Messaggio da SashaCX75 »
Emiliomc
Messaggio da Emiliomc »
Very sorry. I thought this was the forum I should go to. So I don't know which forum I should go to and ask questions there, attaching images.
Version 13.0
Mirror
mbriacuni
Messaggio da mbriacuni »
Do you think it is possible to send an http request with a button directly from the watchface? I know it's possible using the "http" app created by galulex but if it were possible I would like to save the step of opening the app.
rush2112
Has thanked: 119 times
Messaggio da rush2112 »
@SashaCX75
Hi, I have a brief inquiry regarding the GTR3 Pro smartwatch. Could you please consider unlocking the angle of the barometer in the next update? It appears that all other angles in your editor are adjustable, except for this particular one , just please take a look at the Distance angle is unlock / is fine . Thank you.
@rush2112
There are two different parameters ‘ Numerical values’ and ‘ Value at angle’ for a reason. They display data in different ways. So it is wrong to compare them. There is no easy way to display angled pressure on the GTR3.
piotarock
Messaggio da piotarock »
toolsrme ha scritto: 15 gen 2024, 22:18
Thanks @SashaCX75.
I see that in the 10.2 version of the app. I was able to put it all together, but I have a question where I'm probably doing something simple wrong. After using your tool to pack the face, I put it in a directory and unzip it so that I can run "zeus dev" and have it show in the simulator, but it gives me the following error:
error Please set at least one package.
I can see that the apps.json is a little different in that it doesn't have the same JSON structure as what zeus create builds, but contains the same data. Is there a trick to getting the output to work with ZEUS CLI?
Did you ever solve this problem? I am encountering the same challenge.
rush2112
@SashaCX75
@asoo
I inserted a JavaScript into the editor tools, and now I'm trying to create a shortcut. However, I'm not sure how to make the button appear in the editor. Can you give me some advice? Thanks ;)
Been thanked: 2122 times
Messaggio da asoo »
rush2112 ha scritto: 26 gen 2025, 11:29
@SashaCX75
@asoo
As far as I know, the JS script that you add to the editor
will not be displayed in the preview section of the program.
You need to understand the script you added to it, so that you can use the function or command set from the script to define the operation through the function "Button" of the editor by yourself.
Example image of using a function in a script via a button.
However, if you want to simulate the operation of the watchface to test the js script you added, you can do it through the simulator
such as
ZeppPlayer
The ZeppPlayer can simulate about 80% of the operation
and is compatible with ZeppOS1
or
the official ZeppOS Simulator
https://docs.zepp.com/docs/guides/tools ... /download/
The ZeppOS Simulator will simulate correctly, but the settings may be more difficult, but you can see more information here https://docs.zepp.com/docs/guides/tools ... /download/
rush2112
@asoo
Thank you for your response! I appreciate your detailed explanation of the steps to follow. I'll give it a try!
wanders
Messaggio da wanders »
@SashaCX75 , is there any chance that you will support the new Amazfit Active 2 round watch? I have yet to see any mention of it in this forum.
u6gljnuj4l
Messaggio da u6gljnuj4l »
wanders ha scritto: 30 gen 2025, 18:44
I also have the Amazfit Active 2 and would love to see it supported. NOTE: As a workaround for now you can download several of the Amazfit GTR 4 watch faces onto the Amazfit Active 2 (same screen resolution). They all don't work but I have successfully downloaded several of them to my Active 2. I downloaded them to my watch by using Developer Mode on Zepp app and scanning QR code.
In order to add support for the Amazfit Active 2 I need to see at least examples of these watch faces first.
Most likely this model will be added. But if the GTR 4 watch faces are suitable for the Amazfit Active 2, it's not a critical update and it's not a priority. That's why I haven't looked into it yet.
SushiSeb
Messaggio da SushiSeb »
Running into this issue when trying to import this gtr 3 watch face to convert. Any ideas?
Has thanked: 130 times
Been thanked: 20 times
Messaggio da taw_bip »
I use 12-hour format. I have a watchface that shows sunrise/sunset times but it uses 24-hour format. Is there a way to fix?
@SushiSeb It's hard to tell without seeing the watch face. Most likely one or more images are encoded in a format not supported in the editor.
@taw_bip When using the standard widget, sunrise / sunset data does not respond to time format changes. This can only be corrected by using your own code.
SashaCX75 ha scritto: 01 feb 2025, 08:56
@SashaCX75 The watchface I'm looking at is this one:
https://amazfitwatchfaces.com/gtr/view/41938
Can you advise?
apgeo
Messaggio da apgeo »
does anyone know how to add new fonts to the program? There is the 'add new font' button but it gives an error and you can only use the original font
@apgeo
The others do not complain about this function working. So maybe you are doing something wrong. For example, you are trying to add a font that is already in the project folder.
Fladis
Messaggio da Fladis »
I was working normally in the SW and than I tried to pack the WF and an error occured:
System.IO.IOException: Access to the path 'D:\Watch_Face_Editor_(ZeppOS)old\Temp' is denied.
at System.IO.Directory.DeleteHelper(String fullPath, String userPath, Boolean recursive, Boolean throwOnTopLevelDirectoryNotFound, WIN32_FIND_DATA& data)
at System.IO.Directory.Delete(String fullPath, String userPath, Boolean recursive, Boolean checkHost)
at Watch_Face_Editor.Form1.DeleteDirectory(String target_dir)
at Watch_Face_Editor.Form1.Unpack_Zip(String fullFileName)
at Watch_Face_Editor.Form1.button_unpack_zip_Click(Object sender, EventArgs e)
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.9290.0 built by: NET481REL1LAST_C
Assembly Version: 13.0.0.0
Win32 Version: 13.0.0.0
CodeBase: file:///D:/Watch_Face_Editor_(ZeppOS)old/Watch_Face_Editor_(ZeppOS).exe
Win32 Version: 4.8.9251.0 built by: NET481REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 4.8.9282.0 built by: NET481REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 4.8.9037.0 built by: NET481REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Newtonsoft.Json
Win32 Version: 13.0.3.27908
CodeBase: file:///D:/Watch_Face_Editor_(ZeppOS)old/Libs/Newtonsoft.Json.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
Win32 Version: 4.8.9277.0 built by: NET481REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Numerics
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Runtime.Serialization
Win32 Version: 4.8.9241.0 built by: NET481REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
System.Data
Win32 Version: 4.8.9214.0 built by: NET481REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
ControlLibrary
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///D:/Watch_Face_Editor_(ZeppOS)old/Libs/ControlLibrary.DLL
ControlLibrary.resources
CodeBase: file:///D:/Watch_Face_Editor_(ZeppOS)old/Language/en/ControlLibrary.resources.DLL
Watch_Face_Editor_(ZeppOS).resources
CodeBase: file:///D:/Watch_Face_Editor_(ZeppOS)old/Language/en/Watch_Face_Editor_(ZeppOS).resources.DLL
DotNetZip
Assembly Version: 1.16.0.0
Win32 Version: 1.16.0
CodeBase: file:///D:/Watch_Face_Editor_(ZeppOS)old/Libs/DotNetZip.DLL
enabled.
For example:
<configuration>
</configuration>
Now I am not able to do anything. Even the unpacking WF. Only open the project.
Anyone know what happend?
@Fladis
The first line of the error message says that you cannot access the temporary folder. This may be caused by your OS or firewall settings.
The easiest way to fix it is to try deleting the folder ‘D:\Watch_Face_Editor_(ZeppOS)old\Temp’. You can also try copying the editor to another folder.
Fladis
SashaCX75 ha scritto: 09 feb 2025, 12:11
@Fladis
Thanks for advise, but it didn't work :( I also tried to download a new copy of the editor, didn't work as well.
Fladis
Aaaa. I found a solution. Run it as an administrator! Sorry, It didn't come to my mind earlier. But your note about the firewall does. So thanks
In any case, this is strange behaviour. This is not a system folder so that administrator rights are required to work with it.
Guydu91
Has thanked: 58 times
Messaggio da Guydu91 »
SashaCX75 ha scritto: 05 feb 2025, 22:08
@apgeo
I have already encountered this problem.
It is possible that the TTF file is corrupted.
So you have to save the JSON as is, then delete the Fonts folder in the Assets folder.
You also have to delete the Fonts folder in the Temp/Assets folder of the editor otherwise the error persists.
I think that some OTF files have been renamed to TTF without doing a real conversion (this is what happened to me).
In this case, just rename this file to OTF then convert it via an online converter to TTF (I use the site https://convertio.co/ ).
Then just reopen the JSON file and start adding the font again with the right file.
Best regards.
Guy.
@Guydu91 When a font is added to a project, it is simply copied to the folder. So if it was simply renamed, it should not cause an error. Perhaps an error may occur when the editor tries to read the name of the font in the properties. But I have not encountered such an error.
When testing this function, I tried adding different fonts. Including those that had TTF extension but were not TrueType. Unfortunately, in most cases the editor could not recognise such fonts, and errors occurred on the watch.
Torna a “Watchfaces tools”
