Search found 6 matches
- 06 Jul 2019, 11:11
- Jump to forum
- Jump to topic
Expect amazfit verge lite to use a custom dial
- 05 Aug 2019, 19:03
- Jump to forum
- Jump to topic
Amazfit watchfaces Tool
https://cdn1.savepice.ru/uploads/2019/8/5/6da5881f902a163d8262fb1b82a899b2-full.png
We have been working for a long time and continue to make our own Tool for watch faces.
Everything is built on these sources.
Support watch faces for devices
Amazfit Bip
Xiaomi Mi Band 4
Amazfit GTR ...
Amazfit Bip
Xiaomi Mi Band 4
Amazfit GTR ...
- 22 Jan 2020, 09:11
- Jump to forum
- Jump to topic
Re: py amazfit tool
I have a problem with my watchface https://amazfitwatchfaces.com/gtr/view/3058
As soon as I add battery it will pack ok and installation is launching fine but watch failed to display new face and revert to stock.
If I add battery and remove step progress it works. It seems I can't have both step ...
- 30 Jan 2020, 15:30
- Jump to forum
- Jump to topic
- 28 Jan 2021, 16:52
- Jump to forum
- Jump to topic
It is also has included tool which allows to compress and decompress GTR2 ...
- 07 Nov 2019, 03:17
- Jump to forum
- Jump to topic
If you find any bug in the use of AMAZFIT verge lite, please leave a comment here [Verge Lite]
Mainly in the use of bugs, preferably not recommendations.
they have their own planning arrangements, and may not be arranged.
If it's a bug they'll fix it ahead of time
