the watch face. Please give me a hint.
Messaggio da asoo »
demiurg1 ha scritto: 01 feb 2021, 18:51
The watch face I made for GTR2, I used to make it in GTR, so I used the Gif image from GTR.
As for PNG images, if you don't want to take pictures from your watch, you can use the picture 0002.PNG (Background) to decorate it with your favorite photo editor.
Actually, if you initially create a watchface by yourselfe,
You Should have a layout picture ready to use as the preview.
demiurg1
Yes, I can use my own GTR 47 designs. I have GIF files there. Worse with the dials newly designed for the GTR 2. As for the PNG of the watch face, it is a bit tedious to create the final result. My initial design differs too much from the final result.
Thank you for the advice though.
In my final project for GTR2, the sign: bluetooth and alarm are not displayed to me. Can you advise something? I can see these marks are on your watch face.
Best regards.
Messaggio da asoo »
demiurg1 ha scritto: 01 feb 2021, 20:12
Best regards.
Bluetooth : As far as i know ,on GTR2 the default bluetooth will be ON , so icon in background must set show it ON , and in Status icon Bluetooth you must be create picture to OFF
Alarm : I am not sure why your watchface not show , May be you don't set Alarm time or have some misstake in your .json file
MatZil02
Messaggio da MatZil02 »
I can confirm that the default status for bluetooth icon is ON state.
I've made a watchface for the GTR 2, I'm going to buy it :), using the official tool from Huami (it's online, i talked about it on Reddit).
I don't know if it was possible before, but you can make icons shortcut for things like Weather, steps, PAI, Heartrate (i's called "jump hot zone" in the official editor).
demiurg1
I do not have access to the HUAMI online tool. I applied for access more than 7 days ago and to no avail. When I try to enter the website, I get the message "You registration application is under review".
As for the display of icons: alarm and bluetooth, I coped with the alarm icon. Unfortunately, the bluetooth icon is not displayed on the watch face, even though bluetooth is turned on and the smartphone and the watch "see" each other. In the applications:" Zepp" and" "Notify for Amazfit" my GTR 2 is visible. I don't know what about this bluetooth icon?
Torna a “Watchfaces tools”
